Haynes Translations
Noxious89123
PostPosted: 13:26 - 03 Nov 2008    Post subject: Haynes Translations Reply with quote
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer anticlockwise.
Haynes: This is a snug fit.
Translation: Clamp with molegrips then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Clamp with molegrips then beat repeatedly with a hammer.
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start. Now you are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (giant economy size).
Haynes: Retain tiny spring...
Translation: PINGGGG - "Jesus, where the hell did that go?"
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part (and maybe a plaster or two).
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead are throbbing then clamp with molegrips then beat repeatedly with hammer.
Haynes:Weekly checks...
Translation: If it isn't broken don't fix it.
Haynes:Routine maintenance...
Translation: If it isn't broken, it's about to be. We warned.
Haynes:One spanner rating.
Translation: An infant could do this... so how did you manage to **** it up?
Haynes:Two spanner rating.
Translation: Now you may think that you can do this because two is a low, teensy weensy number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you).
Haynes:Three spanner rating.
Translation: Make sure you won't need your motor bike for a couple of days.
Haynes:Four spanner rating.
Translation: You're not seriously considering this are you?
Haynes:Five spanner rating.
Translation: OK - but don't ever carry your loved ones in it again.
Haynes:If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahahahahahahaha.
Haynes:Compress...
Translation: Squeeze with all your might, jump up and down on it, throw it at the garage wall, then find some molegrips and a hammer...
Haynes:Inspect...
Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"
Haynes:Carefully...
Translation: You are about to suffer deep abrasions.
Haynes:Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes:Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes:Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes:Refitting is the reverse sequence to removal.
Translation: Yeah, right. But you swear in different places.
Haynes:Prise away plastic locating pegs...
Translation: Snap off...
Haynes:Using a suitable drift...
Haynes:Everyday toolkit
Translation: RAC Card & Mobile Phone
Haynes:Apply moderate heat...
Translation: Unless you have a blast furnace, don't bother.
Alternatively, clamp with molegrips then beat repeatedly with hammer.
Haynes:Index
Translation: List of all the things in the book, bar what you need to do.
map
Mr Calendar
PostPosted: 16:43 - 03 Nov 2008    Post subject: Reply with quote
I'm sure many, if not all, posted at sometime before but being so true they always raise a smile.
Ariel Badger
PostPosted: 19:54 - 03 Nov 2008    Post subject: Reply with quote
Very true, we did a cam belt on a Rover car this weekend using a Haynes book. Useless thing, we just ignored the book and worked it out ourselves after being mislead for the third time.
Faraz
PostPosted: 20:56 - 03 Nov 2008    Post subject: Reply with quote
From RS50 haynes:
Use extreme caution when working around parts
of the engine and exhaust, or brakes, which may
remain hot for a long time.
Avoid the temptation to hold any part of the motorcycle
in your mouth.
Laughing Laughing
'56 Yamaha MT-01
'05 Nissan 350z Roadster GT
3 words dude.. Fvck. Yes.
Noxious89123
PostPosted: 21:19 - 03 Nov 2008    Post subject: Reply with quote
Wtf, lol!
PostPosted: 01:22 - 04 Nov 2008    Post subject: Reply with quote
I have seen that so many times before, it is still funny mind!
aaronb74
PostPosted: 11:44 - 04 Nov 2008    Post subject: Reply with quote
lol, brilliant.
I really hate the "...as described in Chapter 7" bits, especially when the Chapter 7 bit is 3 times as big a job as what you're trying to do Neutral
Current bike - 2006 ZX6R
tutton
PostPosted: 13:27 - 04 Nov 2008    Post subject: Reply with quote
REP worthy Thumbs Up Laughing
Fisty
PostPosted: 17:02 - 04 Nov 2008    Post subject: Reply with quote
There is a full chapter in my haynes manual for the zx9r on adjusting the drum brakes.
Fatter and faster than Fret
ajacko
PostPosted: 19:00 - 04 Nov 2008    Post subject: Reply with quote
aaronb74 wrote:
lol, brilliant.
Yeah, 'Firstly, remove engine (as described in chapter 3).' Yeah, thanks for that, i'd only allowed myself 20 minutes to do the job as it only appeared to have 6 simple steps.
Current bike:- Suzuki GS500 '02 plate. Next bike CBR600F or GSX650F. I'll leave the race reps to the kids.
www.xembly.com
djr
PostPosted: 19:08 - 04 Nov 2008    Post subject: Reply with quote
Faraz wrote:
From RS50 haynes:
in your mouth.
Laughing Laughing
Where abouts is that Crying or Very sad ?
Faraz
PostPosted: 20:09 - 04 Nov 2008    Post subject: Reply with quote
My bad, its in the workshop manual.
'56 Yamaha MT-01
ZRX61
Victor Meldrew
PostPosted: 22:42 - 04 Nov 2008    Post subject: Reply with quote
Once replaced the driveshafts & associated gubbins on a Citroen CX Safari with the hinderance of a Haynes Book Of Lies.
It stated the job took 4 hours.....
