Best budget alarm?
Darth
PostPosted: 12:34 - 11 Nov 2008    Post subject: Best budget alarm? Reply with quote
Dont want to spend a fortune as the bike really didn't cost me very much but would like something that will wake me up if any pikeys decide to try and walk off with my bike during the night. Ease of fitting/ setting up also a priority. All suggestions and recommendations greatly appreciated Smile
PostPosted: 12:35 - 11 Nov 2008    Post subject: Reply with quote
A few of my mates have used the Cyclone alarm without any problems. Can be a bit tricky to wire up I've heard though.
Personally I think the money's better spent on physical security and a tracker, but it's your choice. Wink
SlimRick
PostPosted: 12:39 - 11 Nov 2008    Post subject: Reply with quote
https://img.dailymail.co.uk/i/pix/2007/05_02/rottweiler270507_468x396.jpg
PostPosted: 12:46 - 11 Nov 2008    Post subject: Reply with quote
They stop working after a couple of weeks. Think you have to feed it or something, but that gets expensive.
the grim reaper
PostPosted: 12:51 - 11 Nov 2008    Post subject: Reply with quote
Get a big chain and an alarm disc lock. Cheap alarms go wrong and also drain your battery, I've removed loads of alarms in my time and the cheap ones go wrong the most often.
At least if your disc lock alarm goes wrong, you can take it off and throw it away.
I still reckon there's a market for a subtle sensor pad type alarm, waterproof and can be incorporated into a flor mat or similar. Wire that into an in-house alarm and you could be warned without the thieves being any the wiser.
Grim
Darth
PostPosted: 12:56 - 11 Nov 2008    Post subject: Reply with quote
Have it tied down to a ground anchor with a decent chain but more wanted something to make a noise if anyone tried to move it - will look into disc alarms. Cheers Smile
PostPosted: 13:05 - 11 Nov 2008    Post subject: Re: Best budget alarm? Reply with quote
All of the cheap alarms on ebay seem to be pretty similar.
Bofh5
PostPosted: 13:19 - 11 Nov 2008    Post subject: Reply with quote
I bought the Cyclone Alarm C-11 a few months back and its been fine so far.
The imobiliser and alarm both work a treat and the siren is very loud.
i've also got a disc lock for when i'm out and a chain for at home.
Nothings gonna stop a pro but for your average pikey scrote should be ok.
At least if someone tries to nick it the screaming alarm should make their ears bleed and give you warning so you can re-educate them with barbara the baseball bat Twisted Evil
(L)users...Disk space is to good for them.
Bikes: Honda 50 / CB125-TDC / 93 CBR600 F2 (Stolen & Trashed) / 2001 SP-1 (Sold) / 95 CBR600 F3
Finglonga
PostPosted: 13:20 - 11 Nov 2008    Post subject: Reply with quote
Piece of pi$$ to get past with the outlay of £2 for a piece of beef to keep them occupied for a few minutes.
As said Disc alarm if you just want to know if anyone is tampering. Wink
Andy Sez....
F.Y.Y.F.F.
Mudskipper
PostPosted: 13:51 - 11 Nov 2008    Post subject: Reply with quote
If you want one of the cyclone ones, I've got one of the 20 quid ones I bought last winter, never fitted it. You could have it for tenner plus post if you want. Thumbs Up
edit: This is now sold, but thanks for the (surprising amount of!) queries by pm Thumbs Up
map
Mr Calendar
PostPosted: 14:36 - 11 Nov 2008    Post subject: Reply with quote
I've been toying with the idea of the Hawk alarm - click here but haven't got around to it yet.
https://www.hawkcaralarm.com/images/MC-01v2.gif
click on image for link
Under £25 for either motorcycle version it's certainly affordable.
Darth
PostPosted: 16:58 - 11 Nov 2008    Post subject: Reply with quote
Thanks for the offer but have decided a disc lock alarm is the way to go for me - reckon if i bought yours it would probably end up in my shed til this time next year too!
MinhDinh
PostPosted: 17:19 - 11 Nov 2008    Post subject: Reply with quote
my friend bought a 60 quid alarm and it cost 250 to fit lol. the mechanics actually said it took them 8 hours and should have charged him more. they also said it would be a lot easier to break into then a datatool alarm.
Hit the G spot. Wink
PostPosted: 17:24 - 11 Nov 2008    Post subject: Reply with quote
Is it one with remote start? Might be interested if no one else is.
And if mechanics took 8 hours to fit a cheap alarm, they are probably not very competent, I'd say.
