SHOCK LINKAGE OVERHAUL
stirlinggaz
PostPosted: 11:33 - 23 Oct 2008    Post subject: SHOCK LINKAGE OVERHAUL Reply with quote
Hi all,
currently restoring a 22 yr old vfr.
as its on the original suspension, im intending to overhaul it, but as this is my 1st attempt at suspension, im learning as i go along.
sourced an oe shocker which is in remarkably good condition.
but i forgot about the linkage, doh!
anyway, the bolt going through the bottom of the shocker is rusted solid & im having problems removing it.
this probably means the the rollers/bearings in the linkage will probably be in a similar state.
if i manage to get the linkage off (those bolts are pretty rusty too!)
the bearings are gonna need replaced & im led to beleive these are of the needle type.
the manual shows them being extracted with a special tool & new ones being pressed in with, again a special tool.
anyone any tips as to how i could do this myself (presuming i can actually source the bearings) or will it be a case of taking the linkage off the bike & taking the thing to a bike shop & asking them to do it?
any advice welcome,
cheers,
GAZ
PostPosted: 11:38 - 23 Oct 2008    Post subject: Reply with quote
The bolt has probably seized to the steel bush in the linkage. It is the bush that runs in the bearing. As such possible (although unlikely) that the bearings are still fine.
Might well be easiest to take off the shock and linkage and then work on it off the bike. Someone with a press could probably get the bolt out pretty quickly it presented with the linkage. Failing that prepare to spend ages with a vice and various spacers.
PostPosted: 12:04 - 23 Oct 2008    Post subject: Reply with quote
The carefull application of large amounts of heat to the effected area is often useful.
If the bearings are definately knackered, just batter them out with something like a socket on an extension bar.
Bearings are cheapest from a bearing factors and usually better quality but don't try to be clever writing down dimensions and suchlike, the guy on the desk on my local bearing factors gives you a lolly if you take the old one in with you.
The old fashioned technique of bearings in the freezer, casting in the oven is often an effective replacement for a bearing pressing tool. That or a bit of big threaded bar with two nuts and washers going up the middle.
Consider fitting grease nipples if there aren't any.
Might be worth comparing the prices of new pins, new sleeves and new bearings to the cost of a good second hand one from a breakers.
stirlinggaz
PostPosted: 12:37 - 23 Oct 2008    Post subject: Reply with quote
hi,
& thanks for the replies.
tbh, i have no idea as to the state of the bearings in the linkage.
i hadnt even thought about the linkage! but i when it came to swapping the suspension units over, this is when i realised all the bolts are pretty much rusted on, this made me think that the bearings are likely to be past it.(though Keith has me hoping not)
i suppose i wont know till i get the whole lot off the bike.
there lies the problem, as the bottom bolt on the unit is seized, i can safely presume that the others are as well!
i had thought of just sourcing a complete second hand linkage & fitting new bolts but there no guarantee that the replacement linkage will be in any better state internally.
is it a case of just fit it & see?
or is there any way i can tell if the needle bearings are f*cked?
cheers,
GAZ
PostPosted: 12:43 - 23 Oct 2008    Post subject: Reply with quote
You should be able to tell once you get it apart. Although too much heat will likely ensure that the bearings are damaged (or at least desperatly in need of tlc).
Entirely possible for just one bolt to be seized. I take it you have got the nut off and the bolt is now just turning but won't slide out.
stirlinggaz
PostPosted: 13:13 - 23 Oct 2008    Post subject: Reply with quote
hi,
the one bolt i attempted to remove, (the one at the bottom of the shock unit) the nut was rusted solid & it rounded off.
the head of the bolts is also seized & &rounded off, so it wont even rotate from that side!
my plan was to cut/grind the nut off & punch the bolt through, but i'm struggling for space down there, so the angle grinder is out & the dremels a bit feeble for this!
cheers,
GAZ
PostPosted: 13:23 - 23 Oct 2008    Post subject: Reply with quote
You can get a tool called a nut splitter, which does as its name suggests. Not sure if they do them that big though.
PostPosted: 13:44 - 23 Oct 2008    Post subject: Reply with quote
Think they do, although maybe not that commonly available.
