Cornering advice please
rhone81
PostPosted: 23:42 - 13 Oct 2008    Post subject: Cornering advice please Reply with quote
I did my first track day at the weekend and will be doing another one at Knockhill on the 25th. I wanted to ask for advice from some of the experienced track riders about my body position through corners. I seem to be able to lean the R6 far enough but feel very wooden when doing so and am not really leaning into the corners. I've attached some photos to give you an idea:
https://www.urbanracing.net/bike/knockhill3/DSC_3457.JPG
https://www.urbanracing.net/bike/knockhill3/DSC_3477.JPG
https://www.urbanracing.net/bike/knockhill3/DSC_2958.JPG
Cheers,
Graeme
PostPosted: 05:29 - 14 Oct 2008    Post subject: Re: Cornering advice please Reply with quote
Keep an eye on your chicken strips I think it is good to see how much tire you have less plus the more you lean you can actually see them disappearing and it give a target.
As for body position move you head closer to your mirror and wiggle an arse cheek off the sofa.
TBH the way I leant to corner quicker to start with was becaue I flew into a few corners to fast for my comfort zone and realised realistically there was no drama the bike handled it fine.
PostPosted: 05:38 - 14 Oct 2008    Post subject: Reply with quote
2 words.
Hang off.
garth
PostPosted: 07:50 - 14 Oct 2008    Post subject: Reply with quote
If your forearm isn't touching the top of the tank, you can still lean off further. Your head is heavy - get it on the inside of the bike and close to the ground to lower your COG.
jay12329
Dr. Evil
PostPosted: 10:09 - 14 Oct 2008    Post subject: Reply with quote
Move your head and try and kiss your reflection in your mirror. That moves your head and shoulders down and out in the right sort of zone.
HTH
J
flossi46
PostPosted: 11:03 - 14 Oct 2008    Post subject: Reply with quote
Rolling Eyes of course you wasn't trying luke! the person with the camera was just there by chance eh....... Laughing and greame, learn the corners 1st, then you can hang off more each time as you get confident, believe me its hillarious watching some of them hurl into the bend, hung off vale style, and then they realise it cant work.ooops!
Very Happy smile.................and everyone wonders what you've been up to Very Happy
2011 is a ROSSI year
PostPosted: 12:06 - 14 Oct 2008    Post subject: Reply with quote
If it's 'feel' you're after; then moving your upper body off can help quite a bit - aim your head and shoulder towards the corners.
Hanging off more will allow bigger lean angles, but judging by the pics you should be able to lean more as is.
As above, have a look at your lines too - apex's are there to be hit Smile.
Deano
PostPosted: 12:17 - 14 Oct 2008    Post subject: Reply with quote
i would say foot postion and body position needs changing from those pictures.
when you at the apex and ready to turn in you wanna be finished with your braking etc and the only thing you wanna be concerned with is leaning over and then thinking about when your gonna be applying the power, which should be at or just after the mid-apex of the corner.
I would try putting your balm of you toes on the inside peg and on a tiptoe stance, aim your knee for the corner(apex), you dont need to hang off the bike like LUKE, shuffling your arse from left to right like that will cause the bike to unsettle and may cause your bike to wobble lots which wont help. the only time you need alot of hangin off is highspeed big lean corners to help keep the bike planted. slide your bum over a bit but sometimes your bum wont want to move due to the leather sticking to the seat so dont focus too much about this if it happens it not mega crucial.
If you find you lean over and the pegs start to scrape the floor which does happen easily enough on standard pegs then starting putting the balm of your foot on the heel plate of the rearset.
your body position is key like others are stating move your head and shoulders towards the mirrors but you dont want any pressure on the handlebars as this will make the bike turn which you dont want to happen. could cause the front end too tuck.
good luck..
PostPosted: 13:58 - 14 Oct 2008    Post subject: Reply with quote
Just to clarify; the Apex is the point you are closest to the edge of the tarmarc; if you're good (better than me) you've got your wheel about 2 inches from the edge of the track here with your knee over the grass.
