Flywheel Puller (MTX 125)
Jello
PostPosted: 14:07 - 20 Nov 2008    Post subject: Flywheel Puller (MTX 125) Reply with quote
Well it didn't take long for the bike to get sick again. Bid end bearings this time.
I found another crankshaft on ebay complete with conrod and big end. So I'm in the process of stripping my engine to replace the crankshaft.
I've come unstuck on the flywheel though. The manual suggests using a specific flywheel puller, which I don't have.
Does anybody know of anywhere that would sell such a tool?
Honda MTX 125
yen_powell
PostPosted: 15:13 - 20 Nov 2008    Post subject: Reply with quote
If it's got a threaded hole in the middle, try using your rear axle. That's worked on a few bikes I've had to remove them from.
XT1200Z and a DR350 in bits
sumpgard
PostPosted: 16:11 - 20 Nov 2008    Post subject: Reply with quote
try race spec £5.99 +postage you will have to measure thread +depth required i have just rebuilt my mtx 125 engine i would also make sure you have a manual handy quite complecated when all the gears and selector forks have to be removed to pressout main bearings.
sumpgard
PostPosted: 16:24 - 20 Nov 2008    Post subject: Reply with quote
Jello
PostPosted: 02:45 - 23 Nov 2008    Post subject: Reply with quote
Sorry, I don't follow...
Honda MTX 125
yen_powell
PostPosted: 10:37 - 23 Nov 2008    Post subject: Reply with quote
If the flywheel is sitting on a tapered shaft and has a threaded hole in the centre then a flywheel puller screws into the hole and when it touches the end of the tapered shaft, you carry on turning it (it gets harder) and it forces the flywheel off of the shaft.
It sometimes occurs that the thread on the rear axle is the same thread on the flywheel. I've used the rear axle a couple of times (on a Yam XT125, is the only one I can definitely remember) and it's worked.
frazer1981
PostPosted: 12:09 - 23 Nov 2008    Post subject: Reply with quote
i got a draper 3 arm puller to get my one off the shaft. Think it cost me a fiver from local car shop. The only thing though is i had to reprofile the arms to fit in the holes in the fly wheel. I have not took it off yet as i don't want to freeze my ****** off in the garage at the minute Razz
1st bike - chunlan starway 50QF4 (SOLD) 2nd bike - 92 Honda mtx125RW-L ( In my garage awaiting some TLC)
05 Honda xl125v Varadero stolen and recovered but now a write off! Sad
07 Hyosung GTR125R
The last post was made 17 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.36 - MySQL Queries: 13 - Page Size: 52.42 Kb
