| TUBZ69 |
 TUBZ69 Trackday Trickster
 Posted: 19:00 - 24 Oct 2008 Post subject: Mechanical Bofs!! 2 rebuild probs ( 2001 zx6r) |
1. Ok so the brake system is sorted with new fluid and braided lines, ive fitted a new front wheel as the old one was bent due to the crash. The problem is that the pads seem to be stuck hard onto the disc, tbh it was a mission to get the calipers bk on the discs!! will they free up wen the bike is rolling again? because at the moment i can push the front wheel around ( whilst the bike is on the stand ) but its pretty stiff, and i can hear the pad rubbing the discs....
2. ive fitted some GB-moto rearsets, obviously on the right hadn side this includes the gear selector arm and linkage, and this is were the problem is....
Now ive heard that you need to put the little 'Oshaped' collar ( on the end of the selector arm) that slides onto the gearbox stork back in the perfect place or it will bugger the gear selection up, and you will have to keep refitting until you get it were it should be?!! is this right, as with the engine running i pulled the clutch in ( whilst the rear stand was on ) clicked into 1st gear and the wheel started spinning ( not just twitching, as they tend to do anyway) with the clutch still in?!!! wots that all about? surely the wheel should remain stationary until i start to slip the clutch and apply throttle etc...? wich makes me think ive put that Collar back incorrectly....
I just want to clarify this problems and sort them out myself if pos as i want to get it on the Dyno in december and ive got a few more bits on the way this month....
any advice welcome!!
thanx
Toby ____________________ those who risk nothing, become nothing, achieve nothing....
c90 rvf 400, vfr 400, gpz 500, Gsxr 750, R1, Zx6r.... |
| rotax81 |
 rotax81 Nearly there...
 Posted: 19:08 - 24 Oct 2008 Post subject: |
1] will be the pistons gummed up in the calipers. you need to get them out, clean them well and refit them. if its just about rubbing then its normal.
2] if your bike has been standing for a while the clutch plates are probably stuck, thats normal, most bikes do it. to free them off i do it by taping the clutch lever in and leave it running in gear on a paddock stand, it eventually frees off  ____________________ ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol) |
| quacker_boy |
 quacker_boy Cuddle Bitch
 Posted: 19:20 - 24 Oct 2008 Post subject: |
1 Could be you didn't bleed the brakes properly if at all or as Rotax says could be gunked up but this is unlikely unless you've left the bike standing for farking ages whilst you've been doing it.
2. Right hand side?! You've got a facking weird bike then. Most modern bikes have got the gear shift on the left Could be a poorly adjusted clutch, doubt it's anything to do with the collar on the linkage as they're designed to kind of roll about on the ball they're on. ____________________ wizzzard wrote: Imagine God just stopping by, tidying your front room up and then quietly letting himself out again. Statisticly more likely to happen than Korn being on here. |
| ZRX61 |
 ZRX61 Victor Meldrew
| TUBZ69 |
| Kickstart |
 Kickstart The Oracle
| TUBZ69 |
 Posted: 18:49 - 25 Oct 2008 Post subject: |
yea i doubt they would need a strip down tbh, as theve just been serviced. My brother has just informed me that he gave the levers a good squeeze the other day when the calipers were just hanging free.... well done and tbh i did wonder why i had to prize the pads apart a bit anyways to even slide the calipers on the discs themselves!!?! so mayby if i take them off again, and prize them apart completely and then put them bk? ____________________ those who risk nothing, become nothing, achieve nothing....
| Kickstart |
| TUBZ69 |
 Posted: 15:51 - 27 Oct 2008 Post subject: |
cool, well il giv it a go wednesday  ____________________ those who risk nothing, become nothing, achieve nothing....
The last post was made 17 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
