Quick Replys Please!! rs 50 - How To Fit The Crank !!!!!!!!
Hutchysrs50
PostPosted: 17:42 - 07 Oct 2008    Post subject: Quick Replys Please!! rs 50 - How To Fit The Crank !!!!!!!! Reply with quote
Right, i have fitted new bearings and have bought a new crank
the parts are BOTH Correct and are the same as the old ones.
The Crank Just WONT GO IN!!! it slides in untill it gets to about 10mm from the webbing to the case.
i have been hitting it with a big hammer and it wont budge... iv had it in the oven cooking away with no differnce!!
Is there a Special way to fit them and im doing it wrong??? or is it just tight with them both being new.
How do i get it in!!
Gilera SC 125 - Current
prawny1
PostPosted: 17:53 - 07 Oct 2008    Post subject: Reply with quote
Don't put the crank in the oven it will expand and deffo not fit in the bearing, try some two stroke oil on the crank and as you try fitting it jiggle it a bit as you push down,the bearing is a tightish fit on the crank but should fit without too much effort, changes are you didn't have the crank dead in line with the bearing so it would not drop into place properly.
If your still having trouble then try lowering the case onto the crank and using a tube tap the cetre of the bearing onto the crank, make sure the threads are well protected as they can be easily damaged rendering your new carank useless.
rotax81
PostPosted: 18:14 - 07 Oct 2008    Post subject: Reply with quote
as above but be warned.
check the crank spins freely because it is very easy to put sideways strain on the bearings rendering them useless in no time.
the last ones i did on a KX80 were a right pig to get right.
if in doubt, take it somewhere like an MX workshop/ decent bike shop as they will be used to it.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
Hutchysrs50
PostPosted: 21:32 - 07 Oct 2008    Post subject: Reply with quote
thanks.
a smash hammer and abit 2 stroke did the job.
the bike is started and runs perfect fine!!!!!!!
booking it in for its MOT on Saturday so i should be on the roads by sunday! Very Happy
dont think anything els can go wrong... its like a brand new engine now.... looks like im gona be riding slow for a while yet.
rezzin
PostPosted: 09:58 - 08 Oct 2008    Post subject: Reply with quote
Put it in a air tight bag in the freezer for about a day or two. Heating the crank will make it bigger you plonk. Freezing it will make it smaller. This is what all the ped tuners do anyway. Thumbs Up
rezzin
Also heat where your fitting the crank,as this will make it bigger,but be careful to not damage anything.
Hutchysrs50
PostPosted: 18:43 - 08 Oct 2008    Post subject: Reply with quote
i put the the engine in the oven, not the crank Smile
lol
iv got the engine all done now, its running perfectly Very Happy
some good advice Karma
Thanks anyway Smile
The last post was made 17 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 51.98 Kb
