Cars with Tiptronic/I-shift/DSG?
Chriss
PostPosted: 12:03 - 23 Oct 2008    Post subject: Cars with Tiptronic/I-shift/DSG? Reply with quote
In a car, I dislike the clutch pedal (if you drove with me you'd understand), what cars have a shift like Honda's I-shift (paddles, with the option of fully automatic?) Volkswagen have the DSG, what other options are there out there, and has anyone tried any of these?
TheShaggyDA: I've got 3 or 4 pairs that predate my wife, so at least 11.5 years old.
plugger147
PostPosted: 12:11 - 23 Oct 2008    Post subject: Reply with quote
Drove an alfa with paddles a while back, can't remember what model it was though. Embarassed
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
LustyLew
PostPosted: 12:18 - 23 Oct 2008    Post subject: Reply with quote
My Citroen C2 had the option of a 'flappy paddle' gearbox.
I think was something like £700 extra with the semi-auto gearbox.
It really was quite pants. When you changed gear, it took longer than doing it yourself. I stuck with the manual.
If you go for the genuine article I suspect it wont be cheap and only available on higher spec models. But I will stand to be corrected no doubt.
There is the old Tiptronic system, but this is just manual overrides on a conventional automatic gearbox. So still the inefficiencies of an auto, and sluggish gear changes. There are also the stepped CVT transmissions.
Ferrari seemed to be the first to come out with a padal gear change on a manual box. Alfa with the Selespeed 156 were the first with a system on affordable car around 2000 (Charlottes mother has one) and they also used the same system on the 147 a year or 2 later. Note that while these systems are generally pretty reliable, there is an issue with a hdeously expensive component wearing out (expect a £1500 bill at about 100k).
There are also a few cars with manual gearboxes but no clutch pedal. First modern one I know of was the Sensonic gearbox on the Saab 900 in the mid 1990s. Renault had the "Easy" transmission on the Clio (we had one for a few years and 100k). And Fiat had the Citymatic transmission on the Seicento. These systems have a normal manual gearstick but no clutch pedal. The conventional clutch is controlled by an electronic control unit.
Whosthedaddy
PostPosted: 12:27 - 23 Oct 2008    Post subject: Reply with quote
Honda Jazz with flappy paddles or auto box, complete wank.
PostPosted: 12:35 - 23 Oct 2008    Post subject: Reply with quote
But was it a proper manual box with flappy paddles, or just some overwieght slothful auto box with limited manual control? Makes a very big difference.
plugger147
That's the kiddie, It was an ok gearchange most of the time, pretty smooth and worked well when giving it some stick the only thing I didn't like was the time it took to go down more than one gear quickly.
Whosthedaddy
PostPosted: 12:38 - 23 Oct 2008    Post subject: Reply with quote
7 speed CVT auto, would change gear at 3-4000 revs of less and be so jerky. The auto was more usable than the paddles.
Cigaro
PostPosted: 12:39 - 23 Oct 2008    Post subject: Reply with quote
The VW DSG one is very good, though most of the others seem to be crap.
PostPosted: 12:40 - 23 Oct 2008    Post subject: Reply with quote
I have driven Charlottes mothers one. I also found the gear change slow, but that might just be my perception. With a normal manual box you are physically doing something which takes up the time. With the paddle type you are just sitting there waiting for something to happen. As such it wouldn't surprise me it it actually is faster than a conventional manual, but just feels slower.
Also possible that it has decided that changing down 2 gears would cause it to over rev and thus it has ignored your 2nd down change.
It probably does a better job of blipping the throttle on down changes than most drivers though.
Visitor Q
$25 whore
PostPosted: 12:46 - 23 Oct 2008    Post subject: Reply with quote
Why don't you just go for an automatic? They all suck but meh, least you can go to sleep in it.
Flappy paddles as mentioned are usually just an add on to automatics to make you feel less of a retard. 'Proper' paddle gearchange is fooking expensive.
Graham88
PostPosted: 12:50 - 23 Oct 2008    Post subject: Reply with quote
My Mum's Ford Fusion has Tip-Tronic. I think it's awful. It's slow to respond. Quite often dangerous.
