| tutton |
 tutton World Chat Champion
| sickpup |
 sickpup Old Timer
| tutton |
| sickpup |
 sickpup Old Timer
 Posted: 18:08 - 25 Oct 2008 Post subject: |
Leave the top end alone damn you.
Side cover off so you can see a crank seal, start engine and spray easy start at it. If revs go up its leaking. |
| tutton |
 Posted: 18:19 - 25 Oct 2008 Post subject: |
Crank on right hand side?
hmm..
lookin at workshop guide it only shows how to remove crank assembly, and the only thing that could be a seal looks like bearings, pic below
https://i123.photobucket.com/albums/o297/Gfxs/untitled.png ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
Current: '02 ZX636 A1P '51 CCM R30 |
| sickpup |
 sickpup Old Timer
| tutton |
| sickpup |
 sickpup Old Timer
| tutton |
| sickpup |
 sickpup Old Timer
| tutton |
| sickpup |
 sickpup Old Timer
| tutton |
| Thom |
 Thom World Chat Champion
| tutton |
| cagiva gezzer |
 Posted: 16:20 - 27 Oct 2008 Post subject: |
Wow, that sounds tasty!
Looks like a derbi engine?
I had a senda with leaky crank seals. The first sign was the gear oil dropping, then the bike was harder to start as it lost compression.
Leak Down testing
Did the problem just start? ____________________ "because one stroke isnt enough and four strokes waste two" |
| tutton |
 Posted: 16:28 - 27 Oct 2008 Post subject: |
Ye same as the derbi senda the bike itself is a 05, running the Mineralli AM6 engine ran in the sendas and motorhispanias
I cant see gear oil leaking anywhere, and the bike always been a bit hard to start, need to get on the throttle a bit.
Well the problem has been here for a while but getting worse and worse, the local shop thought it was the needle valve bent as it was letting too much air through, that was replaced and it still happens so they think crank seals.
looked at that link
but how will i know if its crank, as i cant see that cheers ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
| cagiva gezzer |
| tutton |
| cagiva gezzer |
| tutton |
 Posted: 16:54 - 27 Oct 2008 Post subject: |
Standard filter.
Standard carb.
A dellorto phbn12
https://www.crash.no/images/phbn
is what carb it is, and i would take photos but its too dark to get any decent ones. ____________________ Past: '05 Peugeot XPS '99 Aprillia RS125 '94 FZR600R
| cagiva gezzer |
| tutton |
| cagiva gezzer |
| tutton |
The last post was made 18 years, 5 days ago. Instead of replying here, would creating a new thread be more useful? |
