| modd1uk |
 modd1uk Two Stroke Sniffer
| Ant132 |
 Ant132 World Chat Champion
| modd1uk |
| Ant132 |
 Posted: 19:49 - 23 Oct 2008 Post subject: |
To be honest, i would have thought those three parts would be the same on all the sendas. I think the main differences between them are probably brakes, tyres, forks and styling differences. Dont quote me though
The JR9B is a 12mm plug, so wont even fit the head. However, if the plug is too big for the HT lead, you can just unsrew the tip of the plug. Im sure 90 degree caps require this.
Id check with the manual or the NGK website about the exact plug, its probably the owners that have found a certain heat rating works better with certain mods etc. but id stick the standard plug in and take it from there.
Ant  ____________________ 1980 Suzuki TS50 ~ 1984 Honda CB400N ~ 1992 Triumph Trident ~ 1998 Suzuki Bandit 1200 |
| tutton |
 tutton World Chat Champion
 Posted: 19:54 - 23 Oct 2008 Post subject: |
Same engine as mine, pretty sure if its a 03 its running a mineralli am6. So plug needed is a BR9ES.
Just went through 4 in a week
I know the engine is different on the senda R extremes, as there like 05 bikes or my mate was and had a different engine altogether. although styling parts like that should be fine although things with critical fitting should be thought about before buying, ive bought parts for my 05 off a 03 bike, that dont fit at all  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
| modd1uk |
| tutton |
| modd1uk |
 Posted: 20:04 - 23 Oct 2008 Post subject: |
Do i go for a B9ES or a B8ES ? |
| swiftb |
 swiftb World Chat Champion
| tutton |
 Posted: 20:50 - 23 Oct 2008 Post subject: |
Then save your bike from the hurt.
It does make a big difference,
The higher the number ie10 the colder the plug burns
the lower the hotter ie. br8
So if you choose the wrong plug, then your plug gets too hot and burns a hole in your piston. and that is not clever is it.  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
| modd1uk |
| swiftb |
 Posted: 20:59 - 23 Oct 2008 Post subject: |
the b8es etc are ngk plus, its possible the one in it is a alternative manufacturers plug. Id get the ngk if i were you for the sake of about £3 then you know you got the right plug. Sweet, i would also replace the plug cap with an ngk one, again only a few quid as the orignal that came fitted to the derbis is shite. It corrodes causing misfire, non starting etc.  |
| Ant132 |
| modd1uk |
 Posted: 21:02 - 23 Oct 2008 Post subject: |
| swiftb38 wrote: | the b8es etc are ngk plus, its possible the one in it is a alternative manufacturers plug. Id get the ngk if i were you for the sake of about £3 then you know you got the right plug. Sweet, i would also replace the plug cap with an ngk one, again only a few quid as the orignal that came fitted to the derbis is shite. It corrodes causing misfire, non starting etc.  |
No its an NGK JR9B
https://www.elstars.com.au/pdf/manual/auth/ngk_spark_plugs_catalog.pdf
That right there ^^ is hella informative !
Il buy the B8ES tomorrow, shop should sell a cap too shouldnt they...this is the first restoration project ive done, using it as a major learning curve ( currently studying motorcycles to, and have some knowledge already, but ide rather look stupid and ask questions, than try it myself and fook it up )
Laugh if you will, im just being honest :p |
| modd1uk |
| tutton |
| swiftb |
 Posted: 21:07 - 23 Oct 2008 Post subject: |
thats what these forums are for aint it??? share and share alike!  |
| modd1uk |
| tutton |
 Posted: 21:19 - 23 Oct 2008 Post subject: |
Indeed that was what bike shops have come to teach me.
as today i went in asking for a br8 as my plugs were coking, they told me it wasnt recommended unless i wanted to do a piston change soon as it gets too hot  ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
| Ant132 |
| modd1uk |
| swiftb |
| modd1uk |
| swiftb |
 Posted: 21:57 - 23 Oct 2008 Post subject: |
thats the one fella 5k ohm resistance. So you need a LB05f. Job done  |
| truslack |
 truslack World Chat Champion
The last post was made 17 years, 169 days ago. Instead of replying here, would creating a new thread be more useful? |
