Identify which model senda we have just bought.
modd1uk
PostPosted: 18:51 - 23 Oct 2008    Post subject: Identify which model senda we have just bought. Reply with quote
50cc on an 03 plate if that helps, has showa USD forks and knobbly tires.
Would like to identify which model it is so i can get some parts ordered.
Ant132
PostPosted: 19:17 - 23 Oct 2008    Post subject: Reply with quote
Do the fairings give anything away - Decals etc?
1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200
modd1uk
PostPosted: 19:36 - 23 Oct 2008    Post subject: Reply with quote
Been resprayed in its time lol, its a clean bike..frame numbers match V5 etc but i can find no indication as to what model it is !
Surely these parts must be the same on say..Senda R extreme
front brake switch
front brake lever
chain adjusters
Also what plugs do they take..ive read on ebay that a Senda 99> takes a B9ES but read on another forum its a B10ES ?
Came with a JR9B but its too big for the HT lead. ( wasnt fitted just loose )
Ant132
PostPosted: 19:49 - 23 Oct 2008    Post subject: Reply with quote
To be honest, i would have thought those three parts would be the same on all the sendas. I think the main differences between them are probably brakes, tyres, forks and styling differences. Dont quote me though Wink
The JR9B is a 12mm plug, so wont even fit the head. However, if the plug is too big for the HT lead, you can just unsrew the tip of the plug. Im sure 90 degree caps require this.
Id check with the manual or the NGK website about the exact plug, its probably the owners that have found a certain heat rating works better with certain mods etc. but id stick the standard plug in and take it from there.
Ant Thumbs Up
tutton
PostPosted: 19:54 - 23 Oct 2008    Post subject: Reply with quote
Same engine as mine, pretty sure if its a 03 its running a mineralli am6. So plug needed is a BR9ES.
Just went through 4 in a week Laughing
I know the engine is different on the senda R extremes, as there like 05 bikes or my mate was and had a different engine altogether. although styling parts like that should be fine although things with critical fitting should be thought about before buying, ive bought parts for my 05 off a 03 bike, that dont fit at all Laughing
modd1uk
PostPosted: 19:58 - 23 Oct 2008    Post subject: Reply with quote
https://cgi.ebay.co.uk/DERBI-Senda-50-R-SM-95-NGK-IRIDIUM-spark-plugs_W0QQitemZ260292241961QQcmdZViewItem?hash=item260292241961&_trkparms=72%3A1301|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
I stand corrected, there it says B8ES. not B9ES
Right guys according to the NGK website..
Senda 50 / R /SM ( standard power ) takes a B8ES
Senda 50 / R / SM ( full power ) takes a B9ES
Which one is it :'(
tutton
PostPosted: 20:04 - 23 Oct 2008    Post subject: Reply with quote
Ahh well now this comes onto a bit of a issue.
NGK partfinder lists
Senda 50 / R / SM (Full power) 50+ As a BR9ES
Senda 50 / R / SM (Standard power) 50+ As a BR8ES
Personally dont know the difference between standard and full power on a 50, ive been running br9's from experiance and hasnt done any significant noticable engine damage in 10 monthsish.
modd1uk
Do i go for a B9ES or a B8ES Sad ?
swiftb
PostPosted: 20:47 - 23 Oct 2008    Post subject: Reply with quote
either will do i would of thought. Not a massive difference between them, the dimesions are the same which is the most important. (length of body etc, so not to protrude and hit piston). I have a derbi gpr50. Reccomenends b10es but i have also used b8es in past. Is the plug too big fot the plug cap or has the metal top not been removed from the plug??
tutton
PostPosted: 20:50 - 23 Oct 2008    Post subject: Reply with quote
Then save your bike from the hurt.
It does make a big difference,
The higher the number ie10 the colder the plug burns
the lower the hotter ie. br8
So if you choose the wrong plug, then your plug gets too hot and burns a hole in your piston. and that is not clever is it. Laughing
modd1uk
PostPosted: 20:51 - 23 Oct 2008    Post subject: Reply with quote
Feck me do i feel like a right noob now, ive never ever seen a plug that has a top on it, removed the top and fits in the cap now.
