How do you know when your carbs need balancing?
UnknownStuntm...
PostPosted: 12:25 - 06 Nov 2008    Post subject: How do you know when your carbs need balancing? Reply with quote
As above - I get what I would describe as a lumpy tickover after a few seconds. And if it's cold (like, less than 10 degrees) outside it's a bugger to start and keep going. Really have to tickle the throttle verrrry gently to get some heat in there...
Oh, and choke makes very little difference. If anything it appears to be a little over eager to dump fuel in.
Bike's an 02 hornet 6 btw Thumbs Up
Bezzer
PostPosted: 13:11 - 06 Nov 2008    Post subject: Reply with quote
Unbalanced you get irregular tickover and it's a bit lumpy at low revs, as you open it up it becomes less relevant and unnoticeable. Be worth balancing just to eliminate that from your problems but probably not a carb problem if everything was OK before the damp/cold weather arrived. Possibly it's damp affecting the HT leads/connections until the warmth of the running engine dries them out, give them a good wipe down and seal connections with a waterproof grease or silicone and try that.
Barry_M2
PostPosted: 14:26 - 06 Nov 2008    Post subject: Reply with quote
Rolling Eyes Exactly what he said! Wink Thumbs Up
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
The last post was made 17 years, 343 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 35.8 Kb
