| Eddie Hitler |
 Eddie Hitler World Chat Champion
| NSR Mick |
 NSR Mick World Chat Champion
| Eddie Hitler |
| stinkwheel |
 Posted: 12:31 - 23 Oct 2008 Post subject: |
Have you tried shimming round the shaft with some slices of beer can?
Failing that, if you have decided the shaft and lever are shagged and to be replaced, there is a horrible but effective bodge you can do.
Go out and buy a 4mm HSS drill bit (about £1.50) and put it in the freezer. Set the lever where you want it and do up the clamp as tight as it will go. Heat the area where it clamps as hot as you dare with a blowlamp.
Now drill into the bit where the lever joins the shaft. You should eventuall feel the drill starting to 'bite' once it has gone in a ways. Stop here, undo the drill chuck leaving the drillbit stuck into the metal and snap the end off.
Seen that fix work for a period of years. If it falls out, try hammering an iron nail into the 'hole'. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Eddie Hitler |
 Posted: 13:06 - 23 Oct 2008 Post subject: |
Sounds like a decent bodge ( ), it seems to work fine now i have change the position of the lever. Like i said it looks like /. But ill eventually get round to replacing what needs replacing as ill be seilling next year for a 600 when my restriction is up. I was worried i may have to replace the engine or something. So at least that worries gone.  |
| Pete. |
 Pete. Super Spammer
 Posted: 22:00 - 23 Oct 2008 Post subject: |
Maplins do a box of about 60 roll-pins for about a fiver. Set the position, drill right through and tap-in a roll-pin. ____________________ a.k.a 'Geri'
| Eddie Hitler |
| Blau Zedong |
 Blau Zedong Banned
| Eddie Hitler |
| Stalk |
 Stalk Brolly Dolly
| ZaphodBeeble |
 ZaphodBeeble World Chat Champion
| rotax81 |
 rotax81 Nearly there...
 Posted: 22:42 - 30 Oct 2008 Post subject: |
The last post was made 17 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
