| Knacker |
 Knacker World Chat Champion
 Posted: 11:43 - 07 Nov 2008 Post subject: SRAD problems |
Right bit of a problem here guys
I was riding to work yesterday and wasnt exactly ragging it but as i got into town the bike seemed to be really sluggish, and the exhaust sounds shite it sounds like a big fart almost sounds like its gutless and the air is just falling out, Well you no what i mean it sounds shit. But if you knock it down 1 and it would still do it but then pull eventually. After work it started and ran perfectly went a longer way home to see if it was just the bike didnt like short journeys was going down the dual carriageway and happend to see an R6 And was bobbing along and it started doing it again.
When it starts playing up the bike is around 75/80 degrees and theres plenty of oil in it
Just wondering if you guys have had any similar problems or if you have any ideas on what it could be
Pisses me off as i like to think i look after my bike really well  ____________________ Current: Gsxr 600 Srad - GS125 - DT125
Previous: K1 GSXR 1000 |
| Davie_G71 |
 Davie_G71 World Chat Champion
| Kickstart |
 Kickstart The Oracle
| the grim reaper |
 the grim reaper World Chat Champion
| D O G |
 D O G World Chat Champion
 Posted: 12:29 - 08 Nov 2008 Post subject: |
Ok.
My SRAD used to do exactly the same thing, ran like a dog unless you were giving it some stick, deterioroated so much that it just would cut out at sustained low revs, and then would not start.
I did the following to 'fix' it:
- Strip and clean carbs
- Change CDI
- Swapped plugs/leads
- Attacked it with a multimeter to find an electrical fault.
None worked.
Cylinder #2 was always cutting out (from feeling the downpipes as Kickstart said).
It used to stink of petrol too.
I eventually lost it, and took it to a garage.
The guy found that the fuel pump was continually pumping, oversupplying fuel to the carbs, which then was forced through into #2 cylinder (since it was the closest to the fuel line entry), flooding it. New fuel pump & relay/switch solved the problem.
If it stinks of fuel and it is #2 cylinder (2nd from the left as you sit on it) which cuts out, I would bet my ass this is the problem.
The guy I sold it to still says it's boggy low down, but it really needs setting up now, and I don't think the SRADs' motor will evre be smooth allthe way through - my 1991 FZR 600 pulls smoother than the SRAD ever did. |
| Steve-D |
 Steve-D World Chat Champion
 Posted: 12:43 - 08 Nov 2008 Post subject: |
Should of bought a Honda  ____________________ www.southwestbikers.com
Tristan The said 'Dunno what my pace will be like, fastish slow puncture on the rear and if I go too fast I risk my 'keys' falling out' |
The last post was made 17 years, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
