battery issues
rockers
PostPosted: 18:44 - 24 Oct 2008    Post subject: battery issues Reply with quote
hi guys got a little well have allways had this problem, i brought a new battery when i my bike about two years ago, and its never seems to be holding its charge to start with after about 2-3 months it then went to having to use the kick start, the charging part of the bike must be using as after ridding the bike for abit it will work the electric start, anyone know whats wrong could it need a new battery or am i not using the bike long enuff at a time to get the battery charged up enuff- even tho i use the kick start.
i problem a mile in the morning and couple in the evening getting home and getting about, week ends im usally out and about for 15min a time on the bike. im stuck do i buy a new battery is there a way or seeing if the battery is any good or not, its a 12v battery
rotax81
PostPosted: 18:52 - 24 Oct 2008    Post subject: Reply with quote
sometimes a bike just needs a good run to sort it out. having lights on al the time doesnt help but i dont advise against it.
get one of them optimate chargers.
batteries start degrading at around 3 years in most cases so looked after i would have thought 2 would be ok still.
it should put out over 12v and around 14v when charging (bike running over 5,000rpm) Thumbs Up
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
PostPosted: 08:37 - 25 Oct 2008    Post subject: Reply with quote
What make and model of bike is it?
Do you have access to a multimeter?
Are you aware that your computer keyboard is fitted with a shift key, the use of which which makes your posts much easier to read by the people who can help you?
rockers
PostPosted: 18:32 - 25 Oct 2008    Post subject: Reply with quote
i do have access to a multimeter yes
its kymco styker 125
shift ? put the title in capitals ? classed as shouting ?
alun111
PostPosted: 18:44 - 25 Oct 2008    Post subject: Reply with quote
You're not using your bike an incredible amount really. It could be that your charging circuit isn't working correctly though, although you haven't exactly given it enough time to charge the battery. Bikes will usually start off the button after a run as the engine is hot.
You're best buying or using a multimeter (maplins, aldi) and seeing what charge is in the battery when the bike's standing and the ignition off. If it's above 12v then start the bike and see what the meter reads then, it should be about 13/13.5. When you rev the bike it should go no higher than about 15v. Let us know the results.
PostPosted: 18:59 - 25 Oct 2008    Post subject: Reply with quote
What alun111 said. Check the resting voltage then check it with the engine running. Should be no less than 12v at rest and should rise to around 14v when running.
Might even be worth checking the voltage after a run (a couple of minutes after you switch off) and making sure it doesn't drop overnight. I've had them do that when a cell has been duff and they slowly discharge themselves.
All that said, rockers porobably has it right in that it isn't running for long enough to put the charge back into the battery before you reach your destination.
The only real solution to this is to take it on a longer run every so often or to hook it up to a trickle charger (such as an optimate) when it's parked.
Oh, check the battery terminals are done up tight and free from corrosion. Couple of people on here have had odd charging/starter problems related to a bad connection.
By the capitals I was meaning I find this:
Very hard to read. It appears like an amorpohous block of text. Out of interest, is English your first language or did you use an online translator?
It would scan a lot better if you'd written it like this:
Hi guys. Got a little -well have allways had this problem.
I bought a new battery about two years ago and its never seemed to be holding its charge to start with. After about 2-3 months it then went to having to use the kick start.
The charging part of the bike must be working as after riding the bike for a bit it will work the electric start. Anyone know whats wrong? Could it need a new battery or am I not using the bike long enough at a time to get the battery charged up enough- even tho I use the kick start?
I problem a mile in the morning and couple in the evening getting home and getting about. Weekends I'm usally out and about for 15min a time on the bike.
I'm stuck, do I buy a new battery is there a way of seeing if the battery is any good or not? It's a 12v battery.
Finglonga
PostPosted: 19:03 - 25 Oct 2008    Post subject: Re: battery issues Reply with quote
No capital letters at beginning of sentences and punctuation (as in full stops) as its a pain to read and appears like you have missed some words out as the post doesn't make any sense. I gave up trying after the first couple of lines, I was waiting for someone to translate it. Wink
Anyway, check how many Volts are going into the battery with the engine running and with the engine off. About 12.5v with engine off and 13.5+ with engine running.
Andy Sez....
F.Y.Y.F.F.
AJ
PostPosted: 20:05 - 26 Oct 2008    Post subject: Reply with quote
could be a duff battery but bikes dont charge battery's like a car's allternator does. It only maintains the charge. Test battery by putting meter across battery without any ignition on. Check voltage, then put ignition on and check voltage again if it is really low then get a new battery.
As an example my old battery read 12v with ignition off. But as soon as the ignition went on it droped down to 1.5v not even enough to light up the ignition lights.
rockers
PostPosted: 17:01 - 28 Oct 2008    Post subject: Reply with quote
Ok first of all guys I am english, just im not all that great on the witting side of it.
So i checked the battery with a multimeter, with the engine off it reads 11.45v.
checked again with the engine on it reads 12.98 with little revs it goes up to 13.34 ish.
So which is it battery or bike or neither ?
Rocky
alun111
PostPosted: 18:22 - 28 Oct 2008    Post subject: Reply with quote
Rocky
First off - have you got a proper bike battery charger? If not, go and buy one now. You will find it very useful at times. A decent one can be picked up for about £25 - one that will maintain your battery aswell as charge it - so you can leave it on over winter or whenever you're not using the bike for long periods of time.
Give the battery a full charge, then test as you did before AGAIN. 11.45v is not healthy. It may just be because you're not using the bike enough to give the battery a full charge, but it may also be because the battery is not holding a charge. Your charging circuit seems fine so far - but we'll see.
So give the battery a charge with a proper bike charger and then post your test results again.
rockers
PostPosted: 18:36 - 28 Oct 2008    Post subject: Reply with quote
Ok i have a draper 12v charger this one
https://www.avenue35.co.uk/shopping/shopexd.asp?id=17043
Would this work or do i need a bike specific charger ?
Do you have any idea how long it could take to charge, so i could take battery out and leave over night or somthing.
I will be riding it throughout the winter have no other means of transport.
alun111
PostPosted: 18:47 - 28 Oct 2008    Post subject: Reply with quote
You don't need to take the battery out to charge it, just leave it on.
I'm not too sure about that battery charger. 4A constant current is deemed the maximum really. This one charges up to 6A.
If you've got the money, I'd just buy a proper bike one. If you used that one on a regular basis, it will end up cooking your battery. Bike chargers usually charge at around 1.5amps.
Something like this would be ideal. Although my mate bought me a similar charger from a bike shop last christmas for about £25 also.
Batteries hold about 12.8v maximum, so i'd say it might take around 4-6 hours at the most to charge your particular battery from the charge state it's in.
The last post was made 17 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 77.17 Kb
