I think i have actually buggered my bike up..
Eddie Hitler
PostPosted: 11:20 - 23 Oct 2008    Post subject: I think i have actually buggered my bike up.. Reply with quote
Splines on the shaft must have worn down.
3 gear levers later and its still happened, cant really be anything else.
Rough price/procedure to replace shaft?
NSR Mick
PostPosted: 11:43 - 23 Oct 2008    Post subject: Reply with quote
Could be a simple as clutch cover off, clutch off, remove circlip or other retaining device, slide shaft out.
Get new shaft in hand and reverse procedure.
Eddie Hitler
PostPosted: 11:46 - 23 Oct 2008    Post subject: Reply with quote
Ok cheers, it looked like it was seperate from the engine. WHat ill do it get a new shaft or something from Honda, with a new gear lever and get a small garage ive dealt with for a few years (very good) to get it donr properly for me.
Until i can afford it ill have to change gear with my foot vertical.. only way it grips is when the gear lever is /. Lol.
PostPosted: 12:31 - 23 Oct 2008    Post subject: Reply with quote
Have you tried shimming round the shaft with some slices of beer can?
Failing that, if you have decided the shaft and lever are shagged and to be replaced, there is a horrible but effective bodge you can do.
Go out and buy a 4mm HSS drill bit (about £1.50) and put it in the freezer. Set the lever where you want it and do up the clamp as tight as it will go. Heat the area where it clamps as hot as you dare with a blowlamp.
Now drill into the bit where the lever joins the shaft. You should eventuall feel the drill starting to 'bite' once it has gone in a ways. Stop here, undo the drill chuck leaving the drillbit stuck into the metal and snap the end off.
Seen that fix work for a period of years. If it falls out, try hammering an iron nail into the 'hole'.
Eddie Hitler
PostPosted: 13:06 - 23 Oct 2008    Post subject: Reply with quote
Sounds like a decent bodge ( Laughing ), it seems to work fine now i have change the position of the lever. Like i said it looks like /. But ill eventually get round to replacing what needs replacing as ill be seilling next year for a 600 when my restriction is up. I was worried i may have to replace the engine or something. So at least that worries gone. Cool
PostPosted: 22:00 - 23 Oct 2008    Post subject: Reply with quote
Maplins do a box of about 60 roll-pins for about a fiver. Set the position, drill right through and tap-in a roll-pin.
Eddie Hitler
PostPosted: 21:01 - 29 Oct 2008    Post subject: Reply with quote
A friend of mine suggested welding the gear lever on.
Now when it sounds ideal as it will solve the problem 100% what after effects will i get? Eg not being able to take the chain off?
Eddie Hitler
PostPosted: 15:51 - 30 Oct 2008    Post subject: Reply with quote
Thats exactly what i thought.
Im going to give that roll pin technique a go when i get some dolla.
Stalk
PostPosted: 20:55 - 30 Oct 2008    Post subject: Reply with quote
Could perhaps try taking off the gear lever, cutting a thin slice out of the gap where the pinch bolt goes through to make the split bigger. Hopefully when you tighten the bolt up, the hole in the middle (where it goes over the shaft) will be smaller and will maybe grip better.
Just an idea, hope it helps.
Cheers,
Stalk.
ZaphodBeeble
PostPosted: 22:11 - 30 Oct 2008    Post subject: Reply with quote
An extension of this is to drill vertically through the middle of the shaft and gear lever clamp and put a bolt through it with a nylock nut. Removable and effective. Just make sure the drill bit isnt too big to weaken the shaft. In other words; if you have a 10mm diameter shaft dont drill it out with an 8mm bit. Smile
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
rotax81
PostPosted: 22:42 - 30 Oct 2008    Post subject: Reply with quote
10mm shaft and 8mm bit? bit close that Wink
i have tried bodging these things before on a dt175mx i had that kept destroying levers.
in the end i used a lever from a different bike that was a much better fit. have a look around Thumbs Up
i used a couple of carpet tacks hammered in there as a temp fix.
loosen it off, hammer a couple in and tighten it up.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
The last post was made 17 years, 344 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 73.45 Kb
