Bullet Cam Setup
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
Graham88
PostPosted: 04:51 - 26 Sep 2008    Post subject: Bullet Cam Setup Reply with quote
I bought this Bullet Cam on eBay with the intention of some decent videos at last. Then realised after I'd won it that it needed a camcorder attached, doh Laughing
Anyway, should be able to get better videos with this setup than a wireless cam.
My question is, how would I go about attaching it to a camcorder? I've taken a pic of it all, hopefully someone can point me in the right direction as to what goes where, and what port the camera I buy will need for it to work.
All of it:
https://i18.photobucket.com/albums/b112/GrahamVFR/Random/bulletcam.jpg
This isn't plugged into anything:
https://i18.photobucket.com/albums/b112/GrahamVFR/Random/bulletcam2.jpg
Nor this:
https://i18.photobucket.com/albums/b112/GrahamVFR/Random/bulletcam3.jpg
This must be the external mic?
https://i18.photobucket.com/albums/b112/GrahamVFR/Random/bulletcam4.jpg
The camera itself, it's tiny! Very Happy
https://i18.photobucket.com/albums/b112/GrahamVFR/Random/bulletcam5.jpg
Any help appreciated. I went into Currys today to look at some cameras, some decent looking ones for £150 margin, which is fine, some touch near enough £500 and I'd rather I didn't need one of those tbh Laughing
Seb
PostPosted: 07:30 - 26 Sep 2008    Post subject: Reply with quote
You need a recorder of some sort with AV inputs. The yellow plug is video, the Y plug is audio. I'd suggest a decent SD recorder as bike vibrations are not going to do any tape/hdd/dvd units any good.
2010 Triumph 1050 Sprint ST
Hetzer
PostPosted: 08:40 - 26 Sep 2008    Post subject: Reply with quote
I've got over £500's worth of gear I used only a handful of times. I went with the dedicated HD recording unit in the end, to avoid the dreaded frame-skipping, and it's worked perfectly well wrapped in a soft cloth in a bum-bag.
Bendy
Mrs Sensible
PostPosted: 12:26 - 26 Sep 2008    Post subject: Reply with quote
Most video cameras don't have AV in - there are some out there but it's by no means standard so check.
My bullet cam setup was similar, needed a lead with a 3.5 jack (headphone style) at one end and the female yellow, red and white audio and video at the other in order to plug it into the DV cam.
My video camera survived a lot of crashes (it was on the racebike mostly), in fact it still works as a recorder, just not as a camera any more Laughing Should probably dig it out and fix/sell/do something with sometime.
Graham88
PostPosted: 13:10 - 26 Sep 2008    Post subject: Reply with quote
Right so I need a 3.5mm to go into the camera, will this be called an AV port or something?
Do I need 3.5mm to 3.5mm?
Or 3.5mm to L&R audio?
I really don't have a clue Laughing
How am I supposed to get a lead to plug into the red lead, as it's already connected to the external mic?
The adaptor on the white plug is one of these? What's the purpose of it?
I was just going to store it in a backpack aswell Hetzer, I would hope that the £150 would be able to keep up mind you, if not I'll just take it back to the shop. What's a decent FPS to be looking at before it's too slow?
Thanks for help Thumbs Up
Hetzer
PostPosted: 13:18 - 26 Sep 2008    Post subject: Reply with quote
The FPS is a bit misleading, as it bears no relation to frame-skipping. The solid-state memory-cards cannot handle the data fast enough, which is why you get frame-skipping (jerkiness). Even on the two £250 ones I tried the skipping was very bad.
Graham88
PostPosted: 13:21 - 26 Sep 2008    Post subject: Reply with quote
Did you just bring it back when you found it couldn't keep up, and they were fine with that?
I can't see why they wouldn't be as the camera can't serve the purpose it was bought for.
Hetzer
PostPosted: 13:27 - 26 Sep 2008    Post subject: Reply with quote
I dealt with Dogcam (Mark I think) and he provided sterling service. The first unit we thought was buggered, but the replacement was the same. He hadn't noticed it before, and apparently his previous customers were happy enough. Everything posted back and forward at high speed, no quibbling, free battery-packs thrown in, leads, all-round nop-notch chap. Thumbs Up
Graham88
PostPosted: 13:32 - 26 Sep 2008    Post subject: Reply with quote
I'll give him a search and see what he says Thumbs Up
Any links to videos you've done?
Bendy
Mrs Sensible
PostPosted: 13:45 - 26 Sep 2008    Post subject: Reply with quote
OK - if you're going DV cam you're looking for something like this.
AV in socket (note, most cameras will have a socket marked AV but that's usually just AV out). That's the one with the black lead going into it.
Red white and yellow... yellow is video, red and white are audio. On your setup it looks like only white is free, that's fine - use that. Pretty sure mine only used one of the audio plugs too.
If you want to borrow my camera for a play with, feel free. It's been sat in a box for at least a year since the bulletcam died in the line of duty. Pretty sure the DV cam still works. Laughing
Graham88
PostPosted: 13:59 - 26 Sep 2008    Post subject: Reply with quote
I'd snap your arm off for that offer, but you're in Berkshire Sad
I collected a few things from there last week too, gay!
