| stirlinggaz |
 Posted: 11:38 - 23 Oct 2008 Post subject: |
The bolt has probably seized to the steel bush in the linkage. It is the bush that runs in the bearing. As such possible (although unlikely) that the bearings are still fine.
Might well be easiest to take off the shock and linkage and then work on it off the bike. Someone with a press could probably get the bolt out pretty quickly it presented with the linkage. Failing that prepare to spend ages with a vice and various spacers.
 Posted: 12:04 - 23 Oct 2008 Post subject: |
The carefull application of large amounts of heat to the effected area is often useful.
If the bearings are definately knackered, just batter them out with something like a socket on an extension bar.
Bearings are cheapest from a bearing factors and usually better quality but don't try to be clever writing down dimensions and suchlike, the guy on the desk on my local bearing factors gives you a lolly if you take the old one in with you.
The old fashioned technique of bearings in the freezer, casting in the oven is often an effective replacement for a bearing pressing tool. That or a bit of big threaded bar with two nuts and washers going up the middle.
Consider fitting grease nipples if there aren't any.
Might be worth comparing the prices of new pins, new sleeves and new bearings to the cost of a good second hand one from a breakers. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stirlinggaz |
| stirlinggaz |
| stirlinggaz |
 Posted: 15:23 - 24 Oct 2008 Post subject: UPDATE |
Hi all,
managed to cut/grind the nut off & the bolt is now turning!
but looks like there no quick way of replacing the shocker.
the bolt that i had problems with is the one that goes through the bottom of the shocker.
the other bolts down there all seem to be ok, ie there not completely seized.
unfortunately it looks like im going to have to remove the exhaust & the linkage!
as this bolt wont pull all the way out, because the bolt is one of those types which has a bit of a "collar" on the head (cant remember the correct term, but its not an ordinary bolt) & when trying to pull this bolt out, it hits off the linkage.
& in order to remove the linkage, im going to have to remove the full exhaust! as access to the linkage bolts is akward to say the least!
if the bottom bolt had been of the normal variety, i could have just removed it, pulled the old shocker out & shoved the new one in & hope that the linkage bearings are ok.
it doesnt look as bad as i 1st thought.(the linkage all moves ok, without any nasty grinding noises) but i guess i wont really know till i get the bloody thing off & if i go to that much hassle, i'd be as well replacing the needle bearings in the linkage!
could i just replace the bolt with one of the normal variety?
as i could cut/grind the head down a bit to get it out (its getting chucked anyway,seeing as i have cut the end off!)
here is a pic of the standard bolt,
cheers,
GAZ
edit-just thinking about it.... it wouldnt do any harm to grind down part of the "collar" on both bolts, this would enable me to slide the old one out & the new one in! would it?
i wouldnt be altering the part of the bolt that the socket attaches to, just the circular collar part.
hope this makes sense-the collar of the bolt would be shaped like a D. after i ground it down. |
 Posted: 15:45 - 24 Oct 2008 Post subject: |
Having had a linkage bolt snap I would be dubious about putting any old one in there. They have a fair amount of load.
If you unbolt the top shock mout the you migth be able to move things far enough to remove that bolt if the shoulder is just catching. That said it is probably well worth removing the whole linkage and greasing it properly.
| stirlinggaz |
 Posted: 09:04 - 25 Oct 2008 Post subject: |
You shouldn't have to take the exhaust off.
I presume you have the back wheel out?
I'm struggling slightly with visualising it and I'm not entirely familiar with that model of VFR but you ought to be able to undo enough of the bolts in the linkage to detach it from the swingarm (or possibly detach the dog-bones from the swingarm).
You can then usually jiggle stuff around enough to either get that bolt out or remove all the other bolts and drop the shock out with the linkage still attached.
I certainly know that you can do that on my 750FV. It's the top mount for the shock that is a pain in the arse on my one. You need to dismantle half the bodywork and remove the battery box to get at it.
I have a manual for the VFR750s at home. You didn't say if it was a 750 or a 400 you're working on. If it's a 750, I can have a look at the instructions if you tell me which model you have. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stirlinggaz |
| stirlinggaz |
 Posted: 22:40 - 25 Oct 2008 Post subject: |
Far as I can see, If you have to top shock bolt undone and can detach the two "dog-bone" tie bars from either the linkage or the swingarm itself, you ought to be able to move the linkage independantly of the swingarm.
Probably just a little until the shock is removed but maybe enough to pull that bolt out?
EDIT: Since you have it suspended, would you be able to just remove the swingarm pivot and swing the whole thing out of the way? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| stirlinggaz |
 Posted: 09:27 - 26 Oct 2008 Post subject: |
| stinkwheel wrote: | Far as I can see, If you have to top shock bolt undone and can detach the two "dog-bone" tie bars from either the linkage or the swingarm itself, you ought to be able to move the linkage independantly of the swingarm.
EDIT: Since you have it suspended, would you be able to just remove the swingarm pivot and swing the whole thing out of the way? |
hi,
right you've lost me, lol
whats the "dog bone" tie bars?
as the only bolts i have removed so far is the top & bottom shock bolts (though i have left them in,loosely for now) & the furthest forward linkage bolt. ("suspension linkage front pivot bolt")
this linkage bolt came out & the front linkage link assembly moves up & down an inch or 2, freely, but wont drop all the way down as it hits the swingarm (at the bit where i presume the fitting for the centre stand goes,as its a hollow tube)
hope that makes sense.
i cant get at the rear link assembly bolts.
in theory i should just be able to lift the shock & front linkage out, right?
then worry about the rear linkage next.
the shock is still sitting in its top mount, if i just yank it back (after removing the top bolt, lol)l it should lift out right?
this im worried about, lol as it seems very tight in there.
as for removing the complete swingarm, that was my next step, as it wouldnt do any harm to replace those bearings as well, seeing as there probably the original ones & 22yrs old!
cheers,
GAZ |
| stirlinggaz |
| stirlinggaz |
 Posted: 10:45 - 27 Oct 2008 Post subject: UPDATE |
hi all,
finally removed that stubborn bottom suspension bolt.
it took a bit of jiggling about & a few taps with a hammer & punch.
& i had to grind the "collar" of the bolt head, to get it to slide all the way out.
i removed 1 of the inner spacers on the linkage & had a wee peek at the bearings & much to my surprise, they look remarkably new.
so im guessing they have been replaced at some point.
Im also presuming a bit of grease packed in there, will see it alright for a few more miles.
i only have copper grease & a pot of LM stuff, any recomendations as to what type of grease i should use?
(will check the manual & see what mr honda specifies but maybe someone could recomend a decent brand?)
after greasing, its just a matter of swapping shock units over & bolting it all back up (that'll be fun)
next on the agenda is : send the wheels off to be powdercoated & start on the front end (forks)
as this will be another 1st for me, wish me luck & await the usual stupid questions, lol
many thanks for the advice, keep it coming!
cheers,
GAZ
| stirlinggaz |
The last post was made 17 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
