would this be useful to have?
cicatrez
PostPosted: 22:21 - 08 Oct 2008    Post subject: would this be useful to have? Reply with quote
Sorry if its been posted before or anything (i've no idea).
https://www.maplin.co.uk/Module.aspx?ModuleNo=47715
Could be useful for keeping one warm as winters coming. I wonder how warm it would get. Maybe one of you lot could buy one and give feedback on the rest of us. Prob would be cheaper then spending tons on a heated leather jacket or what not.
opinions?
Matthie
PostPosted: 22:56 - 08 Oct 2008    Post subject: Reply with quote
6xAA batteries Confused
I'd say it either wont get very hot or will rape the batteries.
cicatrez
PostPosted: 23:00 - 08 Oct 2008    Post subject: Reply with quote
mmm i suppose. it said if used constantly on it only lasts 50minutes or so. Would be major suckage if it wasn't warm.
Has no1 invented a hot water bottle type jacket? I would have thought someone would have given it a go.
yambabe
PostPosted: 23:19 - 08 Oct 2008    Post subject: Reply with quote
I use Little Hotties tucked inside my clothes or socks sometimes, they help a lot.
smegballs
PostPosted: 23:23 - 08 Oct 2008    Post subject: Reply with quote
maybe wire it to a ciggy lighter socket on the bike??
I know the voltage would be out
6 X 1.5V (AA battery) = 8V
but maybe on a timer so on for 5 off for 10 mins say
assuming you can get past voltage problem.....
Rich
cicatrez
PostPosted: 23:25 - 08 Oct 2008    Post subject: Reply with quote
Are those them little plastic sealed pouches which as a tiny area u press, and the gel inside it changes, and gets hot. Then to reverse it, you put it under boiling water?
yambabe
PostPosted: 23:29 - 08 Oct 2008    Post subject: Reply with quote
Nope, they look and feel like a giant teabag!
They start to get warm as soon as they come out of the plastic wrapper, and once you're done with them you just chuck them away.
Also useful for camping, a couple in the sleeping bag will help keep you toasty all night.
Visitor Q
$25 whore
PostPosted: 00:37 - 09 Oct 2008    Post subject: Reply with quote
Why not get the proper hand coolers that work by supercooling. You ping the metal disc floating about and it 'freezes' solid, releasing cock loads of heat.
Then you just put in a saucepan for a bit and they go back to normal.
Incredible really.
Phoenix
Twisted Firestarter
PostPosted: 01:58 - 09 Oct 2008    Post subject: Reply with quote
Rich
More like 9v, assuming the batteries are all in series, would imagine you'd need at least 9v for a heating element though so makes sense that way. I wouldn't hardwire it to any power source as it doesnt sound like the jacket is designed for constant heating, the wire elements would burn out, wrecking the jacket and possibly causing a small fire Laughing
A timer might be ok, but you'd need either a transformer or a large load resistor to bring the voltage from 12-9, personally i'd just buy a bike specific heated waistcoat.
Reppyboyo
PostPosted: 03:53 - 09 Oct 2008    Post subject: Reply with quote
Only one I know what is good is the Stormrider vest.
PostPosted: 05:22 - 09 Oct 2008    Post subject: Reply with quote
I mainly ride at night/early mainly between 10:30pm - 7:30am, most lot must be pussies Laughing I currently ride with a winter jacket with the lining removed and a T-Shirt + textile bottoms. Thats fine for me, you lot need to man the fuck up Laughing
Itchy
PostPosted: 07:01 - 09 Oct 2008    Post subject: Reply with quote
This comes up virtually every year this will not work! ,, it is designed to be put on for 2 -3 minutes to warm up then turned off.... to make it work for a bike you will need to wire it into your battery..
As even if you do warm it up and turn it off it will be utterly no match for the wind chill of the erm wind...
yambabe
PostPosted: 08:06 - 09 Oct 2008    Post subject: Reply with quote
Incredible really.
Got some of those too but they are bulkier and harder to slip into a glove, boot or pocket comfortably. Once you've pressed the little metal button and they have crystallised they go rock hard, no flexibility at all. Not too bad if it's just tucked down your tshirt but I tend to put the Hotties in the sleeves of my jacket for example, and the liquid/crystal ones dig in! In boots you can't walk without removing them once you are off the bike and in gloves I've yet to find any that are small enough to fit.
The Hotties really are like a big teabag, they are about 3" long by about 2" wide, made of soft material (but you can't put them directly on your skin cos they would be hot enough to burn) and the inside is kind of like a beanbag so they sort of mould to whichever body part they are near and they stay flexible. I've also found that the heat lasts longer than the liquid/crystal ones. Thumbs Up
Davie_G71
PostPosted: 08:15 - 09 Oct 2008    Post subject: Reply with quote
I must say, this is the way i ride too. Either get a better winter jacket, or war a jumper?
Visitor Q
$25 whore
PostPosted: 09:06 - 09 Oct 2008    Post subject: Reply with quote
Yeh true Babyyam, just seemed a bit wasteful. Also, how many do you use of these things Shocked I bet when you come in from a long enough ride (for them to have worn off) you forget where they all are lol.
Oh and yeh I agree, unless its more thne about 10 miles you really should be able to get away with jeans and jacket for 99% of rides anyway.
That said, I wish I had something to warm me back up 'emergency stylee' when I rode down to east sussex wearing summer gloves and leathers... in the snow.
PostPosted: 09:14 - 09 Oct 2008    Post subject: Reply with quote
Charlotte uses the hotties things as well. They last far longer than the type you describe (we have those as well, work well for about 30 minutes), and can be saved (put them in a sealed zip lock bag and you stop the reaction, take them out at a later date and they start up again).
yambabe
PostPosted: 09:24 - 09 Oct 2008    Post subject: Reply with quote
I never thought of that keith, will give it a go!
TBH I only tend to use them if I know I'm going to be out and going fairly briskly for more than about an hour.
But Bonny yeah, I have had them in my textile jacket (they slip into the armour pockets quite nicely) and then found "used" ones several months later whan I've gone to put a new one in Embarassed
We got a box of 80 at least 2 years ago, and between the 2 of us we've used less than half of them so far.
The last post was made 17 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 99.2 Kb
