| Jamie S |
 Jamie S World Chat Champion
 Posted: 17:10 - 03 Nov 2008 Post subject: Bike will fire up using Easy start, but won't run after? |
Hi, Got a bit of a problem with my piaggio Zip field bike, I haven't bothered to run it for a few months, so today I cleaned the plug, stuck fresh fuel in, ect, then tried to start it, no luck. Right, So I checked for a spark: Yep, nice strong blue spark, but the spark plugs dry?
So I grab a can of easy start, spray in to the inlet, and it fires up, runs for a moment, then cuts out. So it appears the problem lies with the fuel side of things, I cleaned the carb, and tried again, but still to no avail.
What do you think? why isn't fuel getting to the spark plug ?
Thanks for taking the time to read this, Jamie. |
| Whosthedaddy |
 Whosthedaddy Super Spammer
| Kickstart |
 Kickstart The Oracle
 Posted: 17:16 - 03 Nov 2008 Post subject: |
| Whosthedaddy |
| Paddy Blake |
 Paddy Blake World Chat Champion
 Posted: 17:19 - 03 Nov 2008 Post subject: |
Hi Jamie.
I had the same problem and it turned out the fuel tap was turned off.
Is there a vacuum hose going to the tap that might be off or broke.
Paddy. |
| Jamie S |
 Posted: 17:37 - 03 Nov 2008 Post subject: |
| Whosthedaddy wrote: | Blocked or kinked fuel lines, blocked fuel filter? |
Hi, I thought this, so took a bit of fuel line, and an old tank and had it sat next to the bike "remotely", so that I could rule out fuel filters, and the fuel tap, the float bowl is filling nicely, and I also checked that the flow hight is right with a clear bit of piping (got to love carbs that have a drain screw and pipe attachment)
There is no Fuel pump Keith , no.
Thanks, Jamie.  |
| Kickstart |
| Jamie S |
| ravingriley |
 ravingriley Borekit Bruiser
 Posted: 18:31 - 04 Nov 2008 Post subject: |
Hi,
Take your carb off and make sure your reeds are all okay. Not bent or splitt.
They could be deciding not to let fuel into your engine. ____________________ Were all born individual . . Don't die a copy
Sleep When Your Dead!!!!!!!
Sachs Madass  |
The last post was made 17 years, 337 days ago. Instead of replying here, would creating a new thread be more useful? |
