Help with a laptop.....
lllN30lll
PostPosted: 17:16 - 25 Sep 2008    Post subject: Help with a laptop..... Reply with quote
I've never worked on a laptop before, some blokes give me his and told me it doesn't work...
so got it home, it boots to the POST and gives 2 beeps. if i'm not mistaken then that's a ram error right?
where do I get to the ram to test/change it?
cheers.
PS it also gets to this part and the keyboards unresponsive, so is a USB keyboard, i'm guessing it's an old BIOS that doesn't work with USB keyboards.
https://img.photobucket.com/albums/v707/lllN30lll/25092008448.jpg
https://img.photobucket.com/albums/v707/lllN30lll/25092008449.jpg
Turbo R1
CRF450R
lllN30lll
PostPosted: 17:57 - 25 Sep 2008    Post subject: Reply with quote
right, took the rear ram out, still 2 beeps.
took the front ram out and swapped it with the rear. still 2 beeps.
removed the HD and reseated, still 2 beeps.
next?
Turbo R1
CRF450R
map
Mr Calendar
PostPosted: 18:10 - 25 Sep 2008    Post subject: Re: Help with a laptop..... Reply with quote
lllN30lll wrote:
...gives 2 beeps. if i'm not mistaken then that's a ram error right?...
Wrong. Google is your friend and this thread would make it a CMOS setup error with keyboard fault. So just how you get into CMOS without a keyboard I don't know.
However, this link does say memory parity error.
You may want to google and see if there's a CMOS reset for that model. Another idea is, depending on the age, a flat battery used to preserve the settings. Could try remove/replace that if it's accessible.
Just some thoughts.
lllN30lll
PostPosted: 18:30 - 25 Sep 2008    Post subject: Reply with quote
keyboard won't work at all, tried a G11 USB keyboard too.
checked the keyboard ribbon too. Thumbs Up
Turbo R1
CRF450R
MaybeGuy
PostPosted: 19:56 - 25 Sep 2008    Post subject: Reply with quote
maybe its just hanging.
have you tried new ram?
lllN30lll
PostPosted: 20:10 - 25 Sep 2008    Post subject: Reply with quote
surely both sticks can't be fooked?
Turbo R1
CRF450R
MaybeGuy
PostPosted: 20:11 - 25 Sep 2008    Post subject: Reply with quote
i suppose its possible. other than that... Thinking no idea.
bazza
PostPosted: 21:30 - 25 Sep 2008    Post subject: Reply with quote
Check the CMOS battery, clean it with a soft damp cloth, then refit. Better yet, make a note of the number and replace it.
While you're waiting for the new battery, give the inside a good dig out and clean it up - use a small, soft brush and a can of compressed air. Check every connection for bent, loose or missing pins.
Seb
PostPosted: 23:06 - 25 Sep 2008    Post subject: Reply with quote
When it's stuck at that prompt, does it switch off with a single brief tap of the power button?
Is the main battery able to hold a charge at all?
Edit: I assume it doesn't have a PS/2 port? I've not had that mitac chassis come through work so it's not one I'm familiar with Sad
2010 Triumph 1050 Sprint ST
NSR Mick
PostPosted: 23:55 - 25 Sep 2008    Post subject: Reply with quote
As mentioned the CMOS battery is likely to be shagged.
As far as the keyboard goes do the key's feel sticky. I suspect a can of coke or a cup of coffee. Laughing
short1uk
PostPosted: 14:09 - 26 Sep 2008    Post subject: Reply with quote
have you taken the keyboard off at all or made sure its attached properly to the MB. Some one might have had ago already at removing it and buggered it up. CMOS settings suggest the battery is defo dead so get a new one in there. Then try using the keyboard.
The last post was made 18 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 69.51 Kb