Robby
Dirty Old Man
PostPosted: 13:05 - 23 Oct 2008    Post subject: Reply with quote
My smart has paddles. It's a manual gearbox with a clutch, but is normally driven in fully automatic mode.
It changes gear slow, and also has a nasty habit changing gear when you put your foot down just past the apex of a corner, or while you're going up a slow uphill bend. The advantage of the paddles or stick is that you can make it hold a gear through a corner.
Do tend to forget that I took it out of auto and drive along in 4th for ages though. Need to press a button on the gearstick to put it back into auto.
I have never heard of a fladdy paddle system that's particularly effective or reliable - seems they can be one or the other, or neither, but never both. Plain old slushbox auto with a big engine is preferable.
Finglonga
PostPosted: 13:08 - 23 Oct 2008    Post subject: Reply with quote
DSG is the best out there at the moment and faster 0-60 than the same in manual, more economical as well. Wink
Andy Sez....
F.Y.Y.F.F.
PostPosted: 13:10 - 23 Oct 2008    Post subject: Reply with quote
Not really. The Alfa system is pretty cheap. Far cheaper than a conventional auto, let alone an auto with flappy paddles. And potentially there is the option to save money by dropping the synchro mechanism from the gearbox (already has a drive by wire throttle so could easy match the engine and road speeds, double declutching itself and avoiding the need for synchro).
Madmanx
PostPosted: 13:21 - 23 Oct 2008    Post subject: Reply with quote
My wifes AMG had triptronic and it seemed pretty good until I got it stuck in sports mode and had to pay £500 for a new switch. Sad
https://i284.photobucket.com/albums/ll9/manxhornet/Hornet001.jpg
Cigaro
PostPosted: 13:30 - 23 Oct 2008    Post subject: Reply with quote
Agreed. I've driven the Golf GTTDi with it and it was so smooth, changed gear just like a conventional auto.
NSR Mick
PostPosted: 13:31 - 23 Oct 2008    Post subject: Reply with quote
And your issue is? Laughing
Madmanx
PostPosted: 13:34 - 23 Oct 2008    Post subject: Reply with quote
I grudge paying 2 days wages for a bit of plastic. Laughing
NSR Mick
PostPosted: 13:39 - 23 Oct 2008    Post subject: Reply with quote
Should have left it in sport then. Wink
Visitor Q
$25 whore
PostPosted: 14:07 - 23 Oct 2008    Post subject: Reply with quote
manxscot wrote:
paying 2 days wages
What the crap do you do Neutral
That said I've just seen the repair cost breakdown on one of our big bits of kit (a Cell Lab Qaunta SC, which is a 'Advanced Flow Cytometry with 3-Color, Coulter Volume and Side Scatter Analysis'... right Neutral) and the guy fixing it charges £150 an hour.... even for travel Neutral
Madmanx
PostPosted: 14:29 - 23 Oct 2008    Post subject: Reply with quote
Used to run a landscaping company in Edinburgh.
Now run one on The Isle of Man. Cool
NSR Mick
[Cell Lab Qaunta SC, which is a 'Advanced Flow Cytometry with 3-Color, Coulter Volume and Side Scatter Analysis
It's got to be worth £150 an hour just knowing what it does. Laughing Confused
Chriss
PostPosted: 14:39 - 23 Oct 2008    Post subject: Reply with quote
Fwiw, the reason I want a system like this is because I want a fully automatic, but the wife prefers manual. I quite liked the DSG, bug in manual mode, the gear stick was the wrong way round for both of us (don't know why, but down felt like it should be up, but was in fact, down).
I'll be looking into the Alfa option, thanks. Smile
NSR Mick
PostPosted: 14:45 - 23 Oct 2008    Post subject: Reply with quote
And her opinion counts why?? Laughing Wink
I used to swear all my cars would be manuals but after having had the Beemer for a while I dont know whether I could be bothered changing gear myself. Laughing
The last post was made 17 years, 86 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 136.6 Kb
