Honda CG125: Headlight switch is stuck on full beam
Newbiker0507
PostPosted: 22:31 - 22 Nov 2008    Post subject: Honda CG125: Headlight switch is stuck on full beam Reply with quote
The button I use to switch between full and dipped beam is stuck on full. Any idea how I would fix this?
ATB,
James
yen_powell
PostPosted: 23:19 - 22 Nov 2008    Post subject: Reply with quote
Is it one of the square push in, pop out type? If it is, they are usually hollow on the bottom face and you can get a key or small screwdriver in and lever them out again. Then spray liberally with WD40 and keep working it till it loosens up.
XT1200Z and a DR350 in bits
Gazdaman
I did a trackday!!!
PostPosted: 11:14 - 23 Nov 2008    Post subject: Reply with quote
Failing that take apart the left switch gear. Should be two screws on the underside. Undo them and it'll hinge off like a clam. It's very basic and from there you should be able to examine the switch more closely.
Gaz
The last post was made 17 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 34.98 Kb
