MZ Question: Blowing head gasket
PostPosted: 13:46 - 11 Nov 2008    Post subject: MZ Question: Blowing head gasket Reply with quote
Hello,
As many of you know I am now the proud owner of an MZ ETZ 301 Saxon Fun. I have a couple of minor issues with it - and they *are* minor considering the bike cost £270!
First of all, there is a slight stain on one of the cooling fins on the engine block. It happens to be the fin that is below the head gasket. I believe the head gasket may be blowing a little. If it is, it is a little strange as the bike starts and runs OK, in fact I rode it to work this morning. I tried tightening the head nuts to the specified torque (19lbft believe it or not) but they were already tight. Is there anything I can do as a bodge fix to stop it from blowing? Or will I need a new head gasket (the owner says he replaced it recently and I believe him as I have the old gasket...)?
Secondly, and this may be related to the above, but the bike doesn't idle. I have to keep the revs up a bit with the throttle. This isn't too much of a problem, but it means that I need to be on the ball and stay on the throttle all of the time. Would a leaking head gasket cause this? At the moment I plan to take the carb off and give it a clean to make sure it isn't a blocked idle jet.
The bike also has another issue that I'm not too bothered about, and that is the kick start spring is not tensioned. The guy told me he just didn't know how to do it. The bike starts fairly easily and so its not much of an issue, but it means I have to use a piece of wire to hold the kick start in place after I have started the bike. I just mention this because its a bit of a ballache to start the bike if it has died because it doesn't idle! If I can cure the idle problem then I will be happy!
Thanks,
Mark.
PostPosted: 14:18 - 11 Nov 2008    Post subject: Reply with quote
You just identified pretty much all the problems you get with that bike.
1) Probably is leaking a little oil from the head gasket or it could be blowback of leakage from the exhaust header. If it's just a little, I wouldn't bother.
If it is a bigger leak, whip it off and either replace the head gasket or throw it in the bin and refit the head without one. If it has already been binned, you might want to take the barell off and lap the head in or just bung some gasket goo on there.
EDIT: Replacing the head gasket on an MZ 2-stroke takes approximately 3 minutes and requires the use of one tool.
2) They were designed to not idle properly so you keep blipping the throttle at a standstill to ensure it gets a steady supply of oil. I believe they need a bigger idle jet to fix this.
3) I'm pretty sure the kickstart return spring is under the cover rather than in the middle of the engine. It's probably broken or missing or could have been fitted incorrectly.
Now for the best bit.
Head gasket £2.50
Kickstart return spring £5.59
Clutch cover gasket £4.62
Available from www.mz-b.de website includes full set of exploded diagrams of all parts of the bike.
You send them a parts request using their online form, they email you back with a price and availability, you decide if you want to place the order.
They do this to avoid misunderstandings as English is not their first language.
I have used MZ-b many times and they are every bit as efficient as you'd expect a German motor spares company to be.
PostPosted: 14:38 - 11 Nov 2008    Post subject: Reply with quote
I was secretly hoping that you would respond Stinkwheel, because I knew you'd come up trumps!! Very Happy
it is just a little.
Thats crappy as the throttle is quite heavy and I arrived at work this morning with cramp in my right hand where I had been holding the throttle slightly open.
The dude I bought the bike off of says its all there, he had to fix the gearchange return spring. When he put the bike back together he couldn't figure out how to tension it, so he didn't bother.
stinkwheel wrote:
Head gasket £2.50
Available from www.mz-b.de website includes full set of exploded diagrams of all parts of the bike. You send them a parts request using their online form, they email you back with a price and availability, you decide if you want to place the order. They do this to avoid misunderstandings as English is not their first language. I have used MZ-b many times and they are every bit as efficient as you'd expect a German motor spares company to be.
Maybe if I place an order I can practice my German. Head gasket must be Kopf Dichtung or something...
Thanks Stinkeeee! Very Happy
Robby
Dirty Old Man
PostPosted: 14:41 - 11 Nov 2008    Post subject: Reply with quote
When I was looking at an MZ 2 stroke a few years ago it had a broken kickstart spring. May be a common thing.
Hopefully it's located under the clutch cover and therefore quite easy to get to. If it's further back, swear.
And clean your jets. This is the closest I'll get to telling you to cool your jets in the workshop forum.
