| Wise1 |
 Wise1 World Chat Champion
| rotax81 |
 rotax81 Nearly there...
 Posted: 14:47 - 25 Oct 2008 Post subject: |
time to strip them and clean them. if you do get them in they will get stuck on. thats if they are THAT hard to get back.
unless you are a wimp, im that case force them back with clever use of a screwdriver lol
also check that the reservoir is not full to the brim or it will be difficult to move  ____________________ ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol) |
| Wise1 |
 Posted: 14:49 - 25 Oct 2008 Post subject: |
nope def wont move back in, thats what I thought time to strip and clean, might as well now they are off  ____________________ Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600 |
| Itchy |
 Itchy Super Spammer
 Posted: 15:02 - 25 Oct 2008 Post subject: |
No no , unless you have the piston removal tool then you should pump the lever using a solid object on each caliper when they are out far enough to move the other pistons, else you won't be able to get the pistons out. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| alun111 |
 alun111 World Chat Champion
| FerretFing |
 FerretFing World Chat Champion
 Posted: 16:05 - 25 Oct 2008 Post subject: |
Easiest way I`ve found to push the pistons in is to put a piece of tubing (of correct diameter) onto the bleed nipple, undo it a turn or so & then push the pistons in & remember to tighten the bleed nipple up afterwards - Also, make sure you clean the exposed part of the pistons before you start or you`ll be pushing muck etc past the seals  |
| butterob |
 butterob Spanner Monkey
| mentali-juan |
 mentali-juan Scooby Slapper
| Wise1 |
The last post was made 17 years, 136 days ago. Instead of replying here, would creating a new thread be more useful? |
