U Turns
tommybhoy
PostPosted: 12:49 - 19 Oct 2008    Post subject: U Turns Reply with quote
Looking for some help advice...Im just in from my second half day lesson and i still cant do a u-turn on narrow road.My test is thursday and to make matter worse the instructor said i would be better falling off my bike rather than putting my foot down...
I have one more lesson before test ,hopefully i can pick something up from there
Any tips...
I have my own bike but cant practice because im using their bike
nasty
PostPosted: 13:25 - 19 Oct 2008    Post subject: Re: U Turns Reply with quote
Any tips...
You can still practice on your own bike mate, the principles are the same - Steady throttle and use the clutch to control the speed and back brake if needed.
I use my NSR125 to practice u-turns on and that's a totally different style of bike to the one I'm doing my test on, on my NSR I have to lean into the turn and on the DAS bike I just need to turn the handlebars but everything else is exactly the same.
Get yourself out to an industrial estate or another quiet spot where you can get some practice in - the more you do it the easier it gets Very Happy
ZX6R F3
Kal
PostPosted: 13:32 - 19 Oct 2008    Post subject: Re: U Turns Reply with quote
It's better to practise on your bike then not practise at all.
U turn is easy once you get the hang of it, and transferring the skill from bike to bike isn't so difficult
First off stop stressing - if you stress about it you will ride stiffly and fail it
Secondly it is a low speed maneuvre, so your speed control is off of your clutch. Start the turn slowly and give it a little more speed once you have the exit lined up. Use the back brake to keep the frame tight in the begining of the turn.
To balance - pull forwards a little way to steady the bike rather than diving straight into the turn.
Grip your tank with your knees - push down on the pegs.
Look all the way through the turn - the bike follows where you look
Lead into the turn with your right shoulder.
Kal...
PostPosted: 13:37 - 19 Oct 2008    Post subject: Re: U Turns Reply with quote
Practice, practice and then practice some more.
Nope, you're much better putting your foot down than falling off. If you put your foot down there's the slight chance the examiner would let you have another try, if you fall off then I'd expect them to end the test immediately.
What's your bike and what's the training schools bike?
tommybhoy
PostPosted: 13:44 - 19 Oct 2008    Post subject: Reply with quote
Thats what i will do next week practice....
My bike is a yamaha Dt125r and the schools is a Sukida Patriot SK125,honestly the bike is brand new and it peice of shite
nasty
PostPosted: 14:08 - 19 Oct 2008    Post subject: Reply with quote
What test are you doing, A2? Can you not use your own bike?
ZX6R F3
tommybhoy
PostPosted: 14:13 - 19 Oct 2008    Post subject: Reply with quote
they advised me to use their bike and it was only an extra £25...Yes im just doing a restricted ,will be happy with 250cc for two years
mcgoogle
PostPosted: 14:32 - 19 Oct 2008    Post subject: Reply with quote
You do know know that you dont have to get a 250cc bike or is that what size bike you want?
A few people have said to use the clutch to control your speed i was taught to "drag" the back break when doing the u-turn, so the throttle and clutch stay in the same place and if you want to slow down you press harder on the back break and speed up up raise your foot slightly off but not completely.
I am not saying everyone else is wrong its just a different way of doing it.
nasty
PostPosted: 14:44 - 19 Oct 2008    Post subject: Reply with quote
Combination of all 3 is best practice Thumbs Up
ZX6R F3
tommybhoy
PostPosted: 14:47 - 19 Oct 2008    Post subject: Reply with quote
i know that about the size thing.I just dont see the sence of restricting a 600cc to 33bhp...
As i will just have to practise
caragh
PostPosted: 15:05 - 19 Oct 2008    Post subject: Reply with quote
I personally found U- turns much easier when blipping the throttle and slipping the clutch bike felt more stable. Confused
Triumph Tiger 800 XR
Wise1
PostPosted: 23:38 - 19 Oct 2008    Post subject: Reply with quote
Everyone has their own view of how it can be done, for the test its pretty simple.
Remember nerves if they kick in can cause you to put a foot down, pull the throttle, etc...
So dont:
use idle speed only
left the clutch all the way out
use the front brake
So on the test, the safest possible method to ensure you get around which also allows for nerves kicking in is to:
Move off, give yourself about a good 15 feet to get the speed you want, slip the clutch and use the brake as your speed control.
Let the clutch out a bit more if your not going fast enough but cover the back brake at all times and use it to slow you when needed.
As your going into the turn adjust your body weight and lean in the opposite direction (left) and this will remove the feeling of the bike falling over.
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
SonicTheHedge...
PostPosted: 11:11 - 20 Oct 2008    Post subject: Reply with quote
Open your visor as well - keeps you a bit more in touch with the real world in terms of sound and feel.