PostPosted: 15:53 - 11 Nov 2008    Post subject: Reply with quote
For the clutch cover gasket why not use a cereal box? It's just as good as any gasket you can buy.
PostPosted: 15:59 - 11 Nov 2008    Post subject: Reply with quote
The only thing that stops the throttle falling off is the bar end. make sure it hasn't been put in too tight.
I haven't actually guddled inside one of those engines but I would imagine the kickstart return spring has a 'hook' that fits over the sprocket quadrant and a 'tail' that in all probability presses against the crankcase itself.
With this sort of thing you usually need to push the quadrant in with the spring in place, rotate it into position which tensions the spring then hold it there while you fit the shaft through it.
You then have to fiddle the cover back on without the whole lot pinging back off again. I seem to recall it being necessary to put your finger through the hole in the cover for the kickstart shaft so you can keep pressure on the shaft while you slide the cover into place and nip a couple of screws in.
Lone-Wolf
PostPosted: 16:20 - 11 Nov 2008    Post subject: Reply with quote
Wotcha.
Oh, I never knew that. Always wondered why when my Bantam would tick over for ever, the MZ just don't want to play.
Terrible things, these 'ere MZs - I'm now addicted to mine. I'm currently rewiring it . . . . just for fun Thumbs Up
{The things you do to pass the dark Winter nights away }
Cheers.
L.W. - www.moonshiners.org.uk
luke27
PostPosted: 16:32 - 11 Nov 2008    Post subject: Reply with quote
I found 2 things slowed the idle speed down on that bike.
1. Was slow traffic / lots of idling, but every time you hit the open road and blasted the bike out it would be fixed until next time.
2. Was switching the lights on, this would slow the engine down at any engine revs.
If you had both 1 and 2 at the same time the engine may stall or nearly stall depending on how bad the 2 above were.
So I often switched the lights off at that time and also when I wanted to overtake a lorry.
Don't have it anymore, I defected to japan.
PostPosted: 16:34 - 11 Nov 2008    Post subject: Reply with quote
0.4mm idle jet diameter has been mentioned to me in a very much second hand and roundabout manner.
This is no basis whatsoever for altering a fundamental part of your motorcycles fuelling system. Unless of course you happened to have a spare jet that fits and a drill.
luke27
PostPosted: 16:44 - 11 Nov 2008    Post subject: Reply with quote
Have any of you seen the MZ Workshop Videos?
It shows you everything inside and how to strip it down and up again.
https://www.bikechatforums.com/viewtopic.php?t=140295&postdays=0&postorder=asc&start=0
Its under MZ in the first post.
I noticed the Videos did not appear on the internet until the company went bust so I assume there are no copywrite issues.
I turned the videos in to DVD format so I could watch them on my TV.
I class them as an educational tool and general entertainment since I do not have the bike anymore.
PostPosted: 16:49 - 11 Nov 2008    Post subject: Reply with quote
Basically it ALWAYS stalls unless I hold the throttle open a little. I'm wondering if there is an idle speed adjustment on the carburettor... Thinking
PostPosted: 16:52 - 11 Nov 2008    Post subject: Reply with quote
It doesn't have a bar end...
luke27
PostPosted: 17:41 - 11 Nov 2008    Post subject: Reply with quote
Yes there is a idle speed screw.
Its many years since I owned the bike.
Its proberbly the biggest flat headed screw one.
I actually had the MZ ETZ 251 SAXON FUN.
Your bike was identical in every way except for the larger piston.
Even the carb was the same.
I did find the engine ran much better on Super Unleaded.
Normal Unleaded made the off the line performance worse than a Honda 50cc Cub.
You might like to try Shell V Power or BP Ultimate.
Just incase avoid Tesco 99 since it has ethanol in it which might eat the east german engine valves etc.
Are you using the original screen and handlebars?
I fitted the aftermarket taller screen since the original was useless.
The original handlebars resulted in almost no weight on the front wheel so every flatterned piece of mud or hedgehog would through the front wheel in to the air slightly and sideways.
I fitted jota bars which are adjustable so I found the ideal position.
I also used the rear foot rests on long trips when I did not have to change gear / brake to often.
I adjusted the bars to be as low and as far away from my body as possible. This transformed the handling and performance of the bike and no more front wheel problem since far more weight was on it.
