Lost my only key.
Purplepill
PostPosted: 11:55 - 02 Nov 2008    Post subject: Lost my only key. Reply with quote
Hi, I somehow lost my only key to the GPZ the other day so I really need to know a few things,
Firstly, is the little number stamped on the ignition shroud the key code so I can get another made from that? if not will a kawasaki dealer be able to find it out from my V.I.N number or anything similar? or if I pushed my bike to a local locksmith is it possible to have a new one made from my ignition? whats the cheapest easyest way to get a new key made for it?.....
Secondly, until I can get a new key sorted, which of the 5 wires going to the ignition do I need to join to get it running and with lights? Because I need the bike today and for work on monday before I can get a new one sorted
Everytime something good happens to me, something else finds a way of kicking me square in the bollocks
''He had the confidence of a baby-goat dared to tickle a t-rex's nutsack''
NiteMare
PostPosted: 12:07 - 02 Nov 2008    Post subject: Reply with quote
a decent locksmith should be able to sort you a key out ....
i'm not sure but i think your keycode should be on the ignition barrel, you'll probably have to remove it to find it tho ...
no idea on the requirements for hotwiring your bike, i'd have to look personally
it ain't broke...
i ain't fixed it enough
PostPosted: 12:37 - 02 Nov 2008    Post subject: Reply with quote
[edit] attachment didn't work, but I'll send it as a PM instead; don't really want a "hotwiring 101" lesson on here Smile
stirlinggaz
hi,
i dunno about the code, if there is a code stamped/engraved onto the barrell, then you might be able to get a key cut with this number.
but the way i done before, was remove the complete ingition barrell,
take it to any locksmith or bike shop & they can send it off to keys galore, who will cut you 2 new keys for around 30 quid. takes about a week, what with post etc.
whilst i was waiting on the barrel & keys, i jusy ran around with no ignition switch!
i fitted an in- line switch hidden away where no-one could see it.
& used a couple of extra chains & locks (due to having no steering lock & besides, if anyone found the switch they could have just ridden it away! & no insurasnce payout-was a bit para that week, lol)
hardest bit was getting the security bolts out from the barrell.
at least you will then have 2 keys.
cheers,
GAZ
Purplepill
PostPosted: 13:51 - 02 Nov 2008    Post subject: Reply with quote
Cheers guys, got it working using shaggy's method (cheers) only problem is its been sitting for a few days so iv killed the battery trying to start it Mad tryed bumping it a few times until I was knackered, then realised even if I did get it running, I cant actually put any more fuel in it Crying or Very sad .
I really dont want to be messing about with shear bolts so I guess im screwed unless I find this key.
Jamie S
PostPosted: 13:58 - 02 Nov 2008    Post subject: Reply with quote
You might just be surprised, Both the ER-5 and the old Cb750, I am/was able to open with a flat bladed screwdriver, or any old key.
Worth a try.
Purplepill
PostPosted: 14:04 - 02 Nov 2008    Post subject: Reply with quote
Yeah just tryed it, no luck Mad Just realised I cant even charge the battery either because I cant get the seat off Evil or Very Mad
Jamie S
PostPosted: 14:32 - 02 Nov 2008    Post subject: Reply with quote
Seems your stuffed until you get a new key then. Wink
PostPosted: 14:40 - 02 Nov 2008    Post subject: Re: Lost my only key. Reply with quote
Look in the yellow pages for auto-lock smiths.
They should be able to do it and will come to you for a charge - possibly a little more on a Sunday.
Bikes are very easy to hot-wire, but convention has it that it isn't discussed on public forums, for obvious reasons.
Purplepill
PostPosted: 14:47 - 02 Nov 2008    Post subject: Reply with quote
So he can make a new key from my ignition you mean? Have you got a rough idea on price (on a monday rather than sunday) because im quite skint as usual:oops: Its looking like the best option though.....Left my mobile in my work van aswell and dont have a house phone which really isnt helping Rolling Eyes
Cheers.
PostPosted: 14:51 - 02 Nov 2008    Post subject: Reply with quote
I paid £70 to have it done for my car with them coming to the car. £55 for a bike (on a weekend, think a Sunday) taking just the ignition barrel to the bloke's house a few years ago.
Have to ring up to check, however... skype or similar?
Purplepill
PostPosted: 15:00 - 02 Nov 2008    Post subject: Reply with quote
Cheers G, im push biking to my old dears pub in a bit lol so il use her phone to get some prices Thumbs Up maybe even some sympathy money Smile .
stirlinggaz
PostPosted: 17:24 - 02 Nov 2008    Post subject: Reply with quote
"really dont want to be messing about with shear bolts so I guess im screwed unless I find this key."
hi,
shear bolts come out fairly easy with a dremel.
cut a slot in the head with a cutting disc & use a long straight screwdriver or impact driver to remove the security bolt.
cheers,
GAZ
PostPosted: 17:33 - 02 Nov 2008    Post subject: Reply with quote
On the more fuel thing; I lost the key for my CRM125 at one point.
Took the tank off and then the fuel tap off and filled from there.
Unfortunately I only got about halfway around the off-road route we were riding, so ended up calling on Bendy and Cassy to bring me some fuel to repeat the procedure, so we could finish the route.
stirlinggaz
PostPosted: 17:58 - 02 Nov 2008    Post subject: Reply with quote
hi,
found that a few fuel caps open with small bladed screwdriver on my multi-tool, with no damage, some seat locks too.
though, im currently having problems with the seat lock on the vfr, key wont turn it, neither will a screwdriver...stumped
cheers,
GAZ
Finglonga
PostPosted: 18:35 - 02 Nov 2008    Post subject: Reply with quote
NiteMare wrote:
a decent locksmith should be able to sort you a couple of keys out ....
Fixed it.
Andy Sez....
F.Y.Y.F.F.
Purplepill
PostPosted: 16:12 - 03 Nov 2008    Post subject: Reply with quote
Right, tommorow my sphincter's getting torn to the sum of 95 quid+V.A.T Sad Tryed alot of places and its the cheapest I could get (there coming to my house though) some bastards even tryed charging 150 minimum Shocked I guess they've got people bent over really though.....
Oh well, live and learn, its DEFINATLY worth the 5-10quid to get a spare cut rather than thinking just because youve got zip pockets you wont loose it Embarassed
Cheers everyone.
stirlinggaz
PostPosted: 18:54 - 03 Nov 2008    Post subject: Reply with quote
hi,
f*ck paying that!
i'd have persevered & taken the ignition barrel off, hotwired it & got keys cut from the barrel for 30 quid.
but im tight like that.
cheers,
GAZ
The last post was made 17 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 98.64 Kb
