Engine braking
Gary SuperSprint
PostPosted: 18:09 - 29 Sep 2008    Post subject: Engine braking Reply with quote
Hi all, In my cbt the instructer told me for the emergency stop that i didn't need to use engine braking for the cbt only for bike test when i do that. Is it quicker to stop a bike with engine braking aswell? Thanks.
honda cub 90 (stolen), Honda nsr 125 2001 (stolen), present : fully restored honda ns 125 f 1989. Current project, susuki rf600.
Jai466
PostPosted: 18:14 - 29 Sep 2008    Post subject: Reply with quote
it will give you more control of the bike as you will slow down with engine brake...
I awalys use engine braking wen I can carefully not to lock the back wheel... as then comming to a slow you more slow and safe to stop other than stopping at a much faster speed. Also it mean that you planning ahead which is always good...
Wise1
PostPosted: 18:17 - 29 Sep 2008    Post subject: Reply with quote
For the Emergency stop the name of the game i stop as quickly and safely as possible. In order to do that you use the brakes and brakes only. Pull the clutch in at the last moment to prevent locking up.
You should not attempt to come down gears and use the engine as a brake, it will take too long and apart from anything be considered a major (fail).
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
Whosthedaddy
PostPosted: 18:19 - 29 Sep 2008    Post subject: Reply with quote
Slowing down all the time with no stop lights will earn you a fair few minors on the test.
By easing of the gas completely is the only way of using the engine to slow the bike. Yes you should do this if possible in the E stop as you'll be rev happy at a standstill in the middle of the road. Grabbing and pumping a fistfull of brakes is prefered method of stopping in an emergency.
Jai466
oppss sorry mate maybe I was wrong...
I was told in mt CBT to use engine brakeing?
Wise1
PostPosted: 18:29 - 29 Sep 2008    Post subject: Reply with quote
Coming down gears and using the engine as a brake will fail you on test. The process for the E stop is:
In dry conditions
Throttle off
Apply front brake lightly and progressively
Apply Back brake
Clutch in just before you stop
Obs - Look left and right
paddle bike into side of road
Into Nuetral
Wait for further instructions from examiner
Obviously varies slightly depending on road conditions.
Jai466
PostPosted: 18:30 - 29 Sep 2008    Post subject: Reply with quote
How about when not comming to a E stop like stopping at the traffic lights?
ajb
PostPosted: 18:35 - 29 Sep 2008    Post subject: Reply with quote
If you see a red light, or the light is green and you have anticipated it going red, don't accelerate upto it and brake, ease off the throttle and slow gently, tap the rear brake a bit if you feel you need to display a brake light to following vehicles. Clutch in and down through the gears a few metres before you stop, as you get more experience, you'll go through the gears more naturally. (like if youre in 4th, you'll go down progressively, until maybe second then tap down into first the last couple metres.
CBR125R '05 > CB500 '00 > CBR600F '99
Wise1
PostPosted: 19:21 - 29 Sep 2008    Post subject: Reply with quote
Its always best to use the engine as a brake when coming up to traffic lights by coming down the gears. Of course a light touch of the back will warn those behind that your slowing.
Last thing you want to do is stop at lights in 4th and just as they are going to green your fumbling about trying to find 1st.
edit - as AJB said Thumbs Up
The Disapproving Brit
PostPosted: 03:36 - 01 Oct 2008    Post subject: Reply with quote
On a slight tangent, is it acceptable to stall during an E-stop on the test?
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
Moonie
PostPosted: 06:51 - 01 Oct 2008    Post subject: Reply with quote
No, you have to keep the bike running.
And make sure if you do engine brake to only click it into first at the last minuite or the back will lock up.
Wise1
PostPosted: 08:53 - 01 Oct 2008    Post subject: Reply with quote
Its a minor if you stall the engine, but better a minor and stall it than a major and lock it up.