Altho little worried that the plug i have in my hand is # JR9B
Just ran a google search and found nothing telling me the dimensions Sad
Best off going to buy a B9ES tomorrow aint i.
swiftb
PostPosted: 20:59 - 23 Oct 2008    Post subject: Reply with quote
the b8es etc are ngk plus, its possible the one in it is a alternative manufacturers plug. Id get the ngk if i were you for the sake of about £3 then you know you got the right plug. Sweet, i would also replace the plug cap with an ngk one, again only a few quid as the orignal that came fitted to the derbis is shite. It corrodes causing misfire, non starting etc. Thumbs Up
Ant132
Altho little worried that the plug # is JR9B
Did you not read my second post at all lol. I told you about the screw on tops that spark plugs need removing in order to fit a 90 degree cap, and told you that a JR9B is a 12mm plug, thats will not in any way fit a cylinder head threaded for a 14mm 'B' plug Laughing The plug is not a short reach plug therefore you will have no problem in running these plugs, either coking up the threads or risking hitting the piston.
modd1uk
PostPosted: 21:02 - 23 Oct 2008    Post subject: Reply with quote
No its an NGK JR9B
https://www.elstars.com.au/pdf/manual/auth/ngk_spark_plugs_catalog.pdf
That right there ^^ is hella informative !
Il buy the B8ES tomorrow, shop should sell a cap too shouldnt they...this is the first restoration project ive done, using it as a major learning curve ( currently studying motorcycles to, and have some knowledge already, but ide rather look stupid and ask questions, than try it myself and fook it up )
Laugh if you will, im just being honest :p
modd1uk
PostPosted: 21:04 - 23 Oct 2008    Post subject: Reply with quote
HAHAHAHA teaches me to refresh the page !
Just refreshed page and seen your reply, your bang on about the JR being 12mm thread.
So seeing as you know your stuff..
is it B8ES or B9ES that i buy tomorrow ?
tutton
PostPosted: 21:06 - 23 Oct 2008    Post subject: Reply with quote
Quoting 5th post.
swiftb
PostPosted: 21:07 - 23 Oct 2008    Post subject: Reply with quote
thats what these forums are for aint it??? share and share alike! Surprised
modd1uk
PostPosted: 21:16 - 23 Oct 2008    Post subject: Reply with quote
Quoting 5th post.
Il quote you quoting your 5th post.
Only thing different with the 8ES and 9ES is the 9 will burn colder ?
tutton
PostPosted: 21:19 - 23 Oct 2008    Post subject: Reply with quote
Indeed that was what bike shops have come to teach me.
as today i went in asking for a br8 as my plugs were coking, they told me it wasnt recommended unless i wanted to do a piston change soon as it gets too hot Laughing
Ant132
PostPosted: 21:20 - 23 Oct 2008    Post subject: Reply with quote
A hotter plug (the 8) will foul less easily. So if you put the 9 in and it was fouling, the 8 will help. And a colder (the 9) will foul easier.
USE THE STANDARD PLUG!
modd1uk
PostPosted: 21:27 - 23 Oct 2008    Post subject: Reply with quote
Thats what we are trying to get our head round dude, as the NGK site states 8 for standard ? and 9 for full power.
Will take your advice and just get the 8. Like you said, keep it standard.
Also to save me writing another post.
Resistor covers ( HT CAP )
I know i need an LB ( 90degree and 14mm ) but what about the other numbers, i get the next ones resistance..do i want 01, 05 or 10 ? Then finally the last letter can be either. H P K M F Y Z
Wink, learning summit new everyday.
Im guessing something like LB05..F ?
Andy
swiftb
PostPosted: 21:41 - 23 Oct 2008    Post subject: Reply with quote
https://www.spark-plugs.co.uk/pages/pricing/ngk_plug_caps.htm
letter on end is terminal type this should help, lb05f should do it, least thats the one i use with a b8 or b10 plug
the cap thats on the bike now should have the resistance stamped on the side
modd1uk
PostPosted: 21:50 - 23 Oct 2008    Post subject: Reply with quote
You mean the one thats in my hand..just says what looks like " 5 k ", that could well be it.
swiftb
PostPosted: 21:57 - 23 Oct 2008    Post subject: Reply with quote
thats the one fella 5k ohm resistance. So you need a LB05f. Job done Thumbs Up
truslack
PostPosted: 22:00 - 23 Oct 2008    Post subject: Reply with quote
Don't use the JR9B! I must have left that in the box by accident.
I always used B8ES plugs in it, and it ran fine.
The last post was made 17 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 128.68 Kb