Alex-RS
PostPosted: 18:28 - 11 Nov 2008    Post subject: Reply with quote
That's the one i've got, easy to fit, tilt sensor, adjustable sensitivity and very loud siren. Promotion here I come Very Happy
The Tot
PostPosted: 00:46 - 12 Nov 2008    Post subject: Reply with quote
Cyclone alarms are good until they fry two of your batteries when you try and plug in the stater bypass for the remote start. I think it was a duff relay but we could never get to the end of it. It was crap enough to fry and drain 2 Yuasa batteries within a matter of 2 months so be very careful when you want to chop into your wiring loom. Best bet is to just run the alarm parallel with the battery and not have an immobiliser! Just have a good disk lock like a motrax vishas instead to do the immobilising. But for 20 quid, the cyclone alarms do the job
Never argue with autism
Bofh5
PostPosted: 08:31 - 12 Nov 2008    Post subject: Reply with quote
i never bothered with the remote start cr@p as it seems utterly pointless other that to show off.
I spliced mine into the ignition after the fuse which is blown so the bike can only start with the remote.
Battery has been ok but i commute daily so it always gets a good run at least once a day.
PostPosted: 09:15 - 12 Nov 2008    Post subject: Reply with quote
Bofh5 wrote:
i never bothered with the remote start cr@p as it seems utterly pointless other that to scare your work mates.
Corrected for you Wink.
I actually found it quite useful to pre-warm the bike, so I didn't have to go down stairs, across the car park, then sit for ages, or these days I'll start it, ride to near the door then come back in and get my stuff and go back out.
With the remote start I could start the bike at 5:25 from the window in the testing lab; then be walking out the building on the dot of 5:30 and riding out of the gate at 5:31.
Bofh5
PostPosted: 09:25 - 12 Nov 2008    Post subject: Reply with quote
point taken but i always leave my bike in gear and it needs a bit of throttle to keep going from cold.
PostPosted: 10:13 - 12 Nov 2008    Post subject: Reply with quote
Yea, I have to be careful to make sure I don't leave it in gear, especially when parked near shiny cars.
Would some times leave choke on as appropriate, though (not that I've tried yet) that should be an advantage with FI bikes which tend to start and stay running much better.
The Disapproving Brit
PostPosted: 10:45 - 12 Nov 2008    Post subject: Reply with quote
My Cyclone C11 works a treat. I never bothered to wire in the remote start, yet oddly enough it works anyway. I queried it with the website I bought it from, and apparently they activate the remote start before they send it, so you don't have to wire it in.
The remote start is actually very useful - I just leave the exhaust poking out from under the cover, and I can start the bike up from indoors and leave it to warm up while I'm getting ready. It also has entertainment value for making random people jump as the bike they're walking past spontaneously bursts into life. Best to only do this with a front-heavy bike on the centre stand though, just in case some chav knocked it into gear while you were away.
The only downside is that I'm now constantly pulling into fuel stations, only to realise that I can't open the tank because the keys are still at home.
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
Azonicben
PostPosted: 10:58 - 12 Nov 2008    Post subject: Reply with quote
Remote start got disconnected very quickly on mine when i rode to matlock minus a key + fob
started bike, kitted up, wheeled bike out of garage, shut door, rode off, got to matlock, in gear, sidestand down, BUGGER! I`ve left the keys in the garage.
I had the huatai pager alarm on mine no probs at all apart from the tool operating it Mr. Green
https://cgi.ebay.co.uk/Motorbike-Motorcycle-Alarm-REMOTE-PAGER-Immobiliser-KIT_W0QQitemZ280280940674QQcmdZViewItem?hash=item280280940674&_trksid=p3286.c0.m14&_trkparms=72%3A1299|66%3A2|65%3A12|39%3A1|240%3A1318
Same as that, but i bought from a place in the uk Thumbs Up
Bofh5
PostPosted: 13:30 - 12 Nov 2008    Post subject: Reply with quote
well mine just earned itself a couple of brownie points Laughing
parked up in reading town (by the library for the locals) and on return to the bike a group of chav scum strokers is plodding along dragging knuckles the usual sh!te.
as they reach the bike park they slowed and were "inspecting" each bike kicking the tyres etc.
so i slowed and watched keyfob in hand and as one of them squatted down to inspect my bike set off the alarm.
Twisted Evil little f@cker nearly shat himself and the others pulled their baggy jeans up nearly tripping over themselves to get away.
so as a deterrent it works pretty good for 20 quid
PostPosted: 14:25 - 12 Nov 2008    Post subject: Reply with quote
Will a remote start alarm start my MZ? Laughing
virus
PostPosted: 15:00 - 12 Nov 2008    Post subject: Reply with quote
No amount of buttons will make an MZ idle. Laughing
For the real cheapskates, heres what I used to alarm my old CG.
https://www.maplin.co.uk/Module.aspx?ModuleNo=99097
Wire it in on a switch into the horn circuit, If youve got it set right it will set the horn off when you take it off the sidestand.
Works well in combination with
https://www.morrisgarage.com/vespa/stebel_compact.jpg
John
own: 81 xs1100g...
The last post was made 17 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 133.1 Kb
