| twotakt |
 twotakt World Chat Champion
 Posted: 07:09 - 21 Oct 2008 Post subject: Indicator problems |
Hi all,
On my 2002 NSR125 when I connect up the front indicators OR rear indicators they work fine. BUT when I connect BOTH front and rear indicators, the flasher relay doesn't pulsate anymore and stays on permenantly and the indicator turns on with a very weak and permenant light. Then if I disconnect either the front or rear the other indicator flashes perfectly and bright.
Weird eh? Any ideas? (apologies for my knowledge of electrics is super noobish)
Thanks,
Jack ____________________ R.I.P. Tareree Shiimi, 1985-2008 |
| alains |
 alains World Chat Champion
 Posted: 08:01 - 21 Oct 2008 Post subject: |
the flasher relay (near the seat lock) is marked 20W+1,7 . this means that the total bulbs power on each side must be 20W (in fact 10+10) . your bike is probably equiped with aftermarket winkers (in front or rear) and those have 21 or 23W bulbs which is far too much . generaly on this type of winker , the bulb socket is Ba9s or Ba9,5s . so if i am right , change the 21 -23W bulb by 10W model
may be halfords stock them but in case of difficulty to find go there https://www.norbsa02.freeuk.com/goffybulbs.htm
choose Ba9s 12V 10W
the other solution is to fit everywhere 23W bulbs but you need to change the 20W relay by a 40W relay . this solution works but the power asked to make them working is a bit too much and gives a fall in voltage which is dangerous at night with headlights on ____________________ the worst day fishing is better than the best day working |
| twotakt |
 Posted: 08:09 - 21 Oct 2008 Post subject: |
That sounds right alains, as I bought the bike with no indicators so fitted some aftermarket ones that I'd got in a job lot of stuff. I will get some different bulbs from halfords soon and will report back.
Thanks,
| twotakt |
 Posted: 11:20 - 21 Oct 2008 Post subject: |
The lights both come on now.
BUT
Now the relay doesn't work!!!! It was fine y'day, I have to keep hitting it for it to work? Anyway to fix it or is it time for a new one?
Ta,
| alains |
| twotakt |
 Posted: 23:06 - 21 Oct 2008 Post subject: |
Yeah, I have the original relay currently on the bike but it doesn't work anymore. I'll have to get another one from Honda if they're not too expensive. ____________________ R.I.P. Tareree Shiimi, 1985-2008 |
| alains |
 Posted: 00:22 - 22 Oct 2008 Post subject: |
The last post was made 17 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