Mudskipper
PostPosted: 09:32 - 01 Oct 2008    Post subject: Reply with quote
No, you don't.
blindside666
PostPosted: 09:45 - 01 Oct 2008    Post subject: Reply with quote
I failed my test this morning on one thing and one thing only, emergancy stop. I came around and as I did it, the back wheel locked up. Did U-Turns and all perfectly well, just cocked up the emergancy stop.
Now locking the back wheel is NOT the end of the world if it comes to that. I was told afterwards that if I would have released the back brake and controlled the bike to a stop I would have passed!
In my test he asked me to ride around the block then come up to an emergancy stop, my mother did her test recently and just admitted she slowed down slightly from 30 to about 23-25mph as she knew it was coming. Then as said above, on with the front brake, then back, clutch at the last moment, then sort out obs and gears and such. Stopping without locking is the key.
On another note, I got two minor marks for gears on my test, stupid mistakes! I pulled up to the roundabout and for reasons I cannot quite fathom, stopped in 3rd. My bike was being a bitch, did NOT want to go down, I got it into 2nd, saw the examiner getting impatient and thought f**k it and set off. Always best to be in 1st or neutral if your stopped!
Anyway I'm going to take the test again... and get it right this time!
Current Bike: Lifan GY125
CBT: 15th June 2008
A2 Passed: 16th October 2008
MattHirst
PostPosted: 10:37 - 01 Oct 2008    Post subject: Reply with quote
Come back when you have passed your test and you what your talking about.
It took me 3 attempts to pass my test (failed 2 times on the u-turn) and on 2 occasions i stalled in the emergancy stop (including the test that i passed)
It also isn't a minor if you stall, but you will get penalized (not sure if its a minor or a major) if you start the bike in gear and move off without the correct obs. That goes for at a junction, e-stop or anything.
Like in your car test, if you stall you have to put handbrake on and put it into neutral before you start it again, leaving it in gear or using the foot brake will mean you fail.
Kal
PostPosted: 10:53 - 01 Oct 2008    Post subject: Reply with quote
The test is to stop the bike, quickly and efficently while under control - just for reference it is now called a Controlled Stop.
If you stall out, you stall out - however if you do everything you should do you shouldn't
Front Brake
Rear Brake
Clutch
IF the back end starts to break away then take your foot off and progressively reapply.
and then when you are at a halt block change down to first so you are ready to move off as the examiner directs you.
I had the rear break away during mine on wet/greasy road and I did as I advise above to control the stop. Passed no problem.
On a side note, confirm where the brake signal comes on - my rear brake won't signal until I am actually braking, however the front lever lights up the rear before it takes effect.
Kal...
Whosthedaddy
PostPosted: 12:05 - 01 Oct 2008    Post subject: Reply with quote
Mudskipper wrote:
No, you don't.
If you do stall then so what as long as you stop cleanly and promptly.
After the manoeuvre you have to do a life saver both ways and paddle the bike to the side anyway.
Moonie
PostPosted: 13:15 - 01 Oct 2008    Post subject: Reply with quote
CBT instructor said that you had to keep it running.
Meh.
Kal
PostPosted: 13:20 - 01 Oct 2008    Post subject: Reply with quote
It's good practise to have the engine running, but it isn't essential
Kal...
PostPosted: 16:20 - 01 Oct 2008    Post subject: Reply with quote
My CBT instructor said that the reason you paddle to the side is precisely because you could have stalled it, and you need to get somewhere safe before attempting to pull off again. I'm pretty sure he mentioned that it was different for scooters, since they didn't stall, but I wasn't actually paying a lot of attention to the scooter-specific stuff.
Whosthedaddy
PostPosted: 16:27 - 01 Oct 2008    Post subject: Reply with quote
As you E stop in 3rd or 4th, even if you haven't stalled you'd have to try and stamp through the gears to be able to pull away to the side of the road so paddling is quicker and the safer route.
The last post was made 17 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 114.79 Kb
