honda superdream
tommyr
PostPosted: 18:01 - 31 Oct 2008    Post subject: honda superdream Reply with quote
i just picked up my first bike to learn on, a honda superdream and when i picked it up it started up first time (probs cos he warmed it up beforehand) and rode fine. half way home though and it wouldnt rev past 8k, and seems to sometimes bog down even lower, around 5 -6k. now later on, it wont start off the electric start, i can just hear the solenoid clicking. iv checked the usual plugs, filters and hav cleaned the carb out but nowt is working. whats the next step?
Gashead Harry
PostPosted: 18:07 - 31 Oct 2008    Post subject: Reply with quote
This might sound daft but is the choke on?
98' Honda CG125W --- 03' Yamaha DT50SM (Gone!) --- 05' (55) Suzuki GS500 K5
tommyr
PostPosted: 18:11 - 31 Oct 2008    Post subject: Reply with quote
nope, choke defo isnt on. i checked to see if it was sticking open aswel, but seems ok.
luke27
PostPosted: 18:19 - 31 Oct 2008    Post subject: Re: honda superdream Reply with quote
Battery?
Needs charging or replacing perhaps.
rotax81
PostPosted: 18:29 - 31 Oct 2008    Post subject: Reply with quote
i would imagine he jump started before you arrived as the bike was warm.
sounds like battery, if not then loose connection/s, earth or a worn starter motor.
as for the running issues i would be looking at them awful carbs they had, perhaps the diaphragms have gone in the tops.
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
tommyr
PostPosted: 19:43 - 31 Oct 2008    Post subject: Reply with quote
is it very stupid to connect my car via jump leads to the bike. i assume it shud be ok because they are both 12v?
alun111
PostPosted: 20:05 - 31 Oct 2008    Post subject: Reply with quote
It's ok to do that, but general consensus is don't have the car engine running. I'm assuming it is 12v like you say, and not 6v.
as for the starter problem, take the terminal connections off of your battery and clean them up with sandpaper until they're shiny, then fit them back nice and tight! Find the starter relay and make sure everything is clean and tight on that, make sure there are no broken wires. If it still doesn't work after that then try this:
Short out the starter relay by contacting the two terminals together with a screwdriver/spanner etc. It will spark so be prepared. Put the screwdriver/spanner on across SOLIDLY, to make sure you get adequate connection. If the starter motor turns it's either the relay, connections or the starter button. It can also be other things.... If the starter doesn't turn, check all connections between the relay and the battery and the relay and the starter.
Good luck!
The last post was made 17 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 51.21 Kb
