Kickstarting a Honda CG125
Newbiker0507
PostPosted: 10:32 - 10 Nov 2008    Post subject: Kickstarting a Honda CG125 Reply with quote
I've recently bought a 1998 CG125 and I have yet to ride it properly since it starting it is such a ballache. Sometimes it will start on the first kick, then I'll let it run for a couple of minutes, ride up the street and then it will stop. After it stops, restarting it is nigh on impossible for me. The choke is always out when I try and start it, and the throttle is always on a little bit too, but it never seems to start on tap.
Any advice?
PostPosted: 11:07 - 10 Nov 2008    Post subject: Reply with quote
Shouldn't need to have the throttle open to start it, especially when it's warm. Could be that you're flooding it when the motor's warm, so it doesn't want to start.
Try it with just the choke, or even half choke.
Whosthedaddy
PostPosted: 11:08 - 10 Nov 2008    Post subject: Reply with quote
Down the road it probably wont need the choke.
Try kicking it over without and see if that helps.
virus
PostPosted: 11:16 - 10 Nov 2008    Post subject: Reply with quote
If your mechanically competent, get a haynes manual and adjust the valve clearances.
If they are too far out, it will be a bugger to start, most CGs start first kick with the valves set right.
John
own: 81 xs1100g...
luke27
PostPosted: 13:45 - 10 Nov 2008    Post subject: Reply with quote
John
You do not need a Haynes to adjust the valve clearance.
The Honda CG125 website tells you how to do it.
https://hondacg125.awardspace.com/
jingeroo
PostPosted: 19:49 - 10 Nov 2008    Post subject: Reply with quote
You should only need the choke for about ten seconds or maybe twenty if its really cold. Probably need to keep revving it when the choke is on or it'll die. My cg wont idle on choke. When it dies try starting without choke with some throttle. If your riding it with choke on you'll have to rev between gear changes to keep it going.
multijoy
PostPosted: 10:26 - 11 Nov 2008    Post subject: Reply with quote
With my '99 cg, I need full choke once in a blue moon, if that.
Try half when you'd automatically go to full (It's got a mid position, if you've not noticed- quite easy to just go straight up with it. Down = off, mid =half, up = full).
There was a thread a while back, try the search, had a good diagram about it. CG125 choke is an actual choke, rather than something to increase the idle speed which is why you'd treat it a bit differently to what you may be used to .
daywalker
PostPosted: 13:12 - 11 Nov 2008    Post subject: Reply with quote
my cg (1991 brazilian)doesnt like starting on choke unless its freezing cold, it usually starts with out choke first kick but i do need to keep a few revs on untill it warms up slightly(only a couple of minutes) then its fine all day long.
old people are like slinkys.........there not much use but they make you smile when you push em down the stairs!!!!!!!!
if it's got wheels or breasts it's gonna cost you money!
Newbiker0507
PostPosted: 15:04 - 13 Nov 2008    Post subject: Reply with quote
thanks guys...the help worked perfectly.
Newbiker0507
PostPosted: 22:27 - 22 Nov 2008    Post subject: Reply with quote
It only ever starts on half choke or no choke...even in immense cold. Is this normal?
Whosthedaddy
PostPosted: 13:43 - 23 Nov 2008    Post subject: Reply with quote
Sounds ok, I wouldn't knock it to be honest.
Gashead Harry
PostPosted: 13:46 - 23 Nov 2008    Post subject: Reply with quote
Thats spot on. Never had to use choke yet on mine.
98' Honda CG125W --- 03' Yamaha DT50SM (Gone!) --- 05' (55) Suzuki GS500 K5
The last post was made 17 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 70.27 Kb