Looks pretty easy to figure out really, it's just confusing without having it infront of me.
Would you be able to find the cable I'd need on eBay please? I'm not sure what it's called!
And I presume this cable you're talking about is the last thing I'd need, besides the camcorder itself (which I need to have an AV input for bulletcam, I get that now)
Bendy
Mrs Sensible
PostPosted: 14:24 - 26 Sep 2008    Post subject: Reply with quote
Gutted, must be a whole hour's ride. Laughing
Most suitable cameras will come with that lead included so I wouldn't worry about it just yet.
Hetzer
PostPosted: 14:27 - 26 Sep 2008    Post subject: Reply with quote
Here's one of them:
https://uk.youtube.com/watch?v=_vheDleuaB4
PC and Youtube compression ruined the quality.
Graham88
PostPosted: 15:03 - 26 Sep 2008    Post subject: Reply with quote
Hmmm how long before you'd be wanting it back? Very Happy
OK cool Thumbs Up
Thanks Hetzer, looks good and that's even with YouTube compressing the quality, £500 big ones is alot on a camera that I don't know if it would get used all that much to warrant it. I just wanted to try and get a few cool videos!
Bendy
Mrs Sensible
PostPosted: 15:07 - 26 Sep 2008    Post subject: Reply with quote
No particular hurry.
I'm just charging it up just to make sure it's all still working, it's been sat since about 2006 I think. Embarassed
Graham88
PostPosted: 15:15 - 26 Sep 2008    Post subject: Reply with quote
I work in Acton, London, so not too far out my way if it works and it's ok with you. Very Happy
Bendy
Mrs Sensible
PostPosted: 15:25 - 26 Sep 2008    Post subject: Reply with quote
Graham88 wrote:
I work in Acton
You have my sympathy.
Graham88
PostPosted: 15:26 - 26 Sep 2008    Post subject: Reply with quote
It's not that bad, plus I'm not there for long before I travel off somewhere else, that's just the depot.
PostPosted: 17:43 - 26 Sep 2008    Post subject: Reply with quote
I like my Archos A405.
The bullet cam you get with it isn't amazing, but it does have only one wire (powered from unit) and has an in-line 'remote' control for stopping and starting.
Records to SDHC cards.
By adding an extra battery pack (I made one up with AA batteries), you can probably get 12 hours constant filming or something.
I'm tempted to chop the camera off so I stick a better one on the end (after the remote), maybe with a plug arrangement, so you can move them around.
Personally, I wouldn't spend a lot on a bullet camera system now until HD bullet cameras start appearing; though that'll be a bit of time and of course not much better if you're just going to upload to youtube!
An example of (not very compressed) footage:
https://blip.tv/file/975036
(If it doesn't work, click 'download playing' at the bottom, I did something odd with it when editing, I believe.)
rotax81
PostPosted: 18:07 - 26 Sep 2008    Post subject: Reply with quote
i use an atc2000 that has been highly modified by me Very Happy
the mic is under the rear tail piece just above the exhaust.
it runs at 30FPS and a 2gb sd card lasts 80 mins on medium quality.
below is a link to youtube from rockingham in august.
the odd late braking didn't come with the camera Laughing
click on 'watch in high quality' below the box. note that youtube destroys image quality but you can get idea.
video whoring time lol
https://www.youtube.com/watch?v=ZPOANzaTWN8
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
PostPosted: 18:09 - 26 Sep 2008    Post subject: Reply with quote
ATCs do seem to be very variable in quality. Yours isn't nearly as bad as mine, but still does seem to have a little bit of the wobblyness.
There's a 'ATC3k' version out now too I believe, takes SDHC maybe? But not much else new.
If you're happy with the quality, it's definitely worth a look.
rotax81
PostPosted: 18:14 - 26 Sep 2008    Post subject: Reply with quote
the ATC needs to be mounted quite firm but must have a little bit of movment.
i had no end of reliability probs with it at first but gutted it and rebuilt it properl. they are very 'chinese quality' inside.
Lone-Wolf
PostPosted: 18:41 - 26 Sep 2008    Post subject: Reply with quote
Hetzer wrote:
I dealt with Dogcam (Mark I think) and he provided sterling service. :
Wotcha.
I had all my gear from Dogcam - as you say, can't fault 'em.
The results are like this - The coast road towards Freshwater on the Isle of Wight - running at about twice the speed.
Cheers.
L.W. - www.moonshiners.org.uk
Graham88
PostPosted: 19:53 - 26 Sep 2008    Post subject: Reply with quote
Both those videos posted look fine for what I want it for. I'm not looking for the type of quality you can see dirt on the road just not laggy etc.
This one boasts 8 hours filming, which is more than enough! I just like the fact how small the cam is. There are some sucker mounts on eBay, not sure if I can trust that if I'm doing high speeds..
rotax81
PostPosted: 20:01 - 26 Sep 2008    Post subject: Reply with quote
my mate uses the suckers from ebay and they are fine. he does put a bit of ducktape over it though for good measure Wink
i use a mount i made myself thats bolted to the fuel cap housing.
in the pic below Thumbs Up
https://i171.photobucket.com/albums/u282/rotax81/636c.jpg
The last post was made 18 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 131.59 Kb
