Indicator distance
ravingriley
PostPosted: 00:09 - 06 Nov 2008    Post subject: Indicator distance Reply with quote
I have got some really nice indicators that i orded of the internet and made some really nice brackets for them at work.
when i mount them they are going to alot closer together than tey originaly where, does this matter ?.
Is there any sort of ligallity on the distance apart they are from each other ?
Were all born individual . . Don't die a copy
Sleep When Your Dead!!!!!!!
Sachs Madass Smile
MattHirst
PostPosted: 00:25 - 06 Nov 2008    Post subject: Reply with quote
Well i believe you can get E marked intergrated rear indi's and rear light...and they are basically next to each other.
So no, i don't think there is a legal distance they have to be Razz
ravingriley
PostPosted: 00:55 - 06 Nov 2008    Post subject: Reply with quote
Perfect !
Cheerz mate
Sachs Madass Smile
t121anf
PostPosted: 09:14 - 06 Nov 2008    Post subject: Reply with quote
there are regulations for cars, not sure on bikes.
sickpup
Old Timer
PostPosted: 09:16 - 06 Nov 2008    Post subject: Reply with quote
E mark applies to the bulbs and lenses. Yes there is a minimum distance outlined in construction and use regs. Possibly find what they are from the SVA test.
Mr.Everready
PostPosted: 09:39 - 06 Nov 2008    Post subject: Reply with quote
But no minimum distance is needed for the MOT, the indicators need to be on either side of the bike though.
Sir Black Pig
PostPosted: 14:30 - 06 Nov 2008    Post subject: Reply with quote
I have been after an integrated tail light for some time now, the best answer to date is ......
Either side of the centre line,
However, until I get an MoT Station to confirm this for me, I am not spending out on the integ unit.
In short ask your local MoT'er
Eurotrip 2009
Sportugal 2010
PostPosted: 14:39 - 06 Nov 2008    Post subject: Reply with quote
(B) A solo motor bicycle having an engine exceeding 50 cc and first used on or after 1st April 1986-
(1) Front indicators:
300 mm
(2) Rear indicators:
240 mm
From https://www.opsi.gov.uk/si/si1989/Uksi_19891796_en_12.htm#nsch7
Mr.Everready
PostPosted: 15:49 - 06 Nov 2008    Post subject: Reply with quote
If you're so unsure why don't you ask the mot'er yourself ?
I've yet to hear of anyone on any forum who has one to be refused an MOT. As I said anyway it is not part of the mot check, just that they work.
I have also to hear of anyone getting grief from the plod because of them. As posted above they may be against the statuatory requirements but you be very very unlucky for a random plod to know these.
Sir Black Pig
PostPosted: 16:09 - 06 Nov 2008    Post subject: Reply with quote
Yes I will, I have spoken to a few mechanics and custom bike builders, none of them can SEE a roblem, however, as yet I haven't been able to speak to my local MoT guy - very difficult to get hold of on the phone.
Eurotrip 2009
Sportugal 2010
NiteMare
PostPosted: 16:34 - 06 Nov 2008    Post subject: Reply with quote
if you look closely you'll see my indicators, i bent the rules a little bit Mr. Green
https://i259.photobucket.com/albums/hh311/NiteMare_08/2008_05260013.jpg
it ain't broke...
i ain't fixed it enough
Sir Black Pig
PostPosted: 09:17 - 07 Nov 2008    Post subject: Reply with quote
NiteMare, I trust you have had no MoT issues with those wee fellas
Eurotrip 2009
Sportugal 2010
uniuk2000
PostPosted: 20:35 - 07 Nov 2008    Post subject: Reply with quote
----The precise position and angle of visibility of direction indicators are not part of this inspection, but they must be on each side of the longitudinal axis of a solo machine. If a side car is attached, the indicators must be on opposite sides of the combination.Motorcycles first used before 1 September 1965 may be fitted with direction indicators showing a WHITE light to the front and a RED light to the rear.-----
This is an extract from:-
https://www.ukmot.com/bike_1-5.asp#Text_top
NiteMare
PostPosted: 21:52 - 07 Nov 2008    Post subject: Reply with quote
none at all Mr. Green ...
construction and use rules may be different tho, depending on year of first registration
it ain't broke...
Sir Black Pig
PostPosted: 09:34 - 12 Nov 2008    Post subject: Reply with quote
uniuk2000 and NiteMare, Cheers guys Thumbs Up
Eurotrip 2009
Sportugal 2010
The last post was made 17 years, 302 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 89.08 Kb
