| shellandtube |
 shellandtube Derestricted Danger
 Posted: 00:34 - 06 Apr 2004 Post subject: Overheating NSR |
My Honda NSR125RL is overheating. Also in 3rd/4th gear there is a loss of power if the revs dip below 4500rpm. A m8 suggested my mixture was probably lean.
Anyone any ideas on how to change it and set it right?
I am kinda new to 2 strokes and would be greatful for any help.
Cheers.  ____________________ If you can't laugh it's not funny...... |
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
 Posted: 01:20 - 06 Apr 2004 Post subject: |
The trick is not to let the power drop below 4500rpm. The power only comes in with the NSR at about 8000rpm (On the 1993 onwards machines) so keep it around that area if you want power.
As for the overheating, have you checked the water levels? (I know it's obvious but I've got to check.) Also have you checked that the radiator is getting hot at all? If not then maybe the pump has died.  ____________________ Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders. |
| shellandtube |
| ProXimaCore |
 ProXimaCore Dougal
 Posted: 09:28 - 06 Apr 2004 Post subject: |
Has the bike had an engine rebuild lately? A week after mines was rebuilt I was hit by severe overheating when something called a spigot (sp?) came loose. Couldn't even plod along at 5mph without it overheating. Not sure how to fix it, I just took it back to the place that done the rebuild for me and got them to fix it for free. ____________________ Honda NSR125R -> Suzuki GSXR400R GK76a -> Kawasaki ZX636 B1H -> Honda CBR400RR NC29 -> Nothing  |
| shellandtube |
| shellandtube |
| Scouse |
 Scouse World Chat Champion
 Posted: 20:11 - 06 Apr 2004 Post subject: |
Is it just the Temperature gauge that shows over heating? My NSR had a thing of doing that. I later found that it only showed that it was over heating when I had the lights on. When I looked at the wiring, some of the wires were touching that shouldn't of been. When separated, the problem was solved. No more overheating worries. So I'd just check that as well.  |
| shellandtube |
| daveyboy2002 |
 daveyboy2002 L Plate Warrior
 Posted: 13:43 - 08 Apr 2004 Post subject: |
wot a nitemare,
ok you will have to make sure that your oil mixture is spot on, otherwise you'll get major problems.
on my NSR it smokes when first started and after a RUN it stops and i no this is 100% correct, but mine is newer and deristriced.
when the engine dies, does it seize, back wheel lock up or just loose power? the little bit of power obtained on these bikes are at 8000rpm its hard to cruise under 6000rpm and expect to pull away. i suggest you change your plug on it aswell, i blew mine within a week, follow these simple guild line and see who you get on, if you still have no joy ask Kick Start. he's full off knowledge
dave ____________________ guess the top speed of my nsr125rr |
| shellandtube |
 Posted: 21:54 - 08 Apr 2004 Post subject: |
When it cut out I pulled the clutch in so fast, but the back kicked out a little so i dont know if it was about to lock up or not.
My NSR is derisricted aswell as i was running along at 170 kph in 5th with maybe a little left in her. Didn't dare push it any further was running out of straight open road rapidly.
Going to change the plug friday. If all is well at work.
Thanks Dave.  ____________________ If you can't laugh it's not funny...... |
| T_revs |
 T_revs L Plate Warrior
| Slinn84 |
 Slinn84 Scooby Slapper
The last post was made 21 years, 256 days ago. Instead of replying here, would creating a new thread be more useful? |
