| badman_rich |
 badman_rich Borekit Bruiser
 Posted: 18:30 - 11 Oct 2008 Post subject: NSR 125 OVERHEATING!! GEAR PROBLEMS |
right basically my nsr has got the temperature gauge on it..
for some reason its going up alot whenever im suck in traffic.. its only going up half way but i cant understand it because it never used to go up atal ! is there a reason for this??
also im finding that i cant flick my gears into neutral and that the gears have become pretty stiff.
HELPP PLEASE. ____________________ NSR 125  |
| Finglonga |
 Finglonga World Chat Champion
| badman_rich |
 Posted: 18:59 - 11 Oct 2008 Post subject: |
where bouts would the linkage be??
yeh il re-grease it.. wots the best stuff to use? ____________________ NSR 125  |
| Vincent |
 Vincent Banned
| rotax81 |
 rotax81 Nearly there...
| alains |
 alains World Chat Champion
| badman_rich |
 Posted: 19:07 - 12 Oct 2008 Post subject: |
i havnt got a clue where all the problems to the bike overheating could be.. but could it cost me alot???
as for the gears is it easy to fix? ____________________ NSR 125  |
| badman_rich |
 Posted: 19:10 - 12 Oct 2008 Post subject: |
BTW when the bike is turned off i can slip the gear into neutral ____________________ NSR 125  |
| badman_rich |
 Posted: 19:20 - 12 Oct 2008 Post subject: |
could it be that i need coolent also? ____________________ NSR 125  |
| Hutchysrs50 |
 Hutchysrs50 World Chat Champion
 Posted: 20:21 - 12 Oct 2008 Post subject: |
ok i asume neutral is half a click up from 1st....
put it in first gear, pushup very slightly with the clutch fully in and roll the bike farward while still pushing up with your left foot.
if it goes into neutral fine, your clutch just neds adjusting.
if you dont understand that, let me know.
hope this helps! ____________________ Gilera SC 125 - Current |
| badman_rich |
 Posted: 20:37 - 12 Oct 2008 Post subject: |
when u say push up what do u mean??
could the engine need coolent? ____________________ NSR 125  |
| badman_rich |
 Posted: 20:38 - 12 Oct 2008 Post subject: |
also does the bike need to be turned fully on? ____________________ NSR 125  |
| Hutchysrs50 |
| badman_rich |
 Posted: 21:09 - 12 Oct 2008 Post subject: |
ok i will
what if this doesnt work? ____________________ NSR 125  |
| Hutchysrs50 |
 Posted: 21:15 - 12 Oct 2008 Post subject: |
if you cant get it into neutral when the bike is running....
that could be down to the wrong oil making the plates stick?
running low on oil?
clutch screws being to soft?
snapped clutch cable
bad set up of the clutch?
have you rebuilt the engine or changed anything?
have you checked your oil level?
also have you checked you have enough collant in? ____________________ Gilera SC 125 - Current |
| badman_rich |
 Posted: 21:32 - 12 Oct 2008 Post subject: |
i have not rebuilt the engine atal.
to be honest im useless on bikes lol.. i did run really low on oil but then i toped it up!!
is flicks into neutral wen the bikes not on which is odd!!
i recently got the brake pads changed, also i did fall off the bike bout 2 months ago so it couldn't be that i dont fink.
where would the coolant be?? like where could i find out if i need to fill it up?
what coolant would i need is there a special coolant for bikes? could this sort out my overheating problem also?
with the overheating it only goes up half way but no where near the red, thats when im stuck in traffic, but when i was flowing it went straight back down. ive only just noticed this temperature gauge working as it always stayed in the same place pretty much intill a month ago! ____________________ NSR 125  |
| Hutchysrs50 |
 Posted: 21:46 - 12 Oct 2008 Post subject: |
the bike doesnt goes into neutral when the bike is running because the gears havnt steopping spinning making the bike jump from 1st gear to 2nd gear (2nd to 1st if you wona be fussy )
thats why if you roll the bike farward while trying to put it itno neutral it shout go in alot easyer!
I think you have a honda nsr 125?
you will need to take the fairings off from 1 side of the bike, take the radiator cap off and just put some normal tap water in, but over time tap water will rust up, so you can mix water and some sort of anti-freeze or somthing of the type 50 / 50 whenever you can get hold of some.
just let me know if you dont understand anything  ____________________ Gilera SC 125 - Current |
| badman_rich |
 Posted: 21:50 - 12 Oct 2008 Post subject: |
o i get you on the gears!!! i understand now LOL
sorry im new to this.
with the coolant would this help with the bike overheating situation or do you think it could be normal for this to happen??
would the coolant be the same as what you can put in a car or is it different ____________________ NSR 125  |
| Hutchysrs50 |
 Posted: 21:55 - 12 Oct 2008 Post subject: |
well, i guess its normal yes, the faster you go, the faster the water pump spins, and the more wind your getting making it cooler.
i think its still worth checking to see if your low, just nd case..
and yes, i use the same anti-freeze and water from my dads ford transit van  ____________________ Gilera SC 125 - Current |
| badman_rich |
 Posted: 22:05 - 12 Oct 2008 Post subject: |
sweet lol thanks for all this info mate
il mix the anti freeze with water. ____________________ NSR 125  |
| Hutchysrs50 |
 Posted: 22:08 - 12 Oct 2008 Post subject: |
no problem.
the recommended mix is 50% water 50% antifreeze
mines more 90% water and 10% anti-freeze, but that is just because my dad put most of it in his van lol
as you have said you are new.... so pm me if you dont understand what people have said or have any more problems tomorrow!
Good luck!  ____________________ Gilera SC 125 - Current |
The last post was made 18 years, 12 days ago. Instead of replying here, would creating a new thread be more useful? |
