Carb mixture screw
joop200789
PostPosted: 15:10 - 06 Nov 2008    Post subject: Carb mixture screw Reply with quote
can any tell what it does when you turn the screw clockwise, and unclockwise, because i cant remenber to save my life,
and also roughly how many turns is it on a rs125
hope that makes sense
cheers
Thom
PostPosted: 15:42 - 06 Nov 2008    Post subject: Reply with quote
If we're on about the mixture screw as apposed to the idle screw then it's going to alter the amount of fuel:Air being taken into the carb.
I believe increased turns out (anticlockwise) will increase fuelling resulting in a richer mix and turns in (clockwise will lean off the mix) decreasing fuelling.
Or perhaps it's allowing less air in when unscrewed and more air in when screwed in although i think my first answer was right.
joop200789
PostPosted: 15:47 - 06 Nov 2008    Post subject: Reply with quote
cheers for that i had your first answer in my head, but my grandad had the other one in is, so i was checking first
cheers
PostPosted: 16:46 - 06 Nov 2008    Post subject: Reply with quote
My RX-S was the opposite to that. I unscrewed the screw (anti-clockwise) and the mixture became leaner.
luke27
PostPosted: 17:24 - 06 Nov 2008    Post subject: Reply with quote
Depends on carb design
https://hondanighthawks.net/carb14.htm
stirlinggaz
PostPosted: 18:24 - 06 Nov 2008    Post subject: Reply with quote
hi,
depends on whether its the 28mm or 34mm carb.
one has an air adjust screw, t'other has a mixture adjust screw
cheers,
GAZ
joop200789
PostPosted: 23:56 - 06 Nov 2008    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
its the 28mm, which as it got?
cheers
The last post was made 17 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 57.45 Kb
