not sparking with s/motor,only when running????anbody help
grez
PostPosted: 14:27 - 05 Oct 2008    Post subject: not sparking with s/motor,only when running????anbody help Reply with quote
my rg 125 f willl no longer spark when being turnd by startermotor,but runs when bumped,can anybody please help,its just had an engine rebuild but no electrics were touched,i dont know were to start????????
iooi
PostPosted: 16:52 - 05 Oct 2008    Post subject: Reply with quote
Charging the battery might help.
What does it read volt wise with engine running and not running.
grez
PostPosted: 19:53 - 05 Oct 2008    Post subject: Reply with quote
thanx for reply,battery is new and fully charged
test the volts?do you mean test the battery under a load??
bladerunner
PostPosted: 07:55 - 06 Oct 2008    Post subject: Reply with quote
Do you have an after market alarm/immobiliser? If not it does hint that under the load of powering the starter motor not enough voltage to power the cdi. Put a meter on the battery to see what voltage it reads when it's spinning the starter motor and post it up here.
iooi
PostPosted: 17:31 - 06 Oct 2008    Post subject: Reply with quote
Read off the volts with nothing running and then read them off again with the engine running.
Also as above see how much they drop when cranking.
grez
PostPosted: 18:15 - 06 Oct 2008    Post subject: Reply with quote
tested it today,it is at 12 v,and at 14v when running.i dont own a voltage tester so i cannot check how much it drops when using starter motor untill tommorow.soon as i know i will let you know,thanx
grez
PostPosted: 13:51 - 08 Oct 2008    Post subject: Reply with quote
my mate had a spear battery,so we charged it,put it on,problem solved.my battery was 10 days old from ebay,so watch what you buy from ebay.thanx for replys,i would have still had problems now without them Smile
bladerunner
PostPosted: 18:45 - 08 Oct 2008    Post subject: Reply with quote
glad to hear you got it sorted!! Very Happy
The last post was made 17 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 54.47 Kb