I was able to reuse the handlebar grips.
The left one just needed boiling water to get it off and on.
But yours might have gone off with age.
Ichy
PostPosted: 18:08 - 11 Nov 2008    Post subject: Reply with quote
Not too bad, Zylinderkopfdichtung
PostPosted: 18:18 - 11 Nov 2008    Post subject: Reply with quote
If it has the original bars and twist grip it does.
Doesn't necessarily look like it because it takes the form of a slightly dome-shaped 'plug' that fits flush with the end of the twistgrip. This is all that holds the entire twistgrip assembly in place.
Errr. I hope you can spot the error in the above statement!
Just for academic interest. I know a guy who fitted an SU carburettor off a mini to his MZ and rigged it so he could adjust the main jet diameter using a lever on the handlebars. He has run it on such diverse fuels as 50:50 unleaded and meths, BBQ lighter fluid, paraffin, lamp oil or pretty much anything else flammable he can get his hands on. He uses corn oil instead of 2-stroke oil. The bike goes like shit off a stick!
https://i48.photobucket.com/albums/f216/stinkwheel/rat%20and%20survival%2007/01430011.jpg
This leads me to conclude that whatever the problem might be, it is not the grade of fuel.
PostPosted: 19:24 - 11 Nov 2008    Post subject: Reply with quote
I actually think that the compression isn't high enough to warrant stupid unleaded. I used to run Tesco 99 in my RGV and it was fine. But that was high compression and had a stupidly advanced ignition. Maybe the ignition timing on your MZ was advanced too far? Mine has a CDI and apparently the quickest way to destroy the CDI is to take the plug out and put it against the engine to test the spark!
It is a *little* flighty, but I don't care. I bought it for commuting and I've got other bikes for performance and handling. I'm actually finding it a lot of fun as it is. It definately has no bar ends because the grips still have their end bits on (just). The grips are old and knackered, but they are fine for now.
The screen is cracked and yellow. Maybe I should make myself a new one. G has some perspex which might work OK for it. If I could make it a bit taller that would be cool.
luke27
PostPosted: 21:46 - 11 Nov 2008    Post subject: Reply with quote
At the time it was the only bike I had so I had to improve it.
Mine also had CDI.
Don't make the same mistake as others do about super unleaded.
People keep saying there is no point unless the compresion requires it.
But there is far more than just octane in many of the super unleaded fuels.
The main extras are stronger cleaners and other things.
The advice is try it and see what happens.
Some engines will show no difference, others will improve.
The amount of improvement will depend on so many variables the simple answer is try it and see.
The MZ 2 stroke engine does excessively suffer from burning deposits when around town and excessive idling so extra cleaners in the fuel could well help and may improve the idle problem.
Put another way, what if your problem is the carb needs a clean.
The best solution is as you mentioned cleaning the carb.
But the other option is to put petrol through with extra cleaners in to try and clean it out.
If the problem is dirt some ware else in the engine that the petrol comes in to contact with it could also clean it.
In an old engine its often advised to put petrol in with extra cleaners to try to clean it out.
Only problem is the cleaners are weak so takes a long time.
Saying that if you do not notice a decent improvement after 1/2 a tank you can always fill up with normal petrol next time.
I know the extra cleaners are in Shell V Power, BP Ultimate and Tesco 99. The other brands may only be as good as normal unleaded.
I remember the original grips on the bike.
at least I do the left hand one.
It was solid rubber.
It was closed at the end (no handlebar weight or bung).
As for the ethanol part.
My point was that the bike is east german.
They stopped making the old 2 stroke in 1994.
The berlin wall had only fallen a few years before and ethanol was not normal or common back then in east germany or the ex soviet union.
So I doubt the bike is designed to handel ethanol even at our 5% level.
PostPosted: 21:56 - 11 Nov 2008    Post subject: Reply with quote
I can assure you that given a sufficiently large main jet, an MZ 2-stroke can and will run on pure ethanol, never mind 5%.
Take this as fact.
A badly worn carb slide can be another cause of non-existant idling.
PostPosted: 22:49 - 11 Nov 2008    Post subject: Reply with quote
By that reasoning I could also run normal unleaded... with a load of redex in the carb! Wink
I think I'm going to take the carb off at the weekend and give it a clean. I went to Halfrauds at lunchtime and now I have a bottle of TTS and a can of carb cleaner in my top box! Smile When I take the carb apart I can see if the slide is overly worn. Anyone know what kind of carb is fitted to my bike?