Slow in, fast(er) out.
Previous: '00 G2 Bandit 600 Naked. Now: '08 BMW GS Adventure.
Tonka
PostPosted: 11:35 - 20 Oct 2008    Post subject: Reply with quote
I did my DAS on a GS500 but practiced like crazy on the little Yam125 the school let me borrow. It's different but the principle is the same and it's the confidence that you need.
I found that I needed more speed to get round well and that came with confidence, as I kept killing the speed just as I was about to turn and then unsurprisingly couldn't get round Rolling Eyes
Another thing I found that helped me was that I was able to do a u-turn after I'd practiced a bit but the first one was always rubbish - problem with test is I only had one chance! Test format for me was walk bike round, then hop on and ride the u-turn, so I practiced this quite a bit too. Try lots of different streets too as that gives you some more confidence - it's surprising what can put you off (trees, manhole covers etc.)
Hope it goes well! Very Happy
Damon
PostPosted: 14:04 - 20 Oct 2008    Post subject: Reply with quote
best piece of advice i was given about u turns was this
find a point behind you on the otherside of the road, etc a car number plate and focus on that. slip the clutch and use the rear brake. whatever you do, keep focusing on that point and do not look at the curb, otherwise you will be heading for the curb. look at the car, you head for the car. It should also keep you nicely balanced also.
try that and practise on your bike. you will get it. good luck dude
lofty
PostPosted: 16:14 - 20 Oct 2008    Post subject: Reply with quote
Lean to the outside a bit, i find if I shift my left arse cheek off a tiny bit then it stops me doing that 'oh god, im leaning in, oh crap oh crap.... foot down!'
Also, if you let off the throttle you'l lose your balance, keep the revs up and balance it with the clutch and back brake, don't dip the revs if you think you can't make it, because you will put your foot down then!
Good luck with your test!
skiberd123
PostPosted: 16:55 - 20 Oct 2008    Post subject: Reply with quote
got my test at 8am tomorrow morning (sheeet!) and the u-turn is the only thing im worried about after a day of fails and wins practicing. tried it on a mates city fly and found it a a piece of cake. goddamn cbr with stupid low handle bars.... Mad
but i find sitting up straight helps. i think waking up at dawn to go round in circles is the way forward
tommybhoy
PostPosted: 18:13 - 20 Oct 2008    Post subject: Reply with quote
Good news i think!!!.Was out on my own bike and i tried at least 15 u-turns on a street slightly wider then the one on test route and got everyone of them...Gonna try the test route street tomorrow after work ...
Im i allowed to used my own bike even though its an off road but its road legal.Will i need to take the usual mot insurance....The back break light is a bit iffy whe i pull front break
jack_zxr400
PostPosted: 07:27 - 22 Oct 2008    Post subject: Reply with quote
if theres something wrong with your bike or it doesnt have tax mot or insurance the examiner wont do the test
better safe than sorry and do it on the schools unless your not comfortable on it?
Previous Bike: ZXR 400
Current Bike: R6
Test Date: 8/8/2008-PASSED
Kal
PostPosted: 08:37 - 22 Oct 2008    Post subject: Reply with quote
Yes, you will need to take all the bikes docs to prove it is allowed on the road.
Iffy brake light is an MoT fail, as such it shouldn't be on the road at all - and even if you get it through tech inspection if it fails to come on when you are slowing the examiner can fail you for not sharing your intentions with other roadusers.
If your bike is old enough - and I mean 1980's - then you could get away with disconnecting your front brakes sensor and using the rear to signal your intentions.
Kal...
tommybhoy
PostPosted: 09:20 - 23 Oct 2008    Post subject: Reply with quote
test has been canceled because of the weather....
Syx
PostPosted: 09:07 - 24 Oct 2008    Post subject: Re: U Turns Reply with quote
I remember for my test I was of the mentality that "Either this fucker gets around or my arse is on the floor - I'm not putting that foot down" and that very much forced me to just do it. Perhaps what his examiner meant?
Also, best of luck on the test Thumbs Up
tofu-wtf
PostPosted: 14:07 - 27 Oct 2008    Post subject: Reply with quote
Steady revs, slip the clutch and look where you want to go......NOT where you fear ending up!!
and you'll do fine Smile , it's already been said but practice. The turn in the road is generally done on a 'generous' width road anyhow, they're trying to test your ability....not trying to make you fail.
Relax, keep your shoulders loose and it'll all be ok Thumbs Up
Eagles may soar.............but rats don't get sucked through jet engines!!
1999 ZX6r G1.....it makes me smile Very Happy
The last post was made 17 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 123.23 Kb
