| rockers |
 rockers Scooby Slapper
| rotax81 |
 rotax81 Nearly there...
 Posted: 18:52 - 24 Oct 2008 Post subject: |
sometimes a bike just needs a good run to sort it out. having lights on al the time doesnt help but i dont advise against it.
get one of them optimate chargers.
batteries start degrading at around 3 years in most cases so looked after i would have thought 2 would be ok still.
it should put out over 12v and around 14v when charging (bike running over 5,000rpm)  ____________________ ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol) |
| stinkwheel |
 Posted: 08:37 - 25 Oct 2008 Post subject: |
What make and model of bike is it?
Do you have access to a multimeter?
Are you aware that your computer keyboard is fitted with a shift key, the use of which which makes your posts much easier to read by the people who can help you? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| rockers |
| alun111 |
 alun111 World Chat Champion
| stinkwheel |
 Posted: 18:59 - 25 Oct 2008 Post subject: |
What alun111 said. Check the resting voltage then check it with the engine running. Should be no less than 12v at rest and should rise to around 14v when running.
Might even be worth checking the voltage after a run (a couple of minutes after you switch off) and making sure it doesn't drop overnight. I've had them do that when a cell has been duff and they slowly discharge themselves.
All that said, rockers porobably has it right in that it isn't running for long enough to put the charge back into the battery before you reach your destination.
The only real solution to this is to take it on a longer run every so often or to hook it up to a trickle charger (such as an optimate) when it's parked.
Oh, check the battery terminals are done up tight and free from corrosion. Couple of people on here have had odd charging/starter problems related to a bad connection.
By the capitals I was meaning I find this:
| Quote: |
hi guys got a little well have allways had this problem, i brought a new battery when i my bike about two years ago, and its never seems to be holding its charge to start with after about 2-3 months it then went to having to use the kick start, the charging part of the bike must be using as after ridding the bike for abit it will work the electric start, anyone know whats wrong could it need a new battery or am i not using the bike long enuff at a time to get the battery charged up enuff- even tho i use the kick start.
i problem a mile in the morning and couple in the evening getting home and getting about, week ends im usally out and about for 15min a time on the bike. im stuck do i buy a new battery is there a way or seeing if the battery is any good or not, its a 12v battery |
Very hard to read. It appears like an amorpohous block of text. Out of interest, is English your first language or did you use an online translator?
It would scan a lot better if you'd written it like this:
| Quote: | Hi guys. Got a little -well have allways had this problem.
I bought a new battery about two years ago and its never seemed to be holding its charge to start with. After about 2-3 months it then went to having to use the kick start.
The charging part of the bike must be working as after riding the bike for a bit it will work the electric start. Anyone know whats wrong? Could it need a new battery or am I not using the bike long enough at a time to get the battery charged up enough- even tho I use the kick start?
I problem a mile in the morning and couple in the evening getting home and getting about. Weekends I'm usally out and about for 15min a time on the bike.
I'm stuck, do I buy a new battery is there a way of seeing if the battery is any good or not? It's a 12v battery. |
| Finglonga |
 Finglonga World Chat Champion
| AJ |
 AJ Nitrous Nuisance
| rockers |
| alun111 |
| rockers |
 Posted: 18:36 - 28 Oct 2008 Post subject: |
Ok i have a draper 12v charger this one
https://www.avenue35.co.uk/shopping/shopexd.asp?id=17043
Would this work or do i need a bike specific charger ?
Do you have any idea how long it could take to charge, so i could take battery out and leave over night or somthing.
I will be riding it throughout the winter have no other means of transport. |
| alun111 |
 Posted: 18:47 - 28 Oct 2008 Post subject: |
You don't need to take the battery out to charge it, just leave it on.
I'm not too sure about that battery charger. 4A constant current is deemed the maximum really. This one charges up to 6A.
If you've got the money, I'd just buy a proper bike one. If you used that one on a regular basis, it will end up cooking your battery. Bike chargers usually charge at around 1.5amps.
Something like this would be ideal. Although my mate bought me a similar charger from a bike shop last christmas for about £25 also.
Batteries hold about 12.8v maximum, so i'd say it might take around 4-6 hours at the most to charge your particular battery from the charge state it's in. ____________________ Summer: '00 Honda CB600F Hornet
Past Bikes: Lifan LF100-5 Lifan LF125-A Honda C70 |
The last post was made 17 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