Gaz - get the nut off and you might well find that the bolt will slide out. Use decent 6 pointed sockets and the easier to use and common bi-hex ones are far more likely to round nuts and bolts.
stirlinggaz
PostPosted: 15:23 - 24 Oct 2008    Post subject: UPDATE Reply with quote
Hi all,
managed to cut/grind the nut off & the bolt is now turning!
but looks like there no quick way of replacing the shocker.
the bolt that i had problems with is the one that goes through the bottom of the shocker.
the other bolts down there all seem to be ok, ie there not completely seized.
unfortunately it looks like im going to have to remove the exhaust & the linkage!
as this bolt wont pull all the way out, because the bolt is one of those types which has a bit of a "collar" on the head (cant remember the correct term, but its not an ordinary bolt) & when trying to pull this bolt out, it hits off the linkage.
& in order to remove the linkage, im going to have to remove the full exhaust! as access to the linkage bolts is akward to say the least!
if the bottom bolt had been of the normal variety, i could have just removed it, pulled the old shocker out & shoved the new one in & hope that the linkage bearings are ok.
it doesnt look as bad as i 1st thought.(the linkage all moves ok, without any nasty grinding noises) but i guess i wont really know till i get the bloody thing off & if i go to that much hassle, i'd be as well replacing the needle bearings in the linkage!
could i just replace the bolt with one of the normal variety?
as i could cut/grind the head down a bit to get it out (its getting chucked anyway,seeing as i have cut the end off!)
here is a pic of the standard bolt,
cheers,
GAZ
edit-just thinking about it.... it wouldnt do any harm to grind down part of the "collar" on both bolts, this would enable me to slide the old one out & the new one in! would it?
i wouldnt be altering the part of the bolt that the socket attaches to, just the circular collar part.
hope this makes sense-the collar of the bolt would be shaped like a D. after i ground it down.
PostPosted: 15:45 - 24 Oct 2008    Post subject: Reply with quote
Having had a linkage bolt snap I would be dubious about putting any old one in there. They have a fair amount of load.
If you unbolt the top shock mout the you migth be able to move things far enough to remove that bolt if the shoulder is just catching. That said it is probably well worth removing the whole linkage and greasing it properly.
stirlinggaz
PostPosted: 16:09 - 24 Oct 2008    Post subject: Reply with quote
ho.
thanks Keith.i dont fancy that bolt snapping on me!
if i can get the linkage off, i will replace the needle bearings. (hopefully without removing the exhaust) which would be my preferred option.
if i cant get it off, i'll just grind a bit of the bolts collar, which should enable me to fit the replacement shocker.
cheers,
GAZ
PostPosted: 09:04 - 25 Oct 2008    Post subject: Reply with quote
You shouldn't have to take the exhaust off.
I presume you have the back wheel out?
I'm struggling slightly with visualising it and I'm not entirely familiar with that model of VFR but you ought to be able to undo enough of the bolts in the linkage to detach it from the swingarm (or possibly detach the dog-bones from the swingarm).
You can then usually jiggle stuff around enough to either get that bolt out or remove all the other bolts and drop the shock out with the linkage still attached.
I certainly know that you can do that on my 750FV. It's the top mount for the shock that is a pain in the arse on my one. You need to dismantle half the bodywork and remove the battery box to get at it.
I have a manual for the VFR750s at home. You didn't say if it was a 750 or a 400 you're working on. If it's a 750, I can have a look at the instructions if you tell me which model you have.
stirlinggaz
PostPosted: 11:11 - 25 Oct 2008    Post subject: Reply with quote
Hi,
its the 700 interceptor (FG).
& it has the motad single exhaust.
i kinda jumped straight into it before i actually understood the principles of the linkage!
i have the workshop manual & the haynes.
i have the top bolt out & the complete rear subframe (including the rear inner fender & battery box) off. (as it was a bit rusty & i got a good replacement)
i did have the back wheel off, but its back on loosely, as i was doing it outside but the weathers turned nasty!
as for the bolts on the linkage, its impossible to get a socket onto them, theres no room.
if i remove the back wheel, i dont have any kind of stand, any ideas?
cheers,
GAZ
PostPosted: 19:57 - 25 Oct 2008    Post subject: Reply with quote
No main stand?
That makes it a pain in the arse!
Here's what the book says:
Block the motorcycle so that the rear wheel is just resting on the ground so there is no weight on the shock but so that the suspension will noit drop when the pivot bolts are removed.
On G through K models, it may be necassary to remove the mufflers.
Unscrew the pivot bolt nuts and withdraw the pivot bolts. Undo the shock absorber lower mounting nut and bolt and disassemble the rear suspension linkage.
On G through k models unscrew the rear link (shock arm) pinch bolt and use a hammer and punch to drive out the rear link pivot inner sleeve. Note any identifying marks or features which might help to ensure correct reassembly.
Now I usually use a couple of ratchet ring spanners to undo unitrak linkages. You could use normal ring spanners to I'd imagine.
