Servicing
Pickle
PostPosted: 14:57 - 13 Nov 2008    Post subject: Servicing Reply with quote
How much do you pay for your services and what sort of stuff gets done on them? I know it varies from bike to bike, but I've just had my first one done and I think (I hope) I got a pretty good deal:
New shoes, oil, coolant, bulbs, filter, sparks and a gasket drain plug for £200 (including labour). Bike is a Kwak, 2001.
Whaddya think? Like some comparisons to see if I should go back to the bloke next time.
rotax81
PostPosted: 15:09 - 13 Nov 2008    Post subject: Reply with quote
a 2001 kwak could be anything.
£200 looks fair, i would go back there again Thumbs Up
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
PostPosted: 15:11 - 13 Nov 2008    Post subject: Re: Servicing Reply with quote
If he's done a good job and balanced the carbs/throttle bodies, lubed the cables and levers etc, then yes it was a very good deal.
If he's done a crap job then you've thrown your money away. Doesn't matter if you spend £5 or £500 a crap job is a crap job.
mr.kris
PostPosted: 15:34 - 13 Nov 2008    Post subject: Reply with quote
i just had my ZX6R J2 serviced full service oil and filter valve clearences air filter cleaned all cables ect lubed adjusted tyres given a once over cleaned brakes cleaned and bled they even replaced a few bolts whitch were missing for £370
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
MattEMulsion
PostPosted: 16:00 - 13 Nov 2008    Post subject: Re: Servicing Reply with quote
What bike is it then apart from a 2001 Kwak? The servicing costs can vary significantly dependant on the actual bike.
Yamaha YZF-R6
Finglonga
PostPosted: 16:17 - 13 Nov 2008    Post subject: Reply with quote
Googles 2001 Kwak and a few came up was expecting the same picture of one bike over and over again. Embarassed
Mr. Green
Andy Sez....
F.Y.Y.F.F.
Pickle
PostPosted: 16:43 - 13 Nov 2008    Post subject: Re: Servicing Reply with quote
Embarassed
ER-5.
Never had a service before!
The Tot
PostPosted: 12:26 - 14 Nov 2008    Post subject: Reply with quote
Typically on my ZX6R-F,
£200 is good enough to get oil and filters done and valves checking if they don't need shimming. Most of it is labour, so if you can factor out the price for parts, you can start to see where the savings lie.
In my case, because i clock about 12000 miles a year, almost all my main services are major (i do small bits myself)
£320 sees
Arrow Oil & Filter change
Arrow Valve checked & shimming
Arrow Carb balancing
Arrow Brake strip & rebuild
That was at some back street garage in edinburgh. If that was at my usual garage in Loughborough, I'd only get Oil & Filters + valves and possibly brake strip i that price.. I tend to try and do my own servicing now and leave the lazy stuff to the mechanics. Bleeding your own brakes can take a long time if you're doing it for the first time, but you'll save £30 quid if you do it yourself, same with an oil change. Changing your brake pads is a 5 minute job.
Having said that, if you cock up spectacularly, then you feel that it was probably better off taking it to a garage, but i like learning from my mistakes (read as destroying sumps and shrearing off bolts!) so next time you'll know what to expect.
Never argue with autism
The last post was made 17 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 60.29 Kb
