what this noise?
PeterNSR
PostPosted: 11:56 - 21 Oct 2008    Post subject: what this noise? Reply with quote
Some might no that i had an acciident with my bike lst week wihich involved running out of engine oil.
I keep trying to start my bike up but all i get is this.
https://uk.youtube.com/watch?v=g2Bc6LoIHew
Thumbs Up Karma
Current: Honda NSR 125 Smile
My bike
rotax81
PostPosted: 12:01 - 21 Oct 2008    Post subject: Reply with quote
has it siezed up?
try bumping it
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
PeterNSR
PostPosted: 12:08 - 21 Oct 2008    Post subject: Reply with quote
i have tried bumping it and when i do the revs are really low.Could it be the battery
My bike
PostPosted: 12:10 - 21 Oct 2008    Post subject: Reply with quote
Doubtful. It would have enough power just from the alternator to run normally. Try it with the lights off, see if it makes a difference.
PeterNSR
PostPosted: 12:12 - 21 Oct 2008    Post subject: Reply with quote
when i try it with the lights off it just makes tht noise whats in the vid.
What about the spark plug m8
My bike
SoND
PostPosted: 12:16 - 21 Oct 2008    Post subject: Reply with quote
Nothing to do with the spark plug, the engines not turning over.
I'd get some jump leads and see if it works then.
PostPosted: 12:18 - 21 Oct 2008    Post subject: Reply with quote
I mean bump it with the lights off.
PeterNSR
PostPosted: 12:29 - 21 Oct 2008    Post subject: Reply with quote
Yeah when i do that it works .
But when i get on it it doesnt want to go over 5000rpm.
Should i take the fairings off and have a good look at it.
My bike
chillpill
PostPosted: 12:55 - 21 Oct 2008    Post subject: Reply with quote
yeah take the fairings off, did you inspect the top end after you ran it without oil ?
any problems idling when you bump started it ?
BanditsHigh
Worse than a woman
PostPosted: 12:56 - 21 Oct 2008    Post subject: Reply with quote
That sounds almost like the starter motor is trying to rotate but can't, like something is jamming it ... engine seized?
When you say you had an accident with oil, did you run out of oil or have the oil pressure light come on?
Finglonga
PostPosted: 13:27 - 21 Oct 2008    Post subject: Reply with quote
Checked the battery? Charge it and try it then, if it starts and runs ok your battery or charging system is the problem.
Andy Sez....
F.Y.Y.F.F.
PeterNSR
PostPosted: 15:06 - 21 Oct 2008    Post subject: Reply with quote
i ran out of engine oil, no warning light Mad
Just going to get a battery charger now.
if its not the battery could it be the alternator?
My bike
NSR Mick
PostPosted: 15:13 - 21 Oct 2008    Post subject: Reply with quote
I would be taking a look at the top end 1st unless you have allready sorted that.
chillpill
PostPosted: 16:31 - 21 Oct 2008    Post subject: Reply with quote
yeah defentley look at the top end , to run out of oil and not have any barrel or piston damage will be a miracle Sad
salty21
PostPosted: 16:42 - 21 Oct 2008    Post subject: Reply with quote
after a rebuild on my nsr once i forgot to re-attach the oil pipe to the carb and when it seized it made that exact noise when trying to start on the button, when i bumped it, it wouldn't go over 3.5-4k revs and cut out not long after.
i inspected the top end and found deep scores in the front edge of the barrel and had to buy another brand new one to replace the brand new one i had just fitted lol, nearly £350 all in all for that rebuild.
so i am afraid you have more than likely seized it like i did but luckily your pistons not welded itself in yet so dont keep trying to run it and as said get the head off and have a gander.
Damon
PostPosted: 07:06 - 22 Oct 2008    Post subject: Reply with quote
TAKE A LOOK AT THE TOP END BEFORE BUMPING AGAIN
sorry, had to shout that. Mr. Green i have a feeling you may be needing a new barrel and piston tbh
open her up and take some pictures.
good luck
Cigaro
PostPosted: 08:24 - 22 Oct 2008    Post subject: Reply with quote
If you ran out of oil it's probably seized. Not what you want to hear but unfortunately it's true.
No point keeping on trying to start it, you'll just cause more damage.
Take the topend off and have a look. If you're lucky it may just be the rings.
PeterNSR
PostPosted: 16:58 - 22 Oct 2008    Post subject: Reply with quote
I charged my battery all night last night.Put it in when i got home and it started perfect.Took it for a spin and about 5 mins into riding when into 3rd gear and i cut out again.
My mate went and bought an r6 and he said the same thing happened to his rs.said i should put oil down a barrel because the piston might be sticking or something like that.
I was thinking about getting a pro to have a look.
My bike
salty21
PostPosted: 17:03 - 22 Oct 2008    Post subject: Reply with quote
are you even reading the posts???? or are you just not bothered??? im sorry to say this but you are starting to come across as supersports2.
take the head off and have a look.
rac3r
PostPosted: 17:07 - 22 Oct 2008    Post subject: Reply with quote
READ YOUR REPLIES!
In your post most people have said you may have seized it as this is what usually happens when you run it without oil! Check this first Brick Wall
Chequered Flag
rac3r
Doh you beat me to it!
Chequered Flag
Finglonga
PostPosted: 17:14 - 22 Oct 2008    Post subject: Reply with quote
Would have helped if we were told in the first post that it had run out of engine oil as well.
Andy Sez....
F.Y.Y.F.F.
NSR Mick
PostPosted: 21:19 - 22 Oct 2008    Post subject: Reply with quote
CHECK THE TOP END!!! Brick Wall
ZRX61
Victor Meldrew
PostPosted: 02:08 - 23 Oct 2008    Post subject: Reply with quote
& while you're there you might want to mention the fact that you are too fucking stupid to own a bike. Rolling Eyes
The last post was made 17 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 128.77 Kb
