lever bodge
chillpill
PostPosted: 20:01 - 25 Oct 2008    Post subject: lever bodge Reply with quote
short of it is god knocked over my nsr and snapped the front brake lever , ive ordered a new one but need a quick bodge for the next few days
was thinking off taking it to a welders just as a temp fix , anyone got any other good bodge ideas incase that dosent work out ?
cheers Thumbs Up , alex
st3v3
PostPosted: 20:08 - 25 Oct 2008    Post subject: Reply with quote
Doubt welders would do a good job, considering what it's made out of.
Maybe shove a thin screwdrive across the break and use duct tape at either end to hold it in place?
Unless it's broken at the start of the lver, in which case a quick bodge might be out of the question.
PostPosted: 20:09 - 25 Oct 2008    Post subject: Reply with quote
How much is left on the stump? Could you attach a bit of threaded bar to it using a couple of jubilee clips or some cable ties? Could you slide a bit of tubing over the stump and hold it in place with a small bolt right through it?
It would need to be a very good welder to patch up an alloy brake lever. I've seen it done but it takes a lot of skill.
chillpill
PostPosted: 20:28 - 25 Oct 2008    Post subject: Reply with quote
the lever snapped about half way down
i did think about putting a bar across holding the two peices together but because its a curved lever it wouldnt hold very well
stinkwheel i think i might take a hacksaw to the mop and try your tubing and a bolt idea , sounds like a good one Thumbs Up
cheers for the replies Thumbs Up
rotax81
PostPosted: 20:33 - 25 Oct 2008    Post subject: Reply with quote
just mind when bodging it as when you need to squeeze the lever hard is when it may fail Shocked
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
stirlinggaz
PostPosted: 09:34 - 26 Oct 2008    Post subject: Reply with quote
HI,
used a screwdriver & duct tape before.
handle of screwdriver pointing outwards & blade flat against stump of brake lever.
loads of duct tape to hold it on (used a bit of wire 1st as i had no cable ties)
made a decent temp repair & lasted til the replacement came through the post,
cheers,
GAZ
Cigaro
PostPosted: 09:41 - 26 Oct 2008    Post subject: Reply with quote
I'd get a piece of hollow metal tubing, slide it over the stump of the lever and then drill through and secure it with several bolts.
I wouldn't trust duct tape and cable ties on a front brake lever. Clutch, maybe, but not brakes.
chillpill
PostPosted: 11:47 - 26 Oct 2008    Post subject: Reply with quote
my thoughts exactly , it was bad enough driving home with half a lever Confused
well the mops 6inches shorter now and the brake is useable for the mean time, cheers for teh help all Thumbs Up Karma
stirlinggaz
PostPosted: 16:59 - 26 Oct 2008    Post subject: Reply with quote
Hi,
i must point out that the duct tape & wire was all i could get my hands on (thanks to a passing motorist) as the brake lever snapped when the bike fell over at a petrol station (v.embarrassing) , so it was just a temp. repair to get me to work & back home.
but i did use it again, in the same state , the following day & it coped fine.
the motorist that helped me, had a role of wire which we wrapped all the way along the blade of the screwdriver & tied it extremely tight with pliers..
then just covered it up with duct tape.
was very effective for the 2 trips that i used it for. (until the replacement lever arrived)
cheers,
GAZ
The last post was made 17 years, 120 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 60.46 Kb
