seized dowel removal
PostPosted: 19:53 - 19 Sep 2008    Post subject: seized dowel removal Reply with quote
Went to remove one of the dowels that goes between the crankcase halves to make it easier to clean the mating surface.
Gripped it a bit too hard in the pliers and ovaled it.
"Ah well, that one's fucked, I've got a spare, doesn't matter if I grip it really tightly now." Thinks I as I grab the mole grips from the toolbox.
So, now I have a mangled stump of dowel stuck in my crankcase.
I've been applying penetrating oil and it is currently in the oven.
There is still currently just about enough sticking out to get hold of.
Any other useful suggestions? Something tells me this would be a complete and utter bastard to drill out.
Moral of the story?
1) More haste, less speed.
2) Mole grips have no place in the workshop until AFTER things have gone wrong.
gmanxiii
PostPosted: 20:00 - 19 Sep 2008    Post subject: Reply with quote
i had a dowel seized in when replacing the clutch cover on my cbr, i just used a rubber mallet and battered it abit..
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
MaybeGuy
PostPosted: 20:06 - 19 Sep 2008    Post subject: Reply with quote
file it down a bit on either side, and get a spanner around it?
SoND
PostPosted: 20:10 - 19 Sep 2008    Post subject: Reply with quote
Set a nut over it and fill it up with weld? If the case is aluminium you won't have to worry about accidently welding the steel to it.
Are the dowels hardened? If they are it might weld but will probably be very hard and just snap on you.
FerretFing
PostPosted: 20:19 - 19 Sep 2008    Post subject: Reply with quote
any pics of it? might get a few brain juices flowing Thumbs Up
PostPosted: 20:36 - 19 Sep 2008    Post subject: Reply with quote
Right. It's REALLY mangled now.
I reckon it'll have to be drilled.
Had it up to 230 degrees and still not shifting.
Why the hell didn't I just leave it where it was!?
Tomorrow though. I've already caused enough trouble for one day!
MaybeGuy
PostPosted: 20:47 - 19 Sep 2008    Post subject: Reply with quote
if you ignore the problem, it might go away Whistle
Jamie S
PostPosted: 21:45 - 19 Sep 2008    Post subject: Reply with quote
Shame the same theory doesn't apply to you matt....
PostPosted: 21:56 - 19 Sep 2008    Post subject: Reply with quote
For removing stuck dowels, it's always better to tap a good-fitting drill bit into the centre-hole backward before attempting to grip them. Bit late for that now I know.
As a remedy I'd be tempted to get some 16 gauge plate and drill a hole in it of the dowel OD size. Fit the plate over the dowel and grind the dowel down to the plate. Now remove the plate and you should have 1.6mm or less of dowel sticking up proud of the case half, which should not be mangled much. If that still won't do the job of locating the halves, I'd re-drill the plate the same size and use it as protection for the cases and drill down into the dowel a bit. Once at or below the case surface I'd turn-up a solid plug the length of the original dowel. Half the length would be the same as the OD of the dowel, the other half would be the ID of the dowel, with a small starting taper on the end, then I'd tap the plug into the bit of dowel stuck in the case.
MaybeGuy
PostPosted: 22:30 - 19 Sep 2008    Post subject: Reply with quote
hows that arsehole? yes i mean you
Jamie S
PostPosted: 22:33 - 19 Sep 2008    Post subject: Reply with quote
Fine now, thanks for inquiring.
sickpup
Old Timer
PostPosted: 22:46 - 19 Sep 2008    Post subject: Reply with quote
You've just given me an idea.
Piece of flat plate with a dowel size hole in it. Placed over then welded would give a nice lever for removal.
finpos
PostPosted: 23:56 - 19 Sep 2008    Post subject: Reply with quote
Definitely weld a plate to it if you can. Next time, use a drill chuck (old fashioned one you tighten with a key if possible) to grip the dowel.
f.
Odie
PostPosted: 04:42 - 20 Sep 2008    Post subject: Reply with quote
Instead of heat try cold.
I use lighter gas (not fluid!).
used this method before on stuck wheel bearings, heat the ali (gently) and freeze the dowel
PostPosted: 04:48 - 20 Sep 2008    Post subject: Reply with quote
Yeah that would work well, better put a washer over the dowel first in case the plate needs grinding off if it don't work and to prevent it scraping-up the mating srface as you turn it back and forth to work the dowel out.
The last post was made 18 years, 36 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 88.66 Kb