They were close, it took 3 fucking hours to do the first one the way they said it had to be done. Rolling Eyes
& then another 40 minutes to do the second one after an infusion of common sense & mechanical apptitude. Cool
binge
Emo Kiddy
PostPosted: 23:09 - 04 Nov 2008    Post subject: Reply with quote
Haynes is handy for Torque settings and Bolt lengths etc. Thats about it really.
Again, Just about every procedure ends with a pair of mole grips and a hammer. So its pointless even trying to go by the haynes. Where they have nice photos of them stripping down a brand spanking new car, Which isnt rusty. Laughing
Hutchysrs50
PostPosted: 00:53 - 05 Nov 2008    Post subject: Reply with quote
Laughing Laughing Just Lol.... Laughing Laughing
Gilera SC 125 - Current
krebsy
PostPosted: 12:47 - 05 Nov 2008    Post subject: Reply with quote
My Haynes VFR manual was pretty useful for taking the back off the bike. The first thing it said about the number plate hanger was "Note: These nuts WILL have seized so you will need to dismantle the number plate light assembly to get at the screw heads, rather than just undoing the 2 nuts above the wheel."
How true that was. How much a pain it was as well to get at the screws as there's no space to get a screwdriver in, I had to resort to a screwdriver hex bit and pliers to rotate them an eighth of a turn, then repeat for about 15 mins.....
K.
1280 x 1024.
Bishbash
PostPosted: 16:05 - 05 Nov 2008    Post subject: Re: Haynes Translations Reply with quote
Brilliant Laughing Laughing . But this one is so true to my maintenance.
GodzGift
PostPosted: 12:40 - 06 Nov 2008    Post subject: Reply with quote
LOL
Bike Level: Amateur | CBT Passed
There is a gap of 1 year, 137 days between these two posts...
Tango675
PostPosted: 09:07 - 24 Mar 2010    Post subject: Reply with quote
Just got sent this... but someone beat me to posting it.... by a long time Smile
Somebody give that windup merchant a torque wrench..
27cows
PostPosted: 09:33 - 24 Mar 2010    Post subject: Reply with quote
Haynes: workshop manual
Translation: incomplete, inaccurate, badly written, poorly explained imitation of proper workshop manual
cloric_tzr
PostPosted: 16:58 - 25 Mar 2010    Post subject: Reply with quote
ooo i looove the old rovers haha 214 216 220 scars from all of them!!! i got plent of naff gearboxes if any1 wants them!
i dumped my girlfriend the other day! she wouldnt act out one of my fantasy's. all i wanted her to do was come home from work, catch me fucking her sister and join in!!! miserable bitch!
My wifes so ugly, the only thing that goes down on her
Is the internet connection.
PostPosted: 17:12 - 25 Mar 2010    Post subject: Re: Haynes Translations Reply with quote
Noxious89123 wrote:
Haynes: Pry...
Haynes:Carefully...
Thumbs Up Laughing
HAMMER: Originally employed as a weapon of war, the hammer is nowadays
used as a kind of divining rod to locate expensive parts not far from the
object we are trying to hit.
STANLEY KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on boxes
containing seats and motorcycle jackets.
ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their
holes until you die of old age, but it also works great for drilling
mounting holes just above the brake line that goes to the rear wheel.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more dismal
your future becomes.
MOLE-GRIPS/ADJUSTABLE WRENCH: Used to round off bolt heads. If nothing
else is available, they can also be used to transfer intense welding heat
to the palm of your hand.
OXYACETELENE TORCH: Used almost entirely for lighting various flammable
objects in your garage on fire. Also handy for igniting the grease inside
a brake-drum you're trying to get the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older cars and motorcycles,
they are now used mainly for impersonating that 9/16 or 1/2 socket you've
been searching for for the last 15 minutes.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted part you were drying.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprint whorls and
hard-earned guitar callouses in about the time it takes you to say,
"F...."
HYDRAULIC FLOOR JACK: Used for lowering car to the ground after you have
installed your new front disk brake setup, trapping the jack handle firmly
under the front wing.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a
hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbour to see if he has another hydraulic
floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog-doo off your boot.
BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten
times harder than any known drill bit.
TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile
strength of ground straps and brake lines you may have forgotten to
disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that
inexplicably has an accurately machined screwdriver tip on the end without
the handle.
BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid
from a car battery to the inside of your toolbox after determining that
your battery is dead as a doornail, just as you thought.
AVIATION METAL SNIPS: See hacksaw.
INSPECTION LIGHT: The mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which is not otherwise found under cars at night. Health benefits aside,
its main purpose is to consume 40-watt light bulbs at about the same rate
as 105-mm howitzer shells during the Battle of the Bulge. More often dark
than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; can also be used, as
the name implies, to round off Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a fossil-fuel
burning power plant 200 miles away and transforms it into compressed air
that travels by hose to a pneumatic impact wrench that grips rusty bolts
last tightened 30 years ago by someone in Dagenham, and rounds them off.
PRY (CROW) BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses 1/2 inch too short.
Face.
PostPosted: 17:26 - 25 Mar 2010    Post subject: Reply with quote
double post sorry.
Face.
Good to know it's not just me. Laughing
Changing the piston on the gp100 was a mare when the garage forgot to put in two stroke oil.
The last post was made 16 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.17 - MySQL Queries: 13 - Page Size: 139.86 Kb
