Bike will fire up using Easy start, but won't run after?
Jamie S
PostPosted: 17:10 - 03 Nov 2008    Post subject: Bike will fire up using Easy start, but won't run after? Reply with quote
Hi, Got a bit of a problem with my piaggio Zip field bike, I haven't bothered to run it for a few months, so today I cleaned the plug, stuck fresh fuel in, ect, then tried to start it, no luck. Right, So I checked for a spark: Yep, nice strong blue spark, but the spark plugs dry?
So I grab a can of easy start, spray in to the inlet, and it fires up, runs for a moment, then cuts out. So it appears the problem lies with the fuel side of things, I cleaned the carb, and tried again, but still to no avail.
What do you think? why isn't fuel getting to the spark plug ?
Thanks for taking the time to read this, Jamie.
Whosthedaddy
PostPosted: 17:15 - 03 Nov 2008    Post subject: Reply with quote
Blocked or kinked fuel lines, blocked fuel filter?
PostPosted: 17:16 - 03 Nov 2008    Post subject: Reply with quote
Is there any form of fuel pump on it?
Whosthedaddy
PostPosted: 17:17 - 03 Nov 2008    Post subject: Reply with quote
You have got the fuel tap on haven't you?
Paddy Blake
PostPosted: 17:19 - 03 Nov 2008    Post subject: Reply with quote
Hi Jamie.
I had the same problem and it turned out the fuel tap was turned off. Sad
Is there a vacuum hose going to the tap that might be off or broke.
Paddy.
Jamie S
PostPosted: 17:37 - 03 Nov 2008    Post subject: Reply with quote
Hi, I thought this, so took a bit of fuel line, and an old tank and had it sat next to the bike "remotely", so that I could rule out fuel filters, and the fuel tap, the float bowl is filling nicely, and I also checked that the flow hight is right with a clear bit of piping (got to love carbs that have a drain screw and pipe attachment)
There is no Fuel pump Keith , no. Sad
Thanks, Jamie. Thumbs Up
PostPosted: 17:42 - 03 Nov 2008    Post subject: Reply with quote
Is there any compression? Unless the jets are thoroughly blocked then that is the only likely thing I can think of.
Jamie S
PostPosted: 17:44 - 03 Nov 2008    Post subject: Reply with quote
Yep, a lot of compression, blows my finger off the plug hole.
It's very odd, might try cleaning the carb (again)
ravingriley
PostPosted: 18:31 - 04 Nov 2008    Post subject: Reply with quote
Hi,
Take your carb off and make sure your reeds are all okay. Not bent or splitt.
They could be deciding not to let fuel into your engine.
Were all born individual . . Don't die a copy
Sleep When Your Dead!!!!!!!
Sachs Madass Smile
The last post was made 17 years, 337 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 60.16 Kb