It says nothing about removing the exhaust, just the silencer.
I don't have a scanner so I can't scan in the exploded diagram for you.
stirlinggaz
PostPosted: 21:30 - 25 Oct 2008    Post subject: Reply with quote
hi,
cheers Stinkwheel.
heres what i've done :
tied the rear end/suspended it from the roof of my shed (taking the weight off the rear wheel as stated in the manual-looks like im reading from same book as you)
but i think the manuals referring to to the oe twin exhaust as mine has the motad single fitted & it certainly is a tight fit down there!
im having problems removing the pivot bolts.
i can get the shock bottom & top bolts out (i've cut the bottom one as i have another).
i presume that if i remove the shocker (by removing whats left of the bottom bolt, the linkage will drop. giving me better access?
havnt got as far as the pinch bolt yet, but will have another go in the morning.
im probably missing something really obvious or aproaching it all wrong!
cheers,
GAZ
PostPosted: 22:40 - 25 Oct 2008    Post subject: Reply with quote
Far as I can see, If you have to top shock bolt undone and can detach the two "dog-bone" tie bars from either the linkage or the swingarm itself, you ought to be able to move the linkage independantly of the swingarm.
Probably just a little until the shock is removed but maybe enough to pull that bolt out?
EDIT: Since you have it suspended, would you be able to just remove the swingarm pivot and swing the whole thing out of the way?
stirlinggaz
PostPosted: 09:27 - 26 Oct 2008    Post subject: Reply with quote
hi,
right you've lost me, lol
whats the "dog bone" tie bars?
as the only bolts i have removed so far is the top & bottom shock bolts (though i have left them in,loosely for now) & the furthest forward linkage bolt. ("suspension linkage front pivot bolt")
this linkage bolt came out & the front linkage link assembly moves up & down an inch or 2, freely, but wont drop all the way down as it hits the swingarm (at the bit where i presume the fitting for the centre stand goes,as its a hollow tube)
hope that makes sense.
i cant get at the rear link assembly bolts.
in theory i should just be able to lift the shock & front linkage out, right?
then worry about the rear linkage next.
the shock is still sitting in its top mount, if i just yank it back (after removing the top bolt, lol)l it should lift out right?
this im worried about, lol as it seems very tight in there.
as for removing the complete swingarm, that was my next step, as it wouldnt do any harm to replace those bearings as well, seeing as there probably the original ones & 22yrs old!
cheers,
GAZ
PostPosted: 10:45 - 26 Oct 2008    Post subject: Reply with quote
Generic rear suspension linkage will have a (often cast alloy) link from the frame. The rear shock will bolt to this. Also bolted to this will be a pain of links that go to the swinging arm. These are often the shape of a cartoon bone, hence dog bones.
stirlinggaz
PostPosted: 16:07 - 26 Oct 2008    Post subject: Reply with quote
aha,
thanks for clarifying that for me,
cheers,
GAZ
stirlinggaz
PostPosted: 10:45 - 27 Oct 2008    Post subject: UPDATE Reply with quote
hi all,
finally removed that stubborn bottom suspension bolt.
it took a bit of jiggling about & a few taps with a hammer & punch.
& i had to grind the "collar" of the bolt head, to get it to slide all the way out.
i removed 1 of the inner spacers on the linkage & had a wee peek at the bearings & much to my surprise, they look remarkably new.
so im guessing they have been replaced at some point.
Im also presuming a bit of grease packed in there, will see it alright for a few more miles.
i only have copper grease & a pot of LM stuff, any recomendations as to what type of grease i should use?
(will check the manual & see what mr honda specifies but maybe someone could recomend a decent brand?)
after greasing, its just a matter of swapping shock units over & bolting it all back up (that'll be fun)
next on the agenda is : send the wheels off to be powdercoated & start on the front end (forks)
as this will be another 1st for me, wish me luck & await the usual stupid questions, lol
many thanks for the advice, keep it coming!
cheers,
GAZ
PostPosted: 10:54 - 27 Oct 2008    Post subject: Reply with quote
Do not use the copper grease on the bearings under any circumstances.
stirlinggaz
PostPosted: 17:45 - 27 Oct 2008    Post subject: Reply with quote
Hi,
i wasnt planning on using the copper grease, lol.
just couldnt remember the type of grease for bearings, iirc moly something or other, right?
might fit grease nipples while linkage is off, seems a worthwhile & simple enough mod.
cheers,
GAZ
The last post was made 17 years, 102 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 131.78 Kb
