my car wont staart
b1g5m0k3
PostPosted: 18:56 - 25 Oct 2008    Post subject: my car wont staart Reply with quote
i just bought a car (vauxull corsa) and now for some reason its not starting.. and fuel isnt reaching the engine.
how can i fix this? whats wrong.
yandy_yay
PostPosted: 18:58 - 25 Oct 2008    Post subject: Reply with quote
erm its got 4 wheels Twisted Evil
Thats just not right Laughing
past bikes: (20 years ago) cg-125 (wriiten off), C-50 (thrashed n' finnaly scrapped), CZ-125 (nicked - never recovered, insurance payout was more than i paid for it !!!)
Current bikes: GN 125(now sold), Divvy 600s.
steve32
PostPosted: 18:59 - 25 Oct 2008    Post subject: Reply with quote
try looking for a fuel cut off switch
suzuki GSX 600F katana .: ~my bike up for sale~ :.
CBT = Completed
DAS= Working on it - theory test = Passed
chrisw
PostPosted: 19:04 - 25 Oct 2008    Post subject: Reply with quote
Age, engine size, any modifications?
Clanger
Stirrer
PostPosted: 19:07 - 25 Oct 2008    Post subject: Re: my car wont staart Reply with quote
b1g5m0k3 wrote:
i just bought a vauxull corsa and now for some reason its not starting. how can i fix this? whats wrong.
Well, for a start it's a Vauxhall Corsa.... Laughing
b1g5m0k3
PostPosted: 19:13 - 25 Oct 2008    Post subject: Reply with quote
1995, 1.2l no mods. (cept alloys)
Mr Nice Guy
PostPosted: 19:14 - 25 Oct 2008    Post subject: Re: my car wont staart Reply with quote
Dumb question, but is there fuel in it? Don't trust the idiot light.
Suzuki GSX-R750K4 ~ Mivv GP
b1g5m0k3
PostPosted: 19:15 - 25 Oct 2008    Post subject: Reply with quote
i thought this at first but i put about 2 quids of petrol in, and nothing!
surely thats enough to get it started?
Mr Nice Guy
PostPosted: 19:16 - 25 Oct 2008    Post subject: Reply with quote
Is it turning over alright?
b1g5m0k3
PostPosted: 19:17 - 25 Oct 2008    Post subject: Reply with quote
yes
Ariel Badger
PostPosted: 19:21 - 25 Oct 2008    Post subject: Reply with quote
Two quids worth may have been enough in 1972, now it is just a splash in the bottom of the tank. Bung a gallon in and then bleed it through the system and try.
b1g5m0k3
PostPosted: 19:23 - 25 Oct 2008    Post subject: Reply with quote
hm.. but the fuel gauge is over the red line so surely its enough? plus there was already a bit in there
Mr Nice Guy
PostPosted: 19:36 - 25 Oct 2008    Post subject: Reply with quote
Choked fuel filter?
Does the car have any recent service history that would indicate when this was last changed?
How long ago did you buy the car and was it a private sale or a used car dealer?
b1g5m0k3
PostPosted: 19:37 - 25 Oct 2008    Post subject: Reply with quote
private sale, and the day after i bought it.. it wouldnt start Sad
Drew This post is not being displayed because the poster is banned. Unhide this post / all posts.
Cigaro
PostPosted: 20:39 - 25 Oct 2008    Post subject: Reply with quote
No, not on an injected car. There is not enough fuel pressure to prime the system. I had the same thing on a Scirocco that run out of petrol and then just wouldn't start.
Put a tenner's in, get a set of jump leads, and turn the fucker over until it starts.
Other than that, check the fuel pump fuse. It's most likely to be the in-tank pump that isn't working.
b1g5m0k3
PostPosted: 20:52 - 25 Oct 2008    Post subject: Reply with quote
its actualy not fuel injected
chrisw
PostPosted: 20:55 - 25 Oct 2008    Post subject: Reply with quote
Unless you have changed the engine it will be. Vauxhall dropped carbs a before the Corsa was put into production.
Cigaro
PostPosted: 20:58 - 25 Oct 2008    Post subject: Reply with quote
I suspect you're wrong there smoke.
Either way, check the in-tank pump. There should be a fuse in the in-cabin fusebox. If that's gone it won't go anywhere.
Are you SURE there's no fuel to the engine? Thinking it may be flooded instead?
beast rider
PostPosted: 21:03 - 25 Oct 2008    Post subject: Reply with quote
Check the dizzy.
My old corsa had the same problem where it ran fine then didn't wanna know and it turned out the electrodes in the dizzy had blown apart.
b1g5m0k3
its not flooded. either way i will call the AA out 2moro morning and see what the problem is, HOPEFULLY its not serious.. and wont cost me more than 50 quid to fix Very Happy
st3v3
PostPosted: 21:47 - 25 Oct 2008    Post subject: Reply with quote
Check the spark plug's. Laughing
Seriously though, does sound like it's a fuel issue and if filling it doesn't solve the issue then syphon it out and use it for the bike or flog it again.
How much was the car?
temporary
PostPosted: 22:19 - 25 Oct 2008    Post subject: Reply with quote
Take the main petrol line going to the engine off and turn on the ignition/try to start it,if petrol gushes out of the pipe you know you're fuel pump is working.
You should also hear a buzz from the fuel pump when you turn on the ignition.
If you get no fuel with ignition on check the fuel pump relay (common fault on vauxhalls).Usually just removing it,cleaning the terminals then re-fitting gets it going temporarily.(otherwise get a few spares from the scrappy)
If that doesn't work get a tester bulb and make sure power is getting to the fuel pump.If power is getting there try putting a direct live and earth to it.If it's not fucked you should hear it buzz for a few seconds while it pressurized the fuel.
Couple of things their for you to try.
Also as has been said,make sure their's plenty go go juice in.They dont like being run low.
EDIT:
The fuel pump relay is usually either under the bonnet in the relay holder/main fuse box,or in the n/s kick panel.(side trim where passengers left foot would be)
Also usually in their is the fuel cut-off switch.They do sometimes mess up.
Phoenix
Twisted Firestarter
PostPosted: 03:38 - 26 Oct 2008    Post subject: Reply with quote
Bit of petrol or easy start straight into the intakes, if it runs on that then cuts out you know you've got fuel starvation rather than another problem.
b1g5m0k3
PostPosted: 08:52 - 26 Oct 2008    Post subject: Reply with quote
ok just had the AA round and they say its the fuel pump.. how much is one of those Smile
The last post was made 17 years, 341 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 121.76 Kb
