Pistons on brake calipers wont move?
Wise1
PostPosted: 14:45 - 25 Oct 2008    Post subject: Pistons on brake calipers wont move? Reply with quote
I am relplacing the pads on my bike and the pistons on the calipers wont go back in far enough to get the new pads in, any ideas how to get them to go back?
Current - 2007 Suzuki Bandit GSF1250 - 1999 Suzuki TL1000R
Previous - GSXR750 SRAD, Fireblade, ZXR750, CBR600
rotax81
PostPosted: 14:47 - 25 Oct 2008    Post subject: Reply with quote
time to strip them and clean them. if you do get them in they will get stuck on. thats if they are THAT hard to get back.
unless you are a wimp, im that case force them back with clever use of a screwdriver lol Very Happy
also check that the reservoir is not full to the brim or it will be difficult to move Wink
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
Wise1
PostPosted: 14:49 - 25 Oct 2008    Post subject: Reply with quote
nope def wont move back in, thats what I thought time to strip and clean, might as well now they are off Mr. Green
Itchy
PostPosted: 15:02 - 25 Oct 2008    Post subject: Reply with quote
No no , unless you have the piston removal tool then you should pump the lever using a solid object on each caliper when they are out far enough to move the other pistons, else you won't be able to get the pistons out.
alun111
PostPosted: 15:17 - 25 Oct 2008    Post subject: Reply with quote
To the OP - sometimes it helps if you take the reservoir cap off when pushing the pistons back in. Have you tried using a g clamp? I find a good substitute is to use a set of old pads (I keep them now) and lever with two screwdrivers - one going up through the pads and one going down through the pads - lever the opposite way with each.
FerretFing
PostPosted: 16:05 - 25 Oct 2008    Post subject: Reply with quote
Easiest way I`ve found to push the pistons in is to put a piece of tubing (of correct diameter) onto the bleed nipple, undo it a turn or so & then push the pistons in & remember to tighten the bleed nipple up afterwards - Also, make sure you clean the exposed part of the pistons before you start or you`ll be pushing muck etc past the seals Thumbs Up
butterob
PostPosted: 16:17 - 25 Oct 2008    Post subject: Reply with quote
nice big screwdriver and alot of arm strength! failing that there are proper tools but they can get pricey for what they do
j1 zx6r in green
g2 zx6r trackbike Trackdays done: Mallory park, Brands Hatch Indy, Snetterton 300
mentali-juan
PostPosted: 17:21 - 25 Oct 2008    Post subject: Reply with quote
If they are no better after a strip and clean with a toothbrush and a tin of brake cleaner then I would probably replace the piston seals & bleed them.
Pump the pistons out a bit(not right out or they will fall out) and clean with toothbrush & cleaner.
Bit of red grease on the piston seals.
My old gsxr had 6 pot tokicos and were always doing this especially through winter.
Once I changed the seals(loads on 6 pots) they were ok but needed a clean now & again to keep them like that.
I am no expert though tbh.
Wise1
PostPosted: 19:45 - 25 Oct 2008    Post subject: Reply with quote
Sorted, the piston was jammed solid so I took the calipers off the front to give them a clean anyway, the piston that would not move was all dry on the inside and had seized.
Its all good now though.
Just need to bleed the front bakes tomorrow and thats it.
The last post was made 17 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 62.08 Kb
