speedo problem any suggestions
joop200789
PostPosted: 21:41 - 21 Oct 2008    Post subject: speedo problem any suggestions Reply with quote
jst bought a rs there was no speedo cable on it,
so went and bought a new fitted it and it dont work
so ive disconnect it from the speedo end and spun the front wheel and the cable turns so the speedo drive seems to be fine,
so then have reconnected it to the speedo and disconnected it front the speedo drive stuck battery drill on it and spun it round and i get a reading on the speedo,
but when its a together it doesnt work any idea???
Xenocide
PostPosted: 11:03 - 22 Oct 2008    Post subject: Reply with quote
What happens if you connect it to the wheel and put a little bit of pressure on the speedo end and move the bike? Happens to a mates whereby the spline-type-thing on the wheel was damaged so it'd turn when there was no pressure on it but slip when there was.
Had to get new hub internals in the end
KTM LC4 400 | Honda VTR1000
PostPosted: 11:13 - 22 Oct 2008    Post subject: Reply with quote
Double check that it is seated correctly at both ends. Often quite easy to not seat the cable properly (especially behind the speedo itself) and have them not work.
joop200789
PostPosted: 12:48 - 22 Oct 2008    Post subject: Reply with quote
have had another look it looks like it droping down its sleeve and not sitting in the speedo
ill have to modfy it abit
PostPosted: 22:14 - 22 Oct 2008    Post subject: Reply with quote
Might be worth checking it is the right cable then. Not sure but it wouldn't surprise me if they used different cables (probably with different length inner cables) when they changed the style of the clocks (and I can think of 3 different types of clocks on the RS).
The last post was made 17 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 45.13 Kb
