How do i shrink bmp files?
owdamer
PostPosted: 13:59 - 07 Nov 2008    Post subject: How do i shrink bmp files? Reply with quote
How do i reduce the filesize of a bmp file? I can easily reduce jpegs, but I cant find anything that will do the same for bmp's.
Suggestions pls?
neil.
PostPosted: 14:09 - 07 Nov 2008    Post subject: Reply with quote
You can use something like Photoshop or The GIMP to reduce the bit depth of those files, say to 8 bit (256 colours) which will help with the file sizes, but they won't look as good due to using less colours. Or, if you want lossless compression of a bitmap file, convert it to a PNG file, which is smaller but retains all the data.
Or just compress the file to a zip/rar/whatever?
nick.h
PostPosted: 14:10 - 07 Nov 2008    Post subject: Reply with quote
A crude method I use (and you can too if your on windows) is Powertoys for Windows XP, there an image resizer which is operated on the right click.
Nick
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
truslack
PostPosted: 14:19 - 07 Nov 2008    Post subject: Reply with quote
Irfanview would probably do it, or use it to convert it to JPG.
PostPosted: 18:10 - 07 Nov 2008    Post subject: Reply with quote
Pix resizer does it...
Probably one of the easiest progs on the market...
EDIT:
Sorry i read the question wrong Embarassed
DRZ-400sm
Clanger
Stirrer
PostPosted: 19:35 - 07 Nov 2008    Post subject: Reply with quote
pdf or zip.
daz_d_biker
PostPosted: 19:41 - 07 Nov 2008    Post subject: Reply with quote
Very easy way I find is to convert it to JPG. Simply right click to edit in paint, then save as and change the file type to '.jpg' in the drop down bar!
Daz.
"bikes are replaceable - but a complete nutter aint."
owdamer
PostPosted: 09:27 - 08 Nov 2008    Post subject: Reply with quote
Interesting ideas theree guys, but none have worked. The pix resizer and powertoys actually increased the file size.....
I can't change it to a jpeg because it has to remain a bmp.
Its a signature file for mozilla thunderbird email. It only allows bmps..
bazza
PostPosted: 10:56 - 08 Nov 2008    Post subject: Reply with quote
Use an html sig and include any image format you want. Well, except for .bmp.
https://www.freeemailtutorials.com/mozillaThunderbird/emailSignature.cwd
Just tested this and it works. Thumbs Up
owdamer
PostPosted: 13:06 - 08 Nov 2008    Post subject: Reply with quote
Cheers for that, I'll have a butchers at it when i'm back at work on monday. I'm using a bmp at the mo as the IT guy told me thats all you could use. I just nicked his sig files and edited it in paint to put my name on it instead of his. Bit limited to what you can do at work, They've deleted all software off all pcs and just given us open office, mozilla & firefox. I'm surprised they've not got rid of windows as well.
The last post was made 17 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 64.69 Kb
