Help please needed piaggio nrg
bullz712
PostPosted: 16:35 - 01 Nov 2008    Post subject: Help please needed piaggio nrg Reply with quote
Just had to buy a second hand engine fitted it in scooter and it started but i have to put full throttle on just to get it to just over tick over revs no power at all full throtle maybe does about 1000 revs not even enough to turn back wheel ..
Any ideas of whats wrong i would be very gratefull..
cheers
darren
prawny1
PostPosted: 18:25 - 01 Nov 2008    Post subject: Reply with quote
Check you haven't left any pipes of the carb, or the vacuum tap or connected any pipes the wrong way around.
Is it turning over as it should (not to hard on the kicker or to slow on the starter)?
bullz712
PostPosted: 20:46 - 01 Nov 2008    Post subject: hiya Reply with quote
just checked all pipes and they seem ok and yeah it starts easy enough im lost really
prawny1
PostPosted: 20:52 - 01 Nov 2008    Post subject: Reply with quote
where did you get the engine from?
If its from a breakers i would take it back and get it exchanged, most breakers will swap engines if they are faulty.
What was wrong with your origional engine?
bullz712
PostPosted: 20:54 - 01 Nov 2008    Post subject: hi Reply with quote
got it from a m8 it run ok in his scooter but it been standing about 2 months
prawny1
PostPosted: 21:00 - 01 Nov 2008    Post subject: Reply with quote
Do you know if he put any oil down the barrel whilst it was stood?
Some people do to stop things rusting up internaly, the problem is when you come to run the engine again it can take a while to burn the excess oil off.
did you refit your origional carb or did the engine come with one on?
If you used the carb that came with the engine it might want cleaning out because any petrol that was left in it would have dried out and probably blocked something internaly, or you could fit your own carb of the old motor.
bullz712
PostPosted: 21:02 - 01 Nov 2008    Post subject: hi again Reply with quote
not sure if he put oil down but i have fitted it with the carb it come with so i will change it and put my carb back on it tomorrow and will coem back on tomorrow evening earlish and let you know maybe you might be able to give me some more advice then if i dont cure the problem.....
prawny1
PostPosted: 21:05 - 01 Nov 2008    Post subject: Reply with quote
Okay bud, I might not be online untill later on tomorrow, i have to go and clear all my tools of my pals workshop as he is moving.
bullz712
PostPosted: 21:07 - 01 Nov 2008    Post subject: Reply with quote
ok m8
thanks for all your help so far and hope you can carry on helping if i need it.. i owe you on.. Cool Wink
bullz712
PostPosted: 20:07 - 02 Nov 2008    Post subject: hi again Reply with quote
hi ive managed to get it sorted think cable was trapped somewhere .. but now when i put full throttle on it revs up to around 7000-8000 revs but thier doesnt seem to be much pulling power could it be advisable to put some carb cleaner through or something like that if so what and how much, also if not what could be causeing the lack of power to go..
thanks bullz712
The last post was made 18 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.13 - MySQL Queries: 13 - Page Size: 62.71 Kb
