NSR 125 OVERHEATING!! GEAR PROBLEMS
badman_rich
PostPosted: 18:30 - 11 Oct 2008    Post subject: NSR 125 OVERHEATING!! GEAR PROBLEMS Reply with quote
right basically my nsr has got the temperature gauge on it..
for some reason its going up alot whenever im suck in traffic.. its only going up half way but i cant understand it because it never used to go up atal ! is there a reason for this??
also im finding that i cant flick my gears into neutral and that the gears have become pretty stiff.
HELPP PLEASE.
NSR 125 Very Happy
Finglonga
PostPosted: 18:36 - 11 Oct 2008    Post subject: Reply with quote
Sender was probably faulty and is now working if it's only going up half way.
Clean the linkage on the gear selector and re grease it to see if it helps. Is your clutch adjusted properly?
Andy Sez....
F.Y.Y.F.F.
badman_rich
PostPosted: 18:59 - 11 Oct 2008    Post subject: Reply with quote
where bouts would the linkage be??
yeh il re-grease it.. wots the best stuff to use?
NSR 125 Very Happy
rotax81
PostPosted: 14:08 - 12 Oct 2008    Post subject: Reply with quote
sounds like the clutch is dragging as said. as for the temp gauge, just keep an eye on it and make sure your rad is not covered in crap at the front. not familiar with your bike but if it has a fan, check to see if it comes on.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
alains
PostPosted: 16:10 - 12 Oct 2008    Post subject: Reply with quote
when the temp go to the middle it could be 3 causses :
- thermostat inside de head pipe is malfunctioning *
- cylinder head gasket starting to worn
- water pump has a problem
if the neutral is hard to find it's mostly because the engine warm too much . test it when engine is cold , i think you wont find the same problem
* this is easy to test :
- drain cooling liquid
- undo the 2 nuts and take off the pipe (the thermostat is inside)
- drop the thermostat in a pan with water and warm it
- just before the water start to bubble , the thermostat must be open
badman_rich
PostPosted: 19:07 - 12 Oct 2008    Post subject: Reply with quote
i havnt got a clue where all the problems to the bike overheating could be.. but could it cost me alot???
as for the gears is it easy to fix?
NSR 125 Very Happy
badman_rich
PostPosted: 19:10 - 12 Oct 2008    Post subject: Reply with quote
BTW when the bike is turned off i can slip the gear into neutral
NSR 125 Very Happy
badman_rich
PostPosted: 19:20 - 12 Oct 2008    Post subject: Reply with quote
could it be that i need coolent also?
NSR 125 Very Happy
Hutchysrs50
PostPosted: 20:21 - 12 Oct 2008    Post subject: Reply with quote
ok i asume neutral is half a click up from 1st....
put it in first gear, pushup very slightly with the clutch fully in and roll the bike farward while still pushing up with your left foot.
if it goes into neutral fine, your clutch just neds adjusting.
if you dont understand that, let me know. Very Happy
hope this helps!
Gilera SC 125 - Current
badman_rich
PostPosted: 20:37 - 12 Oct 2008    Post subject: Reply with quote
when u say push up what do u mean??
could the engine need coolent?
NSR 125 Very Happy
badman_rich
PostPosted: 20:38 - 12 Oct 2008    Post subject: Reply with quote
also does the bike need to be turned fully on?
NSR 125 Very Happy
Hutchysrs50
PostPosted: 20:48 - 12 Oct 2008    Post subject: Reply with quote
Hey..
yes, Start the bike and let it warm up.
get on the bike and put it into first gear like normal.
keep the clutch in fully and roll the bike forward slowly
while the bike is rolling, try and put it into neutral like normal.
just makesure the clutch is fully in and the bike and rolling a little.
badman_rich
PostPosted: 21:09 - 12 Oct 2008    Post subject: Reply with quote
ok i will
what if this doesnt work?
NSR 125 Very Happy
Hutchysrs50
PostPosted: 21:15 - 12 Oct 2008    Post subject: Reply with quote
if you cant get it into neutral when the bike is running....
that could be down to the wrong oil making the plates stick?
running low on oil?
clutch screws being to soft?
snapped clutch cable Laughing
bad set up of the clutch?
have you rebuilt the engine or changed anything?
have you checked your oil level?
also have you checked you have enough collant in?
badman_rich
PostPosted: 21:32 - 12 Oct 2008    Post subject: Reply with quote
i have not rebuilt the engine atal.
to be honest im useless on bikes lol.. i did run really low on oil but then i toped it up!!
is flicks into neutral wen the bikes not on which is odd!!
i recently got the brake pads changed, also i did fall off the bike bout 2 months ago so it couldn't be that i dont fink.
where would the coolant be?? like where could i find out if i need to fill it up?
what coolant would i need is there a special coolant for bikes? could this sort out my overheating problem also?
with the overheating it only goes up half way but no where near the red, thats when im stuck in traffic, but when i was flowing it went straight back down. ive only just noticed this temperature gauge working as it always stayed in the same place pretty much intill a month ago!
NSR 125 Very Happy
Hutchysrs50
PostPosted: 21:46 - 12 Oct 2008    Post subject: Reply with quote
the bike doesnt goes into neutral when the bike is running because the gears havnt steopping spinning making the bike jump from 1st gear to 2nd gear (2nd to 1st if you wona be fussy Confused )
thats why if you roll the bike farward while trying to put it itno neutral it shout go in alot easyer!
I think you have a honda nsr 125?
you will need to take the fairings off from 1 side of the bike, take the radiator cap off and just put some normal tap water in, but over time tap water will rust up, so you can mix water and some sort of anti-freeze or somthing of the type 50 / 50 whenever you can get hold of some.
just let me know if you dont understand anything Very Happy
badman_rich
PostPosted: 21:50 - 12 Oct 2008    Post subject: Reply with quote
o i get you on the gears!!! i understand now LOL
sorry im new to this.
with the coolant would this help with the bike overheating situation or do you think it could be normal for this to happen??
would the coolant be the same as what you can put in a car or is it different
NSR 125 Very Happy
Hutchysrs50
PostPosted: 21:55 - 12 Oct 2008    Post subject: Reply with quote
well, i guess its normal yes, the faster you go, the faster the water pump spins, and the more wind your getting making it cooler.
i think its still worth checking to see if your low, just nd case..
and yes, i use the same anti-freeze and water from my dads ford transit van Laughing
badman_rich
PostPosted: 22:05 - 12 Oct 2008    Post subject: Reply with quote
sweet lol thanks for all this info mate Very Happy
il mix the anti freeze with water.
NSR 125 Very Happy
Hutchysrs50
PostPosted: 22:08 - 12 Oct 2008    Post subject: Reply with quote
no problem.
the recommended mix is 50% water 50% antifreeze
mines more 90% water and 10% anti-freeze, but that is just because my dad put most of it in his van Laughing lol
as you have said you are new.... so pm me if you dont understand what people have said or have any more problems tomorrow!
Good luck! Mr. Green
The last post was made 18 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 109.96 Kb
