| craigT19 |
 craigT19 Jolly Green Giant
 Posted: 09:37 - 25 Apr 2004 Post subject: New engine worries... |
Hi,
I need a mechanically minded person for this one, I'm going to pick my new zx-6 engine up today, is there anything i should look out for?? also the engine has a worn down generator cover...is it possible to see if the crank has been damaged etc?.
The engine was in a bike that was in a big crash...its evan got a cracked rocker cover (what ever that is) is that likely to have damaged anything.?
Regards ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
BCF member pops. sadly missed 1945-2003 |
| MarJay |
 MarJay But it's British!
 Posted: 10:27 - 25 Apr 2004 Post subject: |
Oh dear,
A rocker cover is on an engine that has rocker arms and push rods. Evidently the breaker you bought this engine from does not know that it is an overhead cam design (as with all modern engines). This means that it is likely that the very top cover of the engine is damaged...
I would be very wary if I were you, there will be loads of bike write-offs with no damage to the engine, and so be very careful of this.
If the generator cover is worn then I would imagine that the generator would get damaged before the crank, but don't quote me on this.
HTH  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| craigT19 |
 Posted: 10:30 - 25 Apr 2004 Post subject: |
Thx im getting it for £180 from a guy on ebay, the rocker cover has a small crack on it..thats as far as that damage goes? ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| Robby |
 Robby Dirty Old Man
| craigT19 |
 Posted: 11:50 - 25 Apr 2004 Post subject: |
ok thx peeps...hopefully if there is anything wrong they can just strip it out of my old lump ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
 Posted: 13:04 - 25 Apr 2004 Post subject: |
A minor crack in the rocker cover (or cam cover for the pedants) is not that likely to do any damage on its own. On some bike the oil feed to the cams goes through the rocker cover but it is not that common. Just replace the rocker cover with the one from your old engine.
The crank end cover might cause more of a problem. If it has gone the whole way through then it is possible for it to damage the stator or rotor. It would probably take a fairly large impact to push it far enough out of line for the stator to be pushed out of position and damage the rotor / crank. Again, 90% likely you can just swap the cover over with the existing ones.
Yes running an engine on its side can do a load of damage. However a short time at idle speed is not likely to do any real damage.
| craigT19 |
 Posted: 20:42 - 25 Apr 2004 Post subject: |
ok i got the lump
the crack on the rocker cover was very very small..it was a semi circle about the size of a 1 pence piece.
1 more tho...the engine is from a 1998 zx6 (G1), and my bike is the zx6 (g2) 1999 bike..i been told by various people this shouldn't matter as the lump is the same..but should i expect any differences??
what exactly is the difference between the G1 and the G2 other than color?
regards.
Also every body in this thread gets a from me  ____________________ Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
| Shaun |
 Shaun Likes 'em bent
The last post was made 22 years, 179 days ago. Instead of replying here, would creating a new thread be more useful? |