I've also ordered some high temperature silicone sealant which I plan to daub on the sides of the head gasket to try to seal it a bit.
PostPosted: 23:02 - 11 Nov 2008    Post subject: Reply with quote
If you are going to use gasket goo. Take the head off, coat the gasket with your goo of choice and refit. It is held on with FOUR NUTS, some models have an attachment to a rubber frame mount too which comprises two bolts. Head off on an MZ is a side-of-the-road job.
It probably has a "Bing" slide carburettor. Diagram.
Do remember that people chop and change parts from different MZs. It is not at all unusual for example to find a rear brake hub fitted on the front wheel or a five speed gearbox in a four speed bike, or a 251 carb on a 301 etc. etc. They are almost infinately bodgeable.
luke27
PostPosted: 13:04 - 12 Nov 2008    Post subject: Reply with quote
I still have the owners manual for the bike.
The Owners manual is for the
ETZ 125
ETZ 150
ETZ 251
ETZ 301
For the ETZ 301 it states
Carburetor
Bing Type 84/30/110
Intake pipe diameter 30
Main Jet 118
Venturi tube 7
Needle Jet 72
Jet needle 4E1
Needle position from top 2
Idling Jet 45
Idling air regulating screw (open turns) 1...1 1/4
Gas Slides 197
Idling Speed approx 1200 rpm.
luke27
PostPosted: 13:21 - 12 Nov 2008    Post subject: Reply with quote
If you want a laugh the owners manual states the exact same carb and settings for the ETZ 251
Yet the 125 and 150 have different carbs / settings to each other.
The ETZ 251 got only 50 to 60 mpg and performance was bad from new.
It was running way to rich so the needle had to be set to as lean as possible.
It then got 60 to 70 mpg and performance improved.
But thats with normal (slightly faster acceleration than adverage cars) riding around at 60mph or lower.
It was said the carb was overfueling since its was setup for the ETZ 301.
I assume you have noticed the bike handles far better and has faster acceleration when you only have around a gallon of fuel in the tank?
That meant I had to run on reserve all the time and I did run out once when I had a faulty batch of petrol (halved my fuel consumption).
Tank holds 24 litres.
It claims that 1.5 litres of that is reserve but mine used around 4.5 litres for reserve.
luke27
PostPosted: 16:02 - 12 Nov 2008    Post subject: Reply with quote
Take this as fact.
Do you know anyone who has run 85% ethanol or stronger?
I belive nearly all carbs would dissolve inside at that strength.
There was a big point that the carb would have to be converted so it did not dissolve inside (thats what they said in the 21st century).
Even in the past, the first model T ford had a version with 2 carbs.
One for petrol and another for 100% ethanol.
The ethanol carb had cork inside to stop it eating the carb insides.
PostPosted: 16:08 - 12 Nov 2008    Post subject: Reply with quote
At the moment it starts easily when cold without choke so I suspect it is running rather rich. The old plug I took out was black. I plan to do a plug chop soon to see what is going on in there. You think that if I'm running too rich I might be able to lower the needle (raise the needle circlip) to make the bike run a little leaner?
PostPosted: 17:35 - 12 Nov 2008    Post subject: Reply with quote
Yes.
Among other things, every speedway bike in the world runs on pure methanol.
I have a friend who runs a 1968 triumph bonneville on Wood alcohol which is largely ethanol.
The MZ I posted a picture of has 50:50 methylated spirits and unleaded in the tank at the time said picture was taken.
I can think of no chemical property of ethanol that would allow it to dissolve, corrode or in any way damage any of the componants contained within a carburettor. It could potentially cause a serious cleaning to occur.
Use of excessive ethanol without seriously adjusting the jetting will however cause fairly major running issues. While the octane rating of pure ethanol is somewhere around 140, it has a low energy density. As such, you need WAY bigger jets to avoid running lean.
It just occurred to me that you might be getting ethanol and acetone confused? Acetone can cause untold mayhem with rubber engine seals.
All of this is of little relevance to the original thread however. An MZ 2-stroke is designed to run on poorer quality fuel than you could possibly buy in the uk.
The last post was made 17 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.25 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 153.34 Kb
