Bike engine tolerances
Acemastr
PostPosted: 07:33 - 16 Oct 2008    Post subject: Bike engine tolerances Reply with quote
I passed my CBT on Saturday, and have been riding my brand new YBR125 to work and back (25miles each way) obviously cruising at 55 has the revs up at 7.5k and redline is 10, how 'robust' are bike engines? i'd never sit at massively high revs in my car but everyone seems to do it on bikes without problems, 60mph is around 8.2k rpm, would this be ok on the engine?
Is a redline every now and again a bad thing?
(p.s run in period is over)
Thanks for input.
2016 Toyota Tacoma Limited
doggone
PostPosted: 07:39 - 16 Oct 2008    Post subject: Reply with quote
They are designed to run at that sort of speed but in the longer term a bigger bike will be so much more relaxed with a run like that.
You should be looking at 600s maybe.
In the meantime keep on top of maintenance particularly oil changes.
Acemastr
PostPosted: 07:51 - 16 Oct 2008    Post subject: Reply with quote
I only passed the CBT last Sat, i'll ride the 125 for a year or so and get the DAS done for a bigger bike, i know it'd be nicer on a bigger bike but it's just not an option right now, fuel consumption is lol, currently done 150miles on this tank and still have 3/4 left! woo.
thefallenange...
PostPosted: 07:55 - 16 Oct 2008    Post subject: Reply with quote
it's a 125 which isn't chinese. If anything goes wrong before 40k i'd be suprised.
On those IIRC there's no filter so drain the oil off every few thousand miles and refill it, lube the chain every couple of days and adjust correctly (use old oil as chain lube) and you'll be fine. You'll crash it before it breaks.
Past - CG125 ,KR1S, SV650s, Street Triple R - Current - Duke 390
r.bridge1988@gmail.com
Acemastr
PostPosted: 07:57 - 16 Oct 2008    Post subject: Reply with quote
Top man, thank you for the reply.
Bike_craze1
PostPosted: 08:09 - 16 Oct 2008    Post subject: Reply with quote
Those bikes are solid for reliability.
Yamaha R125 - Cagiva Mito 125 - Honda CBR 600
CBT passed: 22/07/08 Bike Theory passed: 28/03/09
Bike Test passed: 15/04/09
Charlie
PostPosted: 08:39 - 16 Oct 2008    Post subject: Reply with quote
I have sat at 10k rmp for miles, 10k in top gear is 80mph, so about motorway speeds. Although that isn't that close to the redline so it isn't too bad.
You bike will be fine, I use to thrash my 125 to and between college and it was always fine. Just keep on top of the oil changes and keep the chain in order and it will be fine.
I hope you are enjoying biking Wink
PostPosted: 08:52 - 16 Oct 2008    Post subject: Re: Bike engine tolerances Reply with quote
Acemastr wrote:
Ihas the revs up at 7.5k and redline is 10, how 'robust' are bike engines? i'd never sit at massively high revs in my car
Relatively that is sitting at 3/4 of the available revs. No different to sitting at 4500rpm in the car which I certainly wouldn't worry about.
Renton
PostPosted: 09:32 - 16 Oct 2008    Post subject: Reply with quote
I went on a Bike-Safe course couple weeks back an they told me to use higher revs an lower gears, if they do it an their bikes are fine then I see it as my bike will be fine.
I was told the bikes are tested at a higher rev mark than the red line before being manufactured
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
Acemastr
PostPosted: 09:40 - 16 Oct 2008    Post subject: Reply with quote
You've all been bloody helpful, cheers guys (and gals) really appreciate it, i'm loving riding, it was raining a lot yesterday so that wasn't as fun but i'll get used to it.
v8will
PostPosted: 09:42 - 16 Oct 2008    Post subject: Reply with quote
Follow regular servicing (oil, chain lube etc) and warm the bike before thrashing it and it should be fine.
Extended high(ish) revs at part open throttle isn't too stressful really.
One guy on here has a 125 with over 60k on it!
The last post was made 17 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 67.53 Kb