Though, saying that; An indication you can faster is when you're trying a bit too hard and go over the rumble strip... and don't crash!
The point you start turning is usually described as... 'the turn in point' Smile.
The toes is a good point - you should have the ball of your foot on the peg, with it close in to the bike. This minimises the chance of your foot touching down (it's neither big nor clever).
I would agree that for the moment, you want to probably get the braking over and done with before turning in.
However, if you're 'properly trying' (and people new to the track, please don't try this yet!), this is what you'd want to be doing (in the dry with decent grip):
Just before you start braking, start hanging off.
Brake (so that the rear of the bike is just about to leave the tarmac)
As you get to your turn-in point you should be at the point you can ease off the brakes a bit.
Turn in as sharply as possible (which goes hand in hand with a late turn in point)
After turning in, as you lean over more, slowly release the brakes proportionally, until just before the apex where you fully release them.
Get on the power as you stand the bike up, whacking it fully open (depending on the bike) as soon as possible in relation to the grip you've got.
Getting hold of a copy of 'A Twist of the Wrist II' would be a good start rhone Thumbs Up.
MaybeGuy
PostPosted: 18:12 - 14 Oct 2008    Post subject: Reply with quote
get your arse crack on the edge of the seat, stick knee out, lean until it touches tarmac.
PostPosted: 18:20 - 14 Oct 2008    Post subject: Reply with quote
Unlikely to help you with 'cornering feel', but may make you go faster Smile - may well even make it 'feel' worse for some people.
Whosthedaddy
PostPosted: 22:03 - 14 Oct 2008    Post subject: Reply with quote
The thing that I need to work on is the head and shoulder position.
I tend to stay upright (for a better word) and just seem to push the bike with my arms and legs from side to side just as someone on a bmx or mountain bike may do when turning a corner.
The analogy of a heavy head is a good one as the MCN 'How to KD' uses this principle, I have yet to master it though as it seems to unsettle my position and ultimately my confidence as it feels very front heavy with extra weight being placed on the bars.
Not a big fan of hanging off, seems too much to do in a short period of time especially when you see the corner approaching rapidly.
Any ideas, not the best time of year to try and perfect it I know and I can't wait to see my track day pics come November, the shame of it all I can sense it now!
The rear brake entering a corner is something that was commented on by the Bikesafe course I believe and one that does come in handy on the road not just the track.
PostPosted: 22:21 - 14 Oct 2008    Post subject: Reply with quote
Erm, first off.. that's trailing the front brake into the corner, not rear! I don't really use rear much at all myself.
Hanging off before you start braking (providing you've got decent conditions - not soaking wet) gives you plenty of time to do the rest of the stuff (though does start to make your arms ache if you're trying a bit and a bit unfit, as I usually am).
I found it helped a lot to practice hanging off on the road - even on the 5mph parking into a space at work - doing it on the road when I had time to think about it made it more second nature on track when there's a lot more going on.
Whosthedaddy
PostPosted: 22:31 - 14 Oct 2008    Post subject: Reply with quote
You said rear in your post, but must admit that it was discussed that it was a way of scubbing a little speed off (done gently as not to lock up the rear) and gets you away from snatching the front and causing more problems.
I do use hanging off when doing slow speeds, not sure I'd do it pulling up to park at work as I may get even more stupid looks than I probably already do.
On those pics above, what gear would be best?
PostPosted: 22:42 - 14 Oct 2008    Post subject: Reply with quote
Edited for clarification; meant use the front so the rear is just about to lift.
One place that the rear can be used, though I haven't found it made much difference, is to use it just before the front to drop the rear down a bit; this should mean you can brake a little harder before the back comes off the tarmac.
Wouldn't worry about it too much at the mo - when you're braking with the rear just about to hover right to the apex, then tipping in and keeping brakes deep into the corner, maybe it's worth considering stuff like that to push it a little more Smile... though even when I've been fairly happy with my riding, I've found it's one more thing I don't have time to think about.
The last post was made 17 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 91.6 Kb
