| Hunter |
 Hunter Nitrous Nuisance
 Posted: 17:47 - 03 Jul 2002 Post subject: need help with clutch and tightspots on chain |
Hello guys..
I have a couple more things to sort out with my bike before its ready for the road again.
First.. the clutch.. when I shift into gear the first time after a start (the first start of the day).. the bike kinda jumps forward although its in neutral.. warming up the engine does not seem to help much either.. the clutch seems to engaged although the I'm holding it in. Does anybody else have this same issue?
Second.. the chain.. I have a nasty tight spot on my chain.. and its difficult to adjust the tension correctly cause it really slacks off on one side and become too tight on the other.. this happened after I cleaned it up with kerosene... any ideas?
lastly.... how on earth do you lubricate cables? and what oils are best for the job? I don't hae any special tool for it.. only an oil can!
Thanks for taking time to read.. now please reply! |
| Mole |
 Mole Scooby Slapper
 Posted: 18:33 - 03 Jul 2002 Post subject: |
Hi Hunter,
Same as me M8, no way out! You need a new chain and/or sprocket set
The most likely is the chain, but it's not woth changing just the chain, change the lot M8
Mole ____________________ V4's R Us!!!
Mole, the oldest 18year old on the block ! |
| Mole |
 Mole Scooby Slapper
| Hunter |
| Hunter |
 Posted: 18:49 - 03 Jul 2002 Post subject: |
Keith.. any thoughts on resolving the above?  |
| McJamweasel |
 McJamweasel BCF Junkie
| Hunter |
 Posted: 16:29 - 04 Jul 2002 Post subject: |
Hey Keith! How do you tell if you have an O'ring chain?
Also.. can I service the RC valve without removing the engine (I.e. lowering the engine)? Do I need replacement gaskets if I service the RC valve?
Is there any service recommended for the servo motor? or should I just leave the bugger alone!  |
| Hunter |
 Posted: 13:10 - 05 Jul 2002 Post subject: |
Thanks Keith!
The reason I wanted to have a look at the RC valve was because (I had actually posted this elsewhere!)...
The other day I was checking the RC valve.. when i found that once in about 3-6 times when I rev the engine (upto 4000 or so) and cut-off using the Engine kill switch.. I expected a short whirr (buzzing noise) from the servo.. but.. I heard a longer whirr ( twice as long as the the usual whir you get from the RC valve).
It seems like on certain occasions the Servo gets a bit confused!! and whirrs a while longer than usual. Not sure why! Any Ideas?
cheers!  |
The last post was made 23 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
